Why do the lines m and l coincide in the proof of the parallelogram rule?
  • Context: Undergrad
  • Thread starter Thread starter PLAGUE
    equation Lines
The discussion revolves around the proof of the parallelogram rule using vector notation from "A Course in Mathematics for Students of Physics Volume 1" by Paul Bamberg and Shlomo Sternberg. It establishes that the lines defined by points P and R coincide if they share a common point, leading to the conclusion that either they are the same line or parallel. The proof hinges on the equation R + sv = P + (s + t1 - s1)v, demonstrating that all points on one line correspond to points on the other, confirming their equality. The geometric definition of a parallelogram reinforces this conclusion by showing that the vectors involved must satisfy specific conditions.
  • Understanding of vector notation and operations
  • Familiarity with the geometric definition of a parallelogram
  • Knowledge of linear equations and their graphical representations
  • Basic concepts of intersection and coincidence of lines in geometry
  • Study vector operations in depth, focusing on vector addition and scalar multiplication
  • Explore the geometric properties of parallelograms and their vector representations
  • Learn about the conditions for line intersection and coincidence in Euclidean geometry
  • Investigate the implications of null vectors in vector spaces and their geometric interpretations
Students of mathematics and physics, particularly those studying linear algebra and geometry, as well as educators seeking to clarify the concepts of vector spaces and parallelograms.
PLAGUE
TL;DR
If P and R are two points and v is a vector, then when will ##P + tv## and ##R + sv## coincide? Here t and s are parameters that varies over real number.
I was going through this book called "A Course in Mathematics for Students of Physics Volume 1 by Paul Bamberg and Shlomo Sternberg". There in a part they said something like this:
...if we start with a point P and write
##R=P+u##
##Q=P+v##
and
##S=P+(u+v)##
then the four points
##P,Q,S,R##
lie at the four vertices of a parallelogram... The proof of this fact goes as follows. For any vector
##v=(a,b)##
and any real number t defines their product tv by
##tv=(ta,tb)##
if P is any point the set
##l=P+tv##
(as t varies over real number), is a straight line passing through P. If R is some other point, then the line
##m=R+sv##
(as s varies over real number) and l will intersect, i.e., have some point in common, if and only if there are some
##s_1##
and
##t_1##
such that,
##R+s_1v=P+t_1v##
which means that
##R=P+(t_1−s_1)v##
and hence, for every s, that
##R+sv=P+(s+t_1−s_1)v.##
This means that the lines m and l coincide. In other words, either the lines l and m coincide or they do not intersect, i.e., either they are the same or they are parallel...
Now what I don't understand is the last sentence, why m and l coincide? How can they say m and l coincide from the equation,
##R+sv=P+(s+t_1−s_1)v##
That seems a very complicated approach. What definition of a parallelogram are they using? In terms of vectors, that is more or less the definition of a parallelogram. Note that the vectors ##\vec u## and ##\vec v## need to be in different directions.
If we take the geometric definition of a parallelogram:
https://mathworld.wolfram.com/Parallelogram.html
And translate that into vectors, then we see (using the example in the above page) that we have:
$$\vec{AB} = \vec{DC} \ \text{and} \ \vec{AD} = \vec{BC}$$It would be much quicker simply to check that holds for the four points in your example, with ABCD replaced by PRSQ.
PeroK said:
And translate that into vectors, then we see (using the example in the above page) that we have: $$\vec{AB} = \vec{DC} \ \text{and} \ \vec{AD} = \vec{BC}$$It would be much quicker simply to check that holds for the four points in your example, with ABCD replaced by PRSQ.
And if the two lines (m and l in the OP's post) coincide, then one pair of vectors in the equations above will be zero vectors -- sort of a null parallelogram.
P+tv for all t, is the lien parallel to v and passing through P. R+sv, for all s, is the line parallel to v and passing through R. Since both lines are parallel to v, they are parallel to each other. Therefore they are either the same line or they do not meet. I.e. if they have even one point in common then they have all points in common.
The authors then assume there is one common point, namely that P+t1v = R +s1v. They then show that for every s, the point R+sv on one line, equals the point
P+(s+t1-s1)v on the other. I.e. that every point of form R+sv equals some point of form P+tv, namely the points R+sv and P+tv are equal when t = s+t1-s1. Hence the lines are equal. Actually they have shown the points of form R+sv all lie on the line consisting of points of form P+tv. To show the lines are equal they should also show the opposite, namely that all points of form P+tv also, lie on the line consisting of points of form R+sv. Maybe you can do this, unless you believe that a line which lies inside another line actually equals that line. Well you should do it anyway.
  • · Replies 46 ·
  • · Replies 42 ·
11K
