Where Is the Center of Mass of a Leg?
The center of mass for a leg, considering the thigh, shank, and foot, is calculated to be at coordinates (2.5, 3). The individual coordinates for each segment are (2.7, 3.2) for the thigh, (2.1, 2.5) for the shank, and (1.5, 1.9) for the foot, with respective masses of 9.6 kg, 2.9 kg, and 0.9 kg. The calculation involves determining the torques for each segment based on their mass and position, leading to a total torque of 33.39 for the x-coordinate and 39.68 for the y-coordinate. Dividing these sums by the total mass of 13.4 kg yields the final center of mass. Understanding the process of calculating torques and applying it to the center of mass in two dimensions is crucial for accurate results.
epuen23
The center of mass of someone's thigh, shank, and foot are located at the following coordinates:
Thigh: (2.7, 3.2)
Shank: (2.1, 2.5)
Foot: (1.5, 1.9)
If the masses of them are respectively 9.6, 2.9, and 0.9 kg, where is the location of the entire leg?
ANSWER:
CM = (2.5, 3)
CMx = Xprox + L%*(Xdist - Xprox)
CMy = Yprox + L%*(Ydist - Yprox)
CMbody = E*(CMseg*Mseg)/Mtotal
Thigh: (2.7, 3.2)
Shank: (2.1, 2.5)
Foot: (1.5, 1.9)
ANSWER:
CM = (2.5, 3)I'm having trouble figuring out the steps for this. I feel like I need to know the Length % in order to complete the formula but am lost as to how to get this. Thank you for any help you may be.
-E
Please define the parameters in your equations.
I hope this helps.
I was having a hard time uploading screenshots of the equations/problem. I think I got it to work now.
So in the bottom of the screenshot, it talks about calculating the torques for each segment. Do you know how to do that?
Think about a simpler problem, like a 1 dimensional bar with weights attached at different points. How would you find the center of mass? Now how would this be expanded to 2 dimensions?
So I know T (Torque) = F (Force) * ⊥d (Perpendicular Distance).
Would it be: 2.7 * 9.6? Am I even close?
Yes, you're on the right track.
Oh my gosh, thank you so much guys!
X
2.7 * 9.6 = 25.92
2.1 * 2.9 = 6.09
1.5 * 0.9 = 1.35
SUM OF TORQUES = 33.39
DIVIDED BY SUM OF MASS = 13.4
33.39 / 13.4 = 2.5
Y
3.2 * 9.6 = 30.72
2.5 * 2.9 = 7.25
1.9 * 0.9 = 1.71
SUM OF TORQUES = 39.68
39.68 / 13.4 = 3
Likes scottdave and Chestermiller
