When Can We Swap Variation and Partial Derivation in Calculus of Variations?
  • Context: Graduate
  • Thread starter Thread starter pellman
    Derivative Variation
The discussion centers on the conditions under which variations and partial derivatives can be interchanged in the context of the calculus of variations. Participants explore this topic through examples involving functionals and variations of functions, particularly focusing on the implications of varying parameters and the definitions involved.
  • One participant asks when it is permissible to express the variation of a partial derivative as the partial derivative of the variation.
  • Another participant suggests that this interchange is valid under certain assumptions, but acknowledges that showing it formally may require more detail.
  • A different participant clarifies that their use of "delta" refers to first order variation, not a Dirac delta function, which leads to further discussion on definitions.
  • One participant asserts that the interchange is always valid unless there are specific boundary conditions that complicate the situation.
  • Another participant introduces a functional and questions the conditions under which the variation of a derivative can be expressed as the derivative of the variation.
  • There is a discussion about the potential complications arising from varying the parameter time, with one participant questioning if this affects the relationship between variations of the function and its derivative.
  • Another participant counters that the relationship remains fixed as long as the variation of the function is defined, emphasizing the linearity of differentiation.
Participants express differing views on the conditions under which the interchange of variation and partial derivation is valid. Some assert it is always valid, while others suggest that specific conditions or definitions may need to be considered. The discussion remains unresolved regarding the implications of varying parameters.
Participants reference specific definitions and assumptions related to variations and derivatives, indicating that the discussion may depend on these definitions. There are also mentions of boundary conditions that could influence the validity of the claims made.
pellman
Suppose we are taking the variation of a multiple integral and the integrand contains some terms with [itex]\frac{\partial g}{\partial x}[/itex]. When is it ok to put
[itex]\delta\frac{\partial g}{\partial x}=\frac{\partial}{\partial x}(\delta g)[/itex]
This is a trivial way of showing that what you have written is valid, but I'm guessing you already know it. I'm assuming [itex]\delta[/itex] is dirac, so for [itex]\delta ≠ 0[/itex]:
Since [itex]g_x \rightarrow \frac {\partial g}{\partial x}[/itex], [itex]\delta \cdot g_x = \delta[/itex]([itex]\frac {\partial g}{\partial x}[/itex]) and [itex]\frac {\partial (\delta g)}{\partial x} = \delta g_x[/itex] [itex]\leftrightarrow \delta \frac {\partial g}{\partial x}[/itex], is implied.
Simply put, if you rewrite the terms on either side of your equation you get:
[itex]\delta g_x = \delta g_x[/itex]
Showing it formally would be a little more involved I suppose. The elemental basis of [itex]g_x[/itex] would have to be somewhat disambiguated.
Thank you for the reply. I'm not sure what you mean here. But my delta is not a dirac function. It means here a first order variation.
Any time. You asked "when is it ok to do this", and I assumed that it was always ok to do that since both terms can be rewritten and equate to each other by definition. I'm not sure if if I'm oversimplifying the question, but unless there is a bound-problem with [itex]g_x[/itex] this seems to be more a matter of semantics than theory/concept.
I am still interested in this question. Spelling it out a little better:
Suppose we have a functional
[tex]J[q]=\int^{t_2}_{t_1}{L\left(q(t),\dot{q}(t)\right)dt}[/tex]
where q can be any function in some appropriate domain of functions. And we take the first variation [itex]\delta J[/itex] by varying the function [itex]q\rightarrow q+\delta q[/itex]. Under what conditions can we put [itex]\delta \dot{q}=\frac{d}{dt}(\delta q)[/itex] ?
Always.
If [itex]q \to q + \delta q[/itex] then [itex]\dot q \to \frac{d}{dt} (q + \delta q) = \dot q + \frac{d}{dt} (\delta q)[/itex]. The change in [itex]\dot q[/itex] is then by definition [itex]\delta \dot q = \frac{d}{dt}(q + \delta q) - \dot q = \frac{d}{dt}(\delta q)[/itex].
But if we also are making a variation of the parameter [itex]t \rightarrow t+\delta t[/itex] this can complicate the relation between [itex]\delta q(t)[/itex] and [itex]\delta \dot{q}(t)[/itex], right? I just wanted to be sure that as long as the endpoints are not being varied, then [itex]\delta \dot{q}(t)=\frac{d}{dt}\delta q[/itex] and that I wasn't overlooking some other possible complication.
No.
If you vary a function [itex]q \to q + \delta q[/itex] then the variation in [itex]\dot q[/itex] is fixed as soon as you choose [itex]\delta q[/itex]. Differentiation is a function of a function; if [itex]D(q) = q'[/itex] then [itex]D(q + \delta q) = (q + \delta q)' = q' + (\delta q)'[/itex] because the derivative is linear.
Remember that [itex]\delta q[/itex] is the difference between the new [itex]q[/itex] and the old; thus if you have [itex]q \to q \circ f + r[/itex] then [itex]\delta q = q \circ f + r - q[/itex]. Then [itex]q' \to (q \circ f)' + r'[/itex] and [itex]\delta (q') = (q \circ f)' + r' - q' = (\delta q)'[/itex].
