pardesi
- 337
when we say the current through a wire is uniform and is I what do we mean
The discussion focuses on the concept of uniform current distribution in a wire and the definition of surface current density as described in Griffith's textbook. It establishes that when current I is uniformly distributed, each half of the wire's cross-section carries I/2. Surface current density K is defined as K = dI/dl_{p}, where dl_{p} is perpendicular to the current flow. The conversation emphasizes that the ribbon analogy used for visualization does not affect the local property of surface current density, which is a vector quantity representing current flow direction and magnitude.
PREREQUISITESStudents and professionals in electrical engineering, physicists studying electromagnetism, and anyone seeking to deepen their understanding of current distribution and surface current density concepts.
olgranpappy said:The answers to the question of definition can be found in any textbook. I would suggest that you look in the appendix of Griffith's--maybe under "surface current" or "current, surface"?
griffith said:consider a "ribbon" of infitesmal width dl_{p} running parallel to current flow and let the current through this be dI then we define surface current density K as K=\frac{dI}{dl_{p}} where dl_{p} is taken perpendicular to current flow
Surface current denslity is current per unit width of Griffith's ribbon, sopardesi said:well what i don't understand about this is why should we take a 'ribbon' isn't a small width enough to define .also if a take a width then the current flowing across it in general would depend on the ribbon length
pardesi said:well he says and i quote
