When is the commutator operator [X, A] unitary?
  • Level: Undergrad
  • Thread starter nojojo121
    Operator
17 replies · 10K views · last reply
nojojo121
TL;DR
Unitary operator in complex matrix space equipped with standard inner product
Unitary operator
If an operator L(A) = [X, A], are there matrix X for which the operator is unitary? Keep in mind it is in a complex matrix space with standard inner product (A, B) = tr(A*B)
nojojo121 said:
TL;DR Summary: Unitary operator in complex matrix space equipped with standard inner product
Unitary operator
If an operator L(A) = [X, A],...
How is ##[\cdot,\cdot]## defined?
And are we talking about a linear operator?
The use of unitary suggests that we speak about groups, in which case it would be ##[X,A]=X^{-1}\cdot A^{-1}\cdot X\cdot A##. However, in that case, ##L## wouldn't be a linear operator.
It is also possible, that you meant ##L(A)=X^{-1}AX,## the adjoint operator ##\operatorname{Ad}(X)## of a matrix group. This would at least be a linear operator.
However, experience plus the term operator suggests that you use it as ##L(A)=\mathfrak{ad}(X)(A)=[X,A]=X\cdot A-A\cdot X## in which case the corresponding property would be skew-hermitian.
nojojo121 said:
... are there matrix X for which the operator is unitary?
So you want to know whether there is an operator ##L\, : \,A\longmapsto [X,A]## such that
\langle L(A),L(B) \rangle =\langle [X,A],[X,B] \rangle =\langle A,B \rangle
I am not sure whether there is such a general answer to it, that it is completely irrelevant where ##A,B## are taken from and how ##[\cdot,\cdot]## is defined. My suspicion is a no. So please define the commutator and the domain the matrices are taken from.
In case ##L(A)=[X,A]=X^{-1}A^{-1}XA## the answer is no. ##L## isn't linear in that case and unitary requires linearity.
In case ##L(A)=[X,A]=\operatorname{Ad}(X)(A)=X^{-1}AX##, the answer is yes, e.g. ##L=X=1.##
In case ##L(A)=\mathfrak{ad}X## then ##L=X=0## is unitäry on all complex vector spaces.
This is neither standard nor generally an inner product at all. It suggests that you mean the Killing-form ##(A,B)\longmapsto \operatorname{tr}(\mathfrak{ad}(A),\mathfrak{ad}(B)).## This is an inner product in case ##A,B## are taken from a semisimple, in your case complex, Lie algebra.
Here is an overview that should help you navigate through the various set-ups:
https://www.physicsforums.com/insights/lie-algebras-a-walkthrough-the-basics/ usage of the terms.
Thanks for the reply. I should have been more specific. My definition for the operator is like you guessed, that is ##L(A)=\mathfrak{ad}(X)(A)=[X,A]=X\cdot A-A\cdot X## and ##L\, : \,M{_{n\times n} } \longmapsto M{_{n\times n}} ##. The inner product is ##(A,B)= \operatorname{tr}(A{^\dagger} B). ## which apparently is standard according to Wikipedia. Nevertheless I am searching for X for which the defined operator is unitary.
Reference?
##X=0## does the job, and ##(A,B)\longmapsto \operatorname{tr}(A^\dagger B)## is definitely no inner product.
\operatorname{tr}\left(\underbrace{\begin{bmatrix}1&0\\0&1\end{bmatrix}^\dagger}_{\neq 0} \cdot \underbrace{\begin{bmatrix}0&1\\1&0\end{bmatrix}}_{\neq 0}\right)=\operatorname{tr}\left(\begin{bmatrix}0&1\\1&0\end{bmatrix}\right)=0
@fresh_42 I'm confused, aren't there always lots of pairs of vectors whose inner product is zero? Those are just orthogonal vectors.
I think this is just the standard entry-wise dot product written to look fancy
Yes, my bad. I was lost in translation. We use the term inner product to describe the dot product, and scalar product to describe the inner product.
Anyway, ##L=X=0## is still an answer.
Edit: ... and I automatically think about Lie algebras if someone uses ##[\cdot,\cdot]## and unitary.
I'm confused- unitary operators are supposed to be invertible, but ##L(X)=[X,X]=0## represents a nontrivial kernel (unless ##X=0## but that case is just as easily dismissed). Am I missing something?
My very first statement was: define ##[X,Y]## since unitary belongs to groups and skew-hermitian is the corresponding non-regular property.
As I said, I associated Lie algebras since this is the most common use of ##[\cdot,\cdot]## on PF. Rarely anybody ever uses the group commutator. And the corresponding Lie group operation is the adjoint representation ##\operatorname{Ad}## on its tangent space. In that case, the group elements are commonly written by minuscules.
As long as unitary and presumably ##[X,Y]=XY-YX## as an operator occurs in one sentence, as long will I allow myself to consider the trivial operation.
However, you are all right. So I herewith answer: Yes. Set ##L=1## and ##V=\mathbb{M}(1,\mathbb{C}).##
I only wanted to emphasize that the question was badly posed.
fresh_42 said:
Reference?
I poorly worded what is being searched. I need to find all the matrices ##X## that make the operator ##L## unitary. As someone else mentioned above I think there is a loss in translation but what I call inner product you call dot product. So essentially I have to show for which ##X## the operator ##L## is an isometry.
The important information is where ##X## and ##A,B## are taken from. You said that all complex matrices for ##A## and ##B## are allowed. And you said that the inner product in the definition of the unitary operator ##L_X(A)=XA-AX## is ##\langle A,B\rangle = \operatorname{tr}(A^\dagger B).## This runs down to (if I didn't make a mistake)
\operatorname{tr}(A^\dagger X^\dagger XB-A^\dagger X^\dagger BX-X^\dagger A^\dagger XB+X^\dagger A^\dagger BX-A^\dagger B)=0\quad \forall \;A,B\in \mathbb{M}(n,\mathbb{C})
This is a linear equation system in the coordinates ##X=(x_{ij}).## The solution is therefore a complex vector space. Since you are only interested in a bijective operator, we finally have to calculate all ##X## such that ##A\longmapsto XA-AX## is regular for all solutions ##X.##
You can set ##A=E_{ij},B=E_{kl}## where ##E_{rs}## is the matrix with a ##1## at position ##(r,s)## and ##0## elsewhere in order to solve the system. Then see if ##i \cdot E_{rs}## gives even more equations.
I would start with ##n=2,3## and see how it goes. And I still think that there is something wrong here since you basically ask for regular elements in a Lie algebra. This is normally not of any interest.
I think you are misunderstanding my usage of ##B##, which is just an arbitrary matrix used to define the inner product. This is essentially the linear equation I am trying to solve:
\operatorname{tr}(A^\dagger X^\dagger XA-A^\dagger X^\dagger AX-X^\dagger A^\dagger XA+X^\dagger A^\dagger AX)=\operatorname{tr}(A^\dagger A)
\begin{align*}
\langle L(A),L(B) \rangle &=\langle A,B \rangle\\
\operatorname{tr}(L(A)^\dagger \cdot L(B))&=\operatorname{tr}(A^\dagger\cdot B)\\
\operatorname{tr}([X,A]^\dagger \cdot [X,B])&=\operatorname{tr}(A^\dagger \cdot B)\\
\operatorname{tr}((XA-AX)^\dagger \cdot (XB-BX))&=\operatorname{tr}(A^\dagger \cdot B)\\
\ldots &\phantom{=} \ldots
\end{align*}
https://en.wikipedia.org/wiki/Unitary_operator
Where am I wrong?
fresh_42 said:
\begin{align*}
\end{align*}
Where am I wrong?
My mistake. You are completely right, unitary operators must preserve the inner product and not just the norm.
I'm not sure about the infinite-dimensional case. In finite dimensions, we have the following situation.
If ##X,A,B \in \mathbb{M}(n,\mathbb{C}),## i.e. complex linear transformations of ##\mathbb{C}^n## then we have ##L(A)=(\mathfrak{ad}(X))(A)## and ##L\in \mathfrak{ad}(\mathfrak{gl}(\mathbb{C}^n))=\mathfrak{ad}(\mathfrak{sl}(\mathbb{C}^n)\oplus \mathbb{C}\cdot \operatorname{Id}_{\mathbb{C}^n})=\mathfrak{ad}(\mathfrak{sl}(\mathbb{C}^n))\cong \mathfrak{sl}(\mathbb{C}^n).## Unitarity demands that ##L\in \operatorname{SU}(\mathfrak{gl}(\mathbb{C}^n)).##
You are looking for matrices ##X## that have determinant ##1## and trace ##0## at the same time. This is unusual. May I ask about the context of your research?
@Infrared already said that ##L_X## always has a kernel, hence cannot be bijective.
The kernel of ##L## consists of the diagonal matrices with only one entry, complex multiples of ##1.##
\operatorname{ker}(L)=\{A\in \mathfrak{gl}(\mathbb{C}^n)\,|\,L(A)=0\}=\{A\,|\,XA=AX\;\forall \,X\in\mathfrak{gl}(\mathbb{C}^n)\} = \mathbb{C}\cdot \operatorname{Id}_{\mathbb{C}^n}
Every choice of ##X=S+\lambda\cdot \operatorname{Id}_{\mathbb{C}^n}## with ##S\in\mathfrak{ad}(\mathfrak{sl}(\mathbb{C}^n))## leads to ##L(A)=\mathfrak{ad}(X)(A)=[X,A]=[S,A]=SA-AS.## Thus ##L(A)## has a non-trivial kernel, the operator ##L=\mathfrak{ad}S## itself can be bijective.
No, because ##L_X(X)=0##. If ##S=X-\lambda##, then still ##[S,X]=0##.
Yes, I see it now. I'm getting too old for so little sleep. I was confused by the fact that ##\mathfrak{sl}(V)## contains regular matrices.
It had to be helpless. ##\det = 1## and ##\operatorname{trace}=0## doesn't fit very well.
