What's the difference between tensors and vectors?
Tensors and vectors are closely related mathematical constructs, with tensors defined as multilinear maps between Cartesian products of vector spaces and real numbers. A tensor can assign a real number to a list of vectors, exemplified by the signed area of a parallelogram formed by two Euclidean vectors. In contrast, vectors can be viewed as maps from a dual space to real numbers, establishing a duality that allows for the interchangeability of tensors and vectors depending on the context. This discussion clarifies that while tensors and vectors serve different roles, they can often be conflated in mathematical applications.
  • Understanding of vector spaces and their properties
  • Familiarity with dual spaces and linear maps
  • Knowledge of Euclidean geometry, specifically parallelograms
  • Basic concepts of multilinear algebra
  • Study the properties of multilinear maps in detail
  • Explore the concept of dual spaces in linear algebra
  • Learn about the applications of tensors in physics and engineering
  • Investigate the relationship between tensors and differential geometry
Mathematicians, physicists, and engineers who require a solid understanding of the mathematical foundations of tensors and vectors, as well as students studying linear algebra and its applications.
johann1301
Whats the difference between tensors and vectors?
A tensor is a multilinear map between Cartesian products of vector spaces and real numbers. In more colloquial terms, a tensor assigns a real number to a list of vectors, where each vector's map is linear. An example is a tensor whose input is a list of two Euclidean vectors, and whose output is the signed area of the unique parallelogram spanned by those vectors. Another example with two vector inputs and one real output, linear in both arguments, is the dot product.
For any vector space V, there is a dual space V* consisting of all linear maps from V into the set of real numbers R. For example, in the vector space R3, the map that takes any vector of the form (x, y, z) to ax + by + cz is an element of the dual space. Notice it could be considered a dot product (a, b, c) . (x, y, z) between two vectors. This motivates the idea that the dual space and the vector space are both equally potent vector spaces, so we may give the dual space a vector space structure as well. (Of course, we prove that this can be done for any vector space, not just R3). Notice that now, each particular vector (x, y, z) in V can equally be considered a map from an arbitrary element (a, b, c) of the dual space into R.
Thus, since a single vector in a vector space V can be considered as a map from the dual space V*, which is a vector space, to R, a vector can be considered a tensor. Likewise, since a Cartesian product of vector spaces can itself be given a vector space structure, a tensor can be considered a vector. It all depends the particular context you want to work with at any particular time. So they are very similar, and in many cases can be conflated.
Thanks for taking the time to write this!
