When Integrating (2x)/(4x^(2)+2) I get two different integrals ?
4 replies · 2K views · last reply
FurryLemon
Hi
So let's have ∫(2x)/(4x^(2)+2) dx
Without factorising the 2 from the denominator, I integrate and I get
1/4*ln(4x^(2)+2)+c which makes sense as when I differentiate it I get the original derivative.
BUT when I factor the 2 from the denominator I have
2x/[2(2x^(2)+1)] simplify it down = x/(2x^(2)+1) which is the same as (2x)/(4x^(2)+2)
Now when I integrate ∫x/(2x^(2)+1)dx I get 1/4*ln(2x^(2)+1)+c
which is obviously different from the first integral. Why? because when I simplify it by factorisation its the same thing so Why is it different?
Please, any help would be appreciated.
Thanks.
The point is, [itex]\ln{ab}=\ln{a}+\ln{b}[/itex]. Now if you assume [itex]c=\frac 1 4 \ln{2}[/itex] in the second solution, you'll get the first. So they differ only by an additive constant which makes them equivalent.
Ok, thanks
Ideally its better to not factor anything out from the denominator then, unless you think you can get partial fractions that is.
Indeed, this can be observed from something as simple as:
$$\int x-1 \space dx$$
Making a substitution ##u = x - 1## gives ##du = dx##. Hence:
$$\int x-1 \space dx = \frac{(x-1)^2}{2} + C$$
Now what if you simply integrated by using some integral properties instead of a substitution?
$$\int x-1 \space dx = \int x \space dx - \int 1 \space dx = \frac{x^2}{2} - x + K$$
The two answers look nothing alike, but they're exactly the same! In fact, you can show they differ by a constant. Taking the answer for the substitution method and massaging it a bit gives you:
$$\frac{(x-1)^2}{2} + C = \frac{x^2 - 2x + 1}{2} + C = \frac{x^2}{2} - x + \frac{1}{2} + C$$
It is clear by observation with the non substitution answer that ##K = \frac{1}{2} + C## so ##K## and ##C## differ by ##\frac{1}{2}##.
The other classic example is [tex]\int \cos \theta \sin\theta\,d\theta = -\frac12\cos^2\theta + C = \frac12\sin^2\theta - \frac12 + C = -\frac14 \cos(2\theta) + C - \frac14.[/tex]
