Which bolt should be used for a beam support with different yield strengths?
  • Thread starter Thread starter engtobe
The discussion centers on selecting the appropriate bolt diameter for a beam support, considering differing yield strengths of the bolt and the supporting plate. The user calculated two diameters based on shear strength and a constant load, noting that the plate's lower shear strength necessitated a larger bolt diameter. The consensus is that the design of a bolted joint should prioritize the yield strength of the bolt itself, rather than the material being bolted, unless specific geometric stress limitations apply.
  • Understanding of shear strength calculations
  • Knowledge of yield strength concepts
  • Familiarity with bolted joint design principles
  • Experience with structural engineering materials
  • Research bolted joint design standards and guidelines
  • Learn about the effects of geometry on stress distribution in bolted connections
  • Explore material selection criteria for structural components
  • Study the differences between shear strength and tensile strength in materials
Structural engineers, mechanical engineers, and anyone involved in designing bolted connections in construction or machinery.
engtobe
I have calculated two diameters of a bolt to be used in a beam support using a plate at each side supported in a cradle with a hinge pin.
i used shear strength and a constant load to find the diameters the reason i have two different diameters is because the plate and bolt have different yeild strengths
the plate has the lower shear strength and resulted in a bigger diameter of bolt.
what bolt should be used?
thanks for any answers
You design a bolted joint per the yield strength of the bolt, not the material it's bolting (unless the geometry has stress-limiting factors).
nice one mate
  • · Replies 36 ·
  • · Replies 22 ·
9K
