When and Where Do Two Cars Collide? A Velocity Analysis
  • Thread starter Thread starter aziegler@uark
    Cars Velocity
Two cars, A and B, start at different positions and accelerate at constant velocities after 5 seconds. Car A begins at 2500m and travels at 25 m/s, while Car B starts at -1000m and moves at 30 m/s. To determine when and where they collide, their positions must be expressed as functions of time and set equal to each other. The problem emphasizes that the cars do not start from the origin, complicating the setup. A proper understanding of the equations relating distance, speed, and time is crucial for solving the collision point.
aziegler@uark
Two cars are at rest. Car A is at x=2500m, and Car B is at x=-1000m. At t=5s car A instantly travels at a constant velocity of 25 m/s in the positive x direction. At the same time car A takes off, car B travels at a constant velocity of 30 m/s, also in the positive x direction. When does car B collide with car A? Where does this occur?
velocity=displacement/time; speed=distance traveled/time;
I am having trouble with this problem 1. because I have never taken physics and 2. because its wording is confusing me a bit. I tried to make a graph of this problem, but I thought that time is usually the x-axis and position is usually the y-axis, but the problem says that the cars' positions are on the x-axis and the time I guess would be the y-axis. I think I need to set two equations equal to each other and solve for the variable time, but I'm having trouble finding a starting point. I have to stopping point so I can't figure out a ratio of the two either. Please help!
You will need to set two equations equal to each other. When the cars collide their positions will be the same. You need an equation that relates the distance traveled to the speed they're traveling and the time. Also do not forget they do not start at the origin (or 0).
Thanks Kurdt! I will try this out and play with the numbers.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
