Where should mass B be placed for rotational equilibrium?
  • Thread starter Thread starter bmandrade
    Equilibrium Torque
11 replies · 6K views
bmandrade
On a seesaw, Mass A is 60 kg, mass B is 30 kg, and mass C is 10kg. Mass A is 1.0 m from the piot and mass C is 3.0 m from pivot. Calculate torques of mass A and C about the pivot. Where should you place mass B in relation to the pivot for the system to be in rotational equilibrium
The seesaw is at an angle of 30 degrees from the horizontal. Mass A is on the left side and Mass C is on the right side
torque = rFsin [tex]\Theta[/tex]
I found the torques but i don't know if they are right
mass A (g=9.8m/s2)
[tex]\tau[/tex]=(1)(60g)sin 30 = 294 N[tex]\cdot[/tex]m
mass C
[tex]\tau[/tex]=(3)(10g)sin30 = 147 N[tex]\cdot[/tex]m
then I tried to find where to put mass B
[tex]\tau[/tex]mass A+[tex]\tau[/tex]massB+[tex]\tau[/tex]mass C= 0
i don't know if i should use this equaiton of soemthing else to find where to place B
I got the equationn from the book since for the force what is need is the component on the horizontal
so in that case i don't need the angle because even those there is an angle in the seesaw the force is not being applied at an angle
Well, basically there are two things going on:
1. You don't really need the angle because every term in the torque equation has the same angle factor, so these can be canceled out of the equation.
2. You were using the wrong angle dependence when you calculated the torques, but that doesn't really matter (see 1).
So let's get back to the problem ...
Mass A is on the left, so we could say that it is located at -1.0m from the pivot (note the - sign)
Mass C is to the right, so it's located at +3.0 m.
Can you set up the torque equation you wrote before:
τABC= 0
using what you know about the masses and positions of A and C? You may leave out the angle sin and/or cos stuff.
oh ok it makes sense
so now that everything is clear
I set up the equation
-1(60g)+3(10g)+ τc=0
-588+294 + τc= 0
r F = 294
r (30g) = 294
r = 1
(g = 9.8)
this means that mass B must be place 1 m away from the pivot ( same side as mass C) to have no net torque in the system
