Where should mass B be placed for rotational equilibrium?
  • Thread starter Thread starter bmandrade
    Equilibrium Torque
The discussion revolves around a seesaw problem involving three masses (A, B, and C) and their positions relative to a pivot point. The objective is to determine where mass B should be placed to achieve rotational equilibrium, considering the torques produced by the other two masses at a specified angle of 30 degrees from the horizontal.
  • Participants discuss the calculation of torques for masses A and C and question the relevance of the angle in the torque equation. There is exploration of how to set up the torque balance equation for equilibrium.
Participants have clarified the relationship between the angle of the seesaw and the torque calculations. Some have suggested that the angle may not need to be explicitly included in the torque equation, leading to a more straightforward approach to finding the position for mass B.
There is a lack of visual representation of the seesaw setup, which has led to questions about the arrangement of the masses and the angle's role in the torque calculations. The discussion also reflects uncertainty about the correct interpretation of the torque equation in relation to the angle of the seesaw.
bmandrade
On a seesaw, Mass A is 60 kg, mass B is 30 kg, and mass C is 10kg. Mass A is 1.0 m from the piot and mass C is 3.0 m from pivot. Calculate torques of mass A and C about the pivot. Where should you place mass B in relation to the pivot for the system to be in rotational equilibrium
The seesaw is at an angle of 30 degrees from the horizontal. Mass A is on the left side and Mass C is on the right side
torque = rFsin [tex]\Theta[/tex]
I found the torques but i don't know if they are right
mass A (g=9.8m/s2)
[tex]\tau[/tex]=(1)(60g)sin 30 = 294 N[tex]\cdot[/tex]m
mass C
[tex]\tau[/tex]=(3)(10g)sin30 = 147 N[tex]\cdot[/tex]m
then I tried to find where to put mass B
[tex]\tau[/tex]mass A+[tex]\tau[/tex]massB+[tex]\tau[/tex]mass C= 0
i don't know if i should use this equaiton of soemthing else to find where to place B
Where does the 30 degrees come from? We can't see the figure, if there is one, or on which side of the pivot masses A and C are located.
Okay.
There is a problem here. Yes, the angle of the seesaw to the horizontal is 30 degrees. But what is the angle θ in the equation:
torque = r F sinθ ?
I got the equationn from the book since for the force what is need is the component on the horizontal
Check the book formula and discussion again, what exactly does it say that angle is?
Hint: if the seesaw were exactly horizontal then the forces are vertical and still exert a torque, even the the horizontal force component is zero.
so in that case i don't need the angle because even those there is an angle in the seesaw the force is not being applied at an angle
Well, basically there are two things going on:
1. You don't really need the angle because every term in the torque equation has the same angle factor, so these can be canceled out of the equation.
2. You were using the wrong angle dependence when you calculated the torques, but that doesn't really matter (see 1).
So let's get back to the problem ...
Mass A is on the left, so we could say that it is located at -1.0m from the pivot (note the - sign)
Mass C is to the right, so it's located at +3.0 m.
Can you set up the torque equation you wrote before:
τABC= 0
using what you know about the masses and positions of A and C? You may leave out the angle sin and/or cos stuff.
oh ok it makes sense
so now that everything is clear
I set up the equation
-1(60g)+3(10g)+ τc=0
-588+294 + τc= 0
r F = 294
r (30g) = 294
r = 1
(g = 9.8)
this means that mass B must be place 1 m away from the pivot ( same side as mass C) to have no net torque in the system
Yes. You got it :smile:
thank you! :)
19K
13K
  • · Replies 30 ·
