When is the sample median preferred to the sample mean?
  • Thread starter Thread starter sara_87
    Mean Median
sara_87
i have a few easy questions but i need some help with them:
1)
a) Why do we need averages?
b) Which average can have more than one value?
c) Which average represents the value when the total of all the sample values is shared out equally?
d) Which average has the same number of values above it below it?
e) When is the sample median preferred to the sample mean?
f) When is the sample mode preferred to the sample mean?
g) When is the sample mean preferred to both the sample median and the sample mode?
2)
a) Why do we need measures of variation ?
b) What measure of variation is most useful in the case of: (i) a symmetrical distribution, (ii) a skew distribution'?
c) Think of an example of sample data where the range would be a misleading measure of variation.
d) Name the measure of variation associated with the: (i) sample mean, (ii) sample median, (iii) sample mode.
e) Name the average associated with the: (i) sample standard deviation, (ii) sample inter-quartile range, (iii) range.
a) to analyse the data
b) when there's more than one dependent variable
c) i don't know
d)i don't know
e)when there's numerical data
f) when there's discrete data
g) when the histogram is symmetrical
2)
a) i don't know
b) i) mean/standard deviation ii) median/interquartile range
c) i don't know
d) i don't know
e) i don't know
any help would be very appreciated.
thank you.
a) to analyse the data: WOULD "SUMMARIZE" BE A BETTER WORD THAN "ANALYZE"?
b) when there's more than one dependent variable: NO. I AM INCLINED TO SAY "MOVING AVERAGE" BUT THAT'LL DEPEND ON THE CONTEXT.
c) i don't know: CAN YOU THINK OF AN EXAMPLE?
d)i don't know: DITTO
e)when there's numerical data: NO -- IT HAS TO DO WITH SYMMETRY AND OUTLIERS
f) when there's discrete data: NO -- IT HAS TO DO WITH "NUMERICAL DATA" VS. _________ ("DISCRETE" CAN ALSO BE NUMERICAL; E.G., INTEGER NUMBERS ARE DISCRETE)
g) when the histogram is symmetrical: THIS WILL FOLLOW FROM E AND F ABOVE
2)
a) i don't know: TO SUMMARIZE EXPANSIVENESS OF DATA?
b) i) mean/standard deviation ii) median/interquartile range: MEAN AND MEDIAN AREN'T MEASURES OF VARIATION. (THEY ARE MEASURES OF LOCATION.)
c) i don't know: THINK "OUTLIER(S)"
d & e) i don't know: D & E ARE "MATCHING PAIRS," YOU NEED TO MAKE THE RIGHT MATCHES.
i don't undrerstand what they mean by measures of vairation ??
Consider these two sets of numbers:
Set #1 : {2,1,2,2,2,3,2,2}
Set #2 : {3,1,2,2,0,2,4,2}
Both sets have the same mean, median, and mode. The second set exhibits a lot more deviations from the mean than does the first set.
so why do we need measures of variation, I'm sorry i just don't understand.
and i still don't know how to do question 2
For a), D H practically gave you the answer: because they give us some information we would otherwise miss.
For c): How is the range determined? Can you think, for example, of a set with a very wide range but very small variations?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
