When does the bead fly off the rod?
  • Thread starter Thread starter Adoniram
    Bead Rod
1 reply · 2K views
Adoniram
A rod of length L is fixed at one end, and rotates in the X-Y plane with angular velocity ω. (To be clear, it is sweeping out an area of ##π (L/2)^{2}##.) A bead starts at position ##r(0)=L/2## with ##\dot{r}(0)=0##. Find ##r(t)## and the time it takes for the bead to fly off the end of the rod.
##F=ma##
First, I wanted to find an expression for the velocity of the bead in general:
##v(t)=\dot{r}\hat{r}+rω\hat{φ}##
Then I find the acceleration of such a situation:
##a(t)=(\ddot{r}-ω^{2}r)\hat{r}+(2ω\dot{r})\hat{φ}##
Then I need to apply the 2nd law and solve the diff eq. My question at this point is: Is this problem readily solvable in this coordinate system, or do I need to switch to something else like ##r(φ)## first?
I've played with a few attempts, and my best guess right now is:
##\dot{r}(t)=(L/2)e^{(ω/m)t}##
or
##\dot{r}(t)=(L/2)e^{(2ω/m)t}##
(and of course the position is just the integral of that)
But I'm not really confident on that answer...
OK
Using polar coordinates is good. No, you do not need to express r as a function of angle.
or
This solution does not satisfy ##\dot{r}(0)=0##. Also, the argument of the exponential should be dimensionless.
Can you state the differential equation that you need to solve?
