When the Rational Root Theorem Fails
  • Context: Undergrad
  • Thread starter Thread starter drewfstr314
The discussion revolves around solving the equation -\sqrt{7-x}=-\frac{x^2}{2}+12x-10, particularly after transforming it into a quartic polynomial. Participants explore the implications of the Rational Root Theorem (RRT) failing to find rational roots and discuss methods for identifying solutions algebraically without relying on the quartic formula.
  • One participant notes that the quartic equation derived from the original problem has no rational roots according to the RRT, which suggests a need for alternative methods.
  • Another participant humorously suggests using the quartic formula, implying it is a standard approach.
  • Some participants propose that the roots of the quartic can be approximated within specific intervals, indicating a numerical approach may be necessary.
  • There is a discussion about the original equation having two solutions, with one participant asserting that it has only one real solution based on the behavior of the functions involved.
  • One participant corrects their earlier statement about the original equation, indicating a transcription error and suggesting that the correct form may yield two solutions, as confirmed by Wolfram Alpha.
  • There is a suggestion that the axis of symmetry of the parabola changes with the corrected equation, potentially allowing for intersections with the square root function.
Participants express differing views on the number of solutions to the original equation, with some asserting there is only one real solution while others believe there are two. The discussion remains unresolved regarding the best method to find the solutions algebraically.
Participants highlight potential errors in arithmetic or transcription that may affect the conclusions drawn about the number of solutions. The discussion also reflects uncertainty regarding the behavior of the functions involved and their intersections.
drewfstr314
On a math test, one of the questions was to solve [itex]-\sqrt{7-x}=-\frac{x^2}{2}+12x-10[/itex]. I solved graphically with a calculator, but later tried to solve algebraically, when I had more time. The equation is equivalent (with extraneous solutions) to [itex]x^4 + 48x^3 +536x^2 -956x + 372=0[/itex]. This quartic has no rational roots (the rational roots theorem gives ±1, ±2, ±3, ±4, ±6, ±12, ±31, ±62, ±93, ±124, ±186, ±372, but none of these are zeros. I have shown that all real zeros lie in (-62, 2), but this is as far as I have gotten. What is the next step after the Rational Roots Theorem (RRT) has failed to find a root?
Thanks!
Mathematics news on Phys.org
The quartic formula! Didn't you learn it in school? :p
For many purposes, the best way to represent a root in this situation is something of the form:
r is the root of [itex]x^4 + 48x^3 +536x^2 -956x + 372=0[/itex] between 0.6 and 0.7​
Incidentally, I plugged your original equation and your quartic equation into wolframalpha and the solutions don't agree -- you've made an error in arithmetic or in transcription. (although correcting your arithmetic won't make things any easier)
The original equation, [itex]-\sqrt{7-x} = -\frac{x^2}{2} + 12x - 10[/itex] has two solutions, at x1≈0.996 and x2≈-25.242, but the quartic has two extra solutions: at x3≈0.607 and at x4≈-24.361. These last two are extraneous solutions, but x1 and x2 are also solutions of the quartic.
I'm pretty sure that the original equation has just one real solution. Write it as:
[tex]\sqrt{7-x} = \frac{x^2}{2} - 12x + 10[/tex]
and it's clear that the LHS is the upper half of a sideways parabola, with domain [itex]x \leq 7[/itex], while the RHS is a vertical parabola with axis of symmetry [itex]x=12[/itex]. Therefore, where the domains overlap both curves are monotonic. So there is only one real solution.
BTW. Fixed point iteration of [itex]x = \frac{1}{12} (0.5*x^2 + 10 - \sqrt{7-x} )[/itex] gives this solution at about 0.640259457069546.
Your comment about one solution threw me off. We had gone over the problem (graphically, of course) in class, and there were two solutions. I then noticed that I had typed the wrong equation, and simply copied it from my first post. I switched the signs:
[tex]\sqrt{7-x} = \frac{x^2}{2} + 12x - 10[/tex]
should be correct. Wolfram Alpha confirms that there are two zeros here. Regardless of the signs, how would I find these solutions algebraically, without relying on the quartic formula?
Thanks!
drewfstr314 said:
Your comment about one solution through me off. We had gone over the problem (graphically, of course) in class, and there were two solutions. I then noticed that I had typed the wrong equation, and simply copied it from my first post. I switched the signs:
Thanks!
Yes obviously that changes things. The axis of symmetry of that parabola is x = -12, so that it is now possible for the [itex]\sqrt{7-x}[/itex] curve to intersect with both "sides" of the parabola (I haven't checked that it actually does, but will take your word for it). With the previously given equation however, this was simply not possible. :smile:
  • · Replies 18 ·
  • · Replies 0 ·
9K
