Where is the edge of the universe
  • Context: Graduate
  • Thread starter Thread starter Adrian07
    Edge Universe
The discussion centers on the concept of the universe's edge, presenting three primary theories: the observed edge at approximately 50 billion light-years, the expanding universe theory, and the no-edge scenario. Participants argue that the universe lacks a physical edge, as it is expanding uniformly in all directions without a defined boundary. The consensus suggests that while the observable universe has limits, the universe itself may be infinite, rendering the notion of an edge meaningless. Theories such as the balloon analogy are referenced to illustrate the expansion of space without an external boundary.
  • Understanding of cosmological concepts such as the Big Bang and observable universe.
  • Familiarity with the expanding universe theory and its implications.
  • Knowledge of redshift and its role in measuring cosmic expansion.
  • Basic grasp of spatial geometry, particularly concepts of edges and boundaries in a cosmological context.
  • Research the balloon analogy in cosmology to better understand the expansion of the universe.
  • Explore the implications of redshift in measuring the universe's expansion.
  • Study the concept of the observable universe and its limitations in understanding the cosmos.
  • Investigate various cosmological models, including the standard model of cosmology (LCDM).
Astronomers, cosmologists, physics students, and anyone interested in the fundamental nature of the universe and its expansion.
  • #61
The CMB is depicted using Mollweide projection, which is a way of mapping a spherical surface onto a flat sheet of paper. The resulting image is egg shaped.
Space news on Phys.org
  • #62
Adrian07 said:
How can a universe expanding out from a singularity...
AFAIK this notion is erroneous, it implies that the Big Bang was an explosion in pre-existing space. If this was so we would be able to identify a centre but no matter where you are in the universe if you try to do this you end up measuring yourself as the centre. This is because the Big Bang happened everywhere at once as strange as that sounds. Perhaps someone more knowledgeable can explain this better.
  • #63
Ever tried to make a mobius tube? You get a torsion factor that is hugely complicated to model.
  • #64
mfb said:
What you see is a projection of the whole sky on a surface (paper, or a computer screen). This does not work perfectly, and the problem is similar to the issue how to make a map of earth: you need a globe to do it right.
So, our Universe (at least observable one) is a nicely formed sphere (it's not flat and it's not ellipse)?
  • #65
Ryan_m_b said:
... no matter where you are in the universe if you try to do this you end up measuring yourself as the centre. This is because the Big Bang happened everywhere at once as strange as that sounds.
I can 'visually' explain this to myself only if I 'imagine' more dimensions than those we are able to perceive, and that Big Bang and expansion of Universe has to do with changes within dimensions (their 'relation'; maybe Big Bang was an event where other dimensions curved into themselves and became very tiny, what is what String Theory is saying I guess, possible?).
Yes, please. The more explanations the better.
  • #66
The "edge"of the universe could well be in the very fundamentals of the nature itself(Which we don't comprehend yet)I believe no one is able to answer this question ; "yet"!
I found this interesting:
  • #67
The observable universe is so flat that experiments could not observe a curvature yet. If the universe is curved, then the scale of that is really large.
That is unrelated to the graph of the CMB, however. Independent of the curvature, you can look in all directions in the sky.
  • #68
OK thanks, I think I get it a bit better now. Though, if most consider that whole (not just observable) Universe is infinite then there is nothing strange if the scale of curvature of observable Universe is really large, right?
  • #69
If the whole universe is in fact infinite, then it is almost certainly flat and the fact that we measure the observable universe as almost flat and only within the tolerance of our ability to measure it will just turn out to be a lack of accurate measurement.
  • #70
In regards to that last question. You have it right. However the universe can be so big that even a finite universe would look flat in the observable portion.
If the South pole data on the curvature proved accurate. They calculated that a photon would take 880 billion years to cirmumvent the universe if and only if expansion were to stop.
At current expansion rates that photon may never be able to transverse the universe.
Keep in mind the above applies only if the South pole data is correct on the universe being finite.
  • #71
I'm currently taking an Astronomy class (I'm a high school senior so it's not a very in-depth class) and this question comes up a lot. After thinking about the "edge of the universe" for a while, I came to a conclusion and "answer" that makes logical sense to me (although my teacher seems confused when I try to explain it to him). I personally don't understand the confusion but I will share my view on the "edge" problem... Again I'm no Physicist so please don't assume that I'm giving (or trying to give) the "correct" answer. The "correct answer" I feel could never really be found (at least not for many lifetimes) due to the distance and speed one would have to travel to find (or not find) an "edge". Anywho, here it goes;
Imagine a central point in the middle of a piece of paper. The piece of paper representing all of spacetime and this "central point" will be the "singularity" that is the big bang before expansion. At the point of expansion (the expansion of the matter and energy inside of the singularity), the matter and energy will begin to move across spacetime (time starts here) and keep moving forever or until the expansion rate slows enough for gravity to bring it all back in on itself. Now, you draw a circle (doesn't necessarily matter how large or small because this is purely a visual to make sense of it) around the "central point". This circle represents the current expansion in age and in space (how far the expansion has moved across spacetime). Outside of that circle is the future and therefore we can only reach it when the expansion has reached it. You cannot "go over" that "edge" unless you go into the future. I personally think that the Science-Fiction idea of "jumping into the future (or the past)" is silly, but that is debatable and isn't the point of my example so I digress. As far as the present goes, what is on the other side of the "edge" (besides the future) doesn't matter because you will never reach it outside of waiting until the future is here. Unless you could go faster than the expansion rate and faster than light, but that just isn't possible... as far as we know any who, but I like to think that Einstein was correct. If you try to vision an "edge" that is purely physical (does not include time in the "spacetime"), you will find yourself confused and frustrated trying to understand it. This is because the other side of that edge must be "nothing" otherwise it would be included in the "universe", and "nothing" doesn't make sense to current-human logic. For this reason, I find that one should include the "time" in "spacetime" to make more sense of it. Of course, there are multiple ways to think about the "edge" problem so, just accept the one that makes the most sense to you (even if someone claims that it "makes no sense" or is "wrong").
If I did not make myself clear, feel free to ask questions. Again, this is just my thought on the whole shibang so don't quote me as claiming to have the perfect answer or any of that jazz... I am not a Physicist, and I like to think that I'm not that arrogant.
  • #72
I don't think your model is possible in General Relativity.
  • #73
Just throwing this out there, but is it not logical to think that the big bang would have projected matter out in all directions? Creating a 360 degree universe? Also is it not logical to think that the universe is a sphere but it's just so so big that even with our most poweful telescopes we can not see the horizon... Because the universe is expanding faster than the speed of light, light can not make a full circle and come back to us.
If the universe was not expanding, eventually light would complete a full circle. I think the curve is just so small and the universe is expanding faster than the speed of light so we can never see the horizon. It's just getting further away with every passing second.
  • #74
Others more knowledgeable can answer this well. I'd just like to say that if expansion stops all light will eventually reach us (later than sooner I guess) and (future) we might see birth of Universe :-)
  • #75
You apparently believe that the big bang happened at a point. That is the first misconception that is thrown out in cosmology 101. I suggest you read some actual cosmology before you start postulating things that don't make sense.
  • #76
We ALREADY see as far back as we are ever going to see in the visible spectrum. Google "surface of last scattering".
  • #77
Randomtask94 said:
Imagine a central point in the middle of a piece of paper. The piece of paper representing all of spacetime and this "central point" will be the "singularity" that is the big bang before expansion. At the point of expansion (the expansion of the matter and energy inside of the singularity), .
To get a better picture. I would suggest that you crumple the paper(spacetime) instead of having a dot and compressed it as much as possible until you create a condensed ball of paper of some sort. What you have now is a GUP but before that. Imagine that weird condensed ball appear from 'something'.(Quantum Fluctuation). We move 2 step forward. That ball of condensed paper rapidly inflate and after that at some point gradually expands.
We can't identify any edge since we only have the paper as everything so far(not some paper within a given space/room/table and so on, etc).^^
  • #78
I have been contemplating the expanding universe theory with regard to the edge of the universe. As far as I am aware this theory resulted in the fact that if all motion in the universe was reversed then all would come together at a single point somewhere, which at that time would have been the whole universe.
If all started at a single point, and assuming time is imagonary i.e. just the rate of change, then the edge would now be 13.7blys away from that point. Using a simple diagram you can see that the oldest part of the universe would be at the center with age reducing as you move outwards. There are 2 problems with this picture 1 unless viewed from the center the universe would appear lop-sided regarding the age of what is seen 2 the furthest you could see would be half the age of the universe in light years. This picture puts everything inside an expanding circle looking towards the edge. This is what we appear to see but we do not see a lop-sided universe and we can see further than 7blys.
If time is real, being discussed in another thread, then a universe expanding in time and space should produce something closer to what we actually see, the universe would look the same in all directions and we would be able to see almost to the beginning, but would put us on the edge of the circle looking in which would put the edge of the universe not in space but just in front of us in time, strange as that might sound.
Of course if what I have read regarding the expansion of the universe from its beginning is incorrect then I will have to think again.
  • #79
I think it is possible to see the birth of the unvierse in the futre, but it won't be via light or by the universe's expansion for the reason phinds pointed out. But there are two types of radiation that can penetrate the surface of last scattering.
1 neutrinos , these could take us back to about 2 seconds after the big bang.
2 gravity waves, these could go even earlier and some have suggested even before the big bang itself.
The technology needed for this is not going to happen in the next fw years in my opiion, it's somewhat scifi but it is not impossible.
  • #80
As I believe has been pointed out to you in other threads, this is complete nonsense and is most emphatically NOT believed by any serious cosmologist.
  • #81
AAARRRRRHHHH ... I understand what you are saying and I am NOT saying it is wrong, I just find it unfortunate that because of your wording it is possible to interpret what you have said as being that you support the point of view that the big bang was an explosion from a single point in space.
I am NOT saying that that's what you said (I see that it isn't), I'm just pointing out how you've left it open to misinterpretation.
  • #82
:smile: Don't you love the singularity misconceptions Phinds? To be serious the size of the universe at the beginning is an unknown size, the singularity in this case is simply a point where the maths no longer work.
  • #83
Sorry if your analogy were true we would have a preferred direction, that preferred direction would be towards the center. Expansion would have different rates depending on which direction we look. Large scale structures would form at different points depending on which direction we look.
None of this occurs, there is no preferred direction. Expansion occurs the same regardless of which direction we look. This discounts the possibility of expansion radiating outward from a central point regardless of the size of that central point.
  • #84
Yeah ... I had the same problem when I started looking at cosmology, so it doesn't bother me that others have that misconception, what BOTHERS me is that some of them just hang on to it and hang on to it and hang on to it ...
So anything that helps them hang on to it also bothers me, thus my response to julcab12 who made a perfectly valid analogy that just had the unfortunate problem of being overly susceptible to misunderstanding.
  • #85
Part of the problem there is there is tons of pop media you-tube videos etc that describe it in just that manner. Some of the worse is the ones that imply some form of "God particle (used to represent GUT). Those are the ones I truly hate. Especially considering You tube is a popular source of information for those wishing to learn cosmology
  • #86
Haha. Well. I failed, should have used better wording. Dilemma of oversimplification.
  • #87
Has anybody brought up the bubble theory within the multiverse theory? How about the 11-dimensions creating the possibility of all possibilities within eleven dimensions? That would assume infinite space and time, if not in our three dimensional universe.
  • #88
I suspect that no one has brought those up because this forum is for the discussion of actual science, not totally unproven speculation.
  • #89
That's mostly fair, and I CERTAINLY won't argue the bubble universe, but I believe that the 11- dimensions come from the mathematical models from the string theory? Again, I know very little about this topic and I apologize for the pseudo-science
  • #90
String theory holds HUGE promise but there are two problems.
1) It has held that promise for over 20 years and has gone nowhere. LOTS of very smart people have spent huge amounts of time on it, because of the potential, but it has gone nowhere.
2) There is exactly zero empirical evidence for it.
EDIT: by the way, I don't mean to imply that string theory is not a valid topic for this forum but extending it to cosmology as you did is WAY premature.
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 34 ·
  • · Replies 42 ·
