When does quantum take over classical?
  • Thread starter Thread starter DrummingAtom
    Classical Quantum
DrummingAtom
When does quantum "take over" classical?
There's seems to be a lot of information about how relativity "takes over" classical mechanics when certain speeds are reached, like at a certain % of speed of light, etc. I haven't found much information regarding when quantum mechanics takes over for atoms within a system. I have found the Quantum Realm from wikipedia but if I try to google that term produces a whole load of strange websites and I can't decipher what's garbage anymore.
Any advice on where to start looking?
Thanks.
Generally when dealing with particles, though there have been quantum mechanical evidence (wave interference) even with a buckyball (C_{60}) I can't find the paper, but this is the abstract I think: http://www.aip.org/pnu/1999/split/pnu453-2.htm
Quantum mechanics never "takes over". It's always correct - in principle, one could use QM to calculate the trajectory of a baseball, but of course that's impractical.
Relativity doesn't "take over" either - it's always valid. You need to consider it at progressively lower and lower speeds as you want progressively more and more accuracy in your calculation.
Thanks for the response. I'm confused by this article:
http://www.wired.com/science/discoveries/news/2007/04/quantum
From article said:
"One of the motivations for our experiment is to investigate a system which is on the border between quantum and classical," Treutlein said.
The article makes it seem like there is a defined line between the classical and quantum. It's pretty obvious that I don't know anything about this topic but I can't find anything online relevant to my question, which is why I'm asking for help to search.
Looking at the article, what the author probably means by 'the border between quantum and classical' is the scale and temperatures where classical physics no longer gives even a semi-accurate description of the situation.
The experiment in question involves forcing a macroscopic object to exhibit quantum irregularities, so the border is where it stops acting classically and starts acting 'quantumy'.
A good example would be some sort of oscillator with a resonance frequency f0 of a few GHz. At high temperatures where h*f<<kb*T (h is Planck's constant and kb Boltzmanns constant): the "population" of the different "levels" in the oscillator (which modes are active, they are not real levels since they overlap) can be described using a Boltzmann distribution. However, if you operate the oscillator at a temperature where h*f0>kb*T you have to use the quantum mechanical description (the Schroedinger equation to get the levels, and the Fermi's Golden Rule for the population).
In the intermediate region where h*f0 is approximately equal to kb*T both descriptions work (and you can also use some funny "hybrids", the SE for the levels and the BD for the populations).
Note that there are quite a few systems where this crossover can be seen experimentally (including mechanical oscillators), so it is not a hypothetical scenario.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
