Where Can I Find Reliable Paper Publishing Advice?
  • Thread starter Thread starter exmarine
    Paper Publishing
The discussion revolves around the challenges of publishing a paper in the fields of general relativity, frame dragging, and dark matter, particularly for individuals without academic connections or formal credentials. Participants explore potential journals, the importance of background research, and strategies for gaining feedback on their work.
  • One participant expresses a desire to publish a paper but feels unqualified due to a lack of academic connections and credentials.
  • Another suggests reading relevant journals and articles to identify appropriate publication venues and emphasizes the importance of understanding the field before submitting work.
  • A different participant shares their own experience of writing a paper and the challenges of finding an audience, noting the potential for publishing on platforms like ResearchGate.
  • Some participants recommend reaching out to researchers in the field for feedback on the paper and advice on suitable journals.
  • Concerns are raised about the adequacy of available reading materials, with one participant noting limited access to technical libraries and reliance on textbooks and arXiv papers.
  • Questions are posed regarding the necessity of testable hypotheses in the work and the costs associated with publishing in reputable journals.
Participants do not reach a consensus on specific journals to target or the best approach to publishing. Multiple viewpoints on the necessity of extensive background research and the feasibility of reaching out to established researchers are presented.
Some participants highlight the potential issue of predatory journals and the need for rigorous peer review, while others mention the importance of understanding the existing literature to inform their own work.
Individuals interested in publishing research in physics or related fields, particularly those without formal academic backgrounds or connections.
exmarine
Summary:: I would like to write a paper about a subject germane to this forum,...
I would like to write a paper about a subject germane to this forum, i.e., general relativity, frame dragging, dark matter, etc. I have no connection to any academics, so I don’t know and can’t ask anyone what journals might be appropriate. Also I have no “credentials” and will automatically be assumed a crack-pot. (A perfectly understandable policy considering some of the stuff I have seen on the web!) Can anyone suggest how to go about this, what journals I might try – specifically ones with competent and rigorous reviews before publishing?
Thanks.
Thanks.
There are several Insights articles that will give you some information, like this one:
https://www.physicsforums.com/insights/guide-publishing-peer-reviewed-journals/
Watch out for predatory journals -- they will take your money and provide very little value. Also, you should be reading the journals that publish similar papers to what you want to publish. And you should be reading the papers and the references in those papers to understand the field better. If you are not doing that reading, it's probably a bad idea to pursue trying to send anything in for review, IMO.
Do you have a local technical library that carries such journals?
Thanks.
To be honest: there is not much hope. We have a couple of articles about the problem in our insight blog section, so maybe you can find some advice there.
https://www.physicsforums.com/insights/?s=publish
I have a similar problem. I'm currently writing a paper - well, no paper, mainly just the formulas, the texts must still be included - which could serve well as either a master thesis or a paper. It is about a part of mathematics which is very likely not found anywhere else. I even know a professor in Vienna who might be interested in the ideas or just take it as a suggestion for one of his students to elaborate it, or simply check for errors. His father was a professor of mine. It is itself not suited as an insight article on PF as it is presumably not of general interest. However, it's long ago that I finished my study at university, so chances that it will ever be read are close to zero. Nevertheless it makes fun to think about and write down the results. At the end I might publish it on (worthless) researchgate. It's a bit of a pity as it is really new stuff. But, so what. At least it makes fun and smaller parts serve as questions in our math challenge threads.
That shouldn’t be a problem. Since you don’t have formal training in this area then you will need to “double down” (or even triple) in your reading of the relevant scientific literature. Keep detailed notes of what you read and key insights from each paper (not necessarily the point of the paper but what you individually learned from it).
As you do that you will find that most of the papers come from a few journals. Those are your target journals. You can either choose the one that you used the most or you can choose the most prestigious (highest impact factor)
Why not email your paper to some of the people working on these topics. They'll give youfeed back and advice where to send it.
Thanks for the responses! But no I do not have access to a technical library. The nearest one (UVA) is about 100 miles away, I am retired and have to take care of an ailing spouse. So I do not even know what journals are out there, much less have any familiarity with their contents, styles, etc. The only reading materials I have are the many textbooks I have bought from Amazon and the papers I can find on arXiv.
I thought about sending it to Zee since a section in his book is what sparked the idea. But I hate to pester those busy guys. Although I did send an email to Milgrom (‼) some time ago on a different subject and got a very gracious response. A problem with sending this paper to him is that it argues counter to his MOND theory. Or maybe that would be a good reason to send it to him. I suspect he might vigorously oppose it if he has the time to read it.
So no specific journal recommendations based on the subjects of general relativity, astrophysics, etc.?
PS. Do the reputable journals charge the authors fees for publishing?
Does your work contain testable hypotheses? If so, how expensive would it be (in dollars or energy from the grid) to conduct those experiments?
That probably won’t be enough background research to produce anything publishable. You can’t think outside the box if you don’t even know what is in the box. But when you are reading arxiv be sure to at least pay attention to which journal the article is actually published in. That might be enough to get you a few journals (instead of a whole library) to get access to and consider.
  • · Replies 61 ·
14K
  • · Replies 25 ·
9K
