Which car has greater momentum at the cliff's edge?
In the discussion regarding the momentum of two cars at the edge of a cliff, it is established that Car 1 (HC), which has twice the mass of Car 2 (TLC), will have greater momentum when both cars are subjected to equal and constant forces over the same distance. The key equations used are Impulse = force x time and Momentum = mass x velocity. Since Car 1 accelerates more slowly due to its greater mass, it experiences the applied force for a longer duration, resulting in a higher final velocity and thus greater momentum compared to Car 2.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of momentum and impulse
  • Basic knowledge of kinematics, specifically acceleration and velocity
  • Ability to apply mathematical equations related to force, mass, and motion
  • Study the relationship between force, mass, and acceleration using Newton's Second Law
  • Explore the concept of impulse and its effect on momentum in different scenarios
  • Learn about kinematic equations to calculate final velocities in motion problems
  • Investigate real-world applications of momentum in vehicle collisions and safety design
Physics students, educators, and anyone interested in understanding the principles of momentum and motion in mechanics.
deanine3
Two cars are initially at rest on a horizontal parking lot at the edge of a steep cliff. Car 1 (HC) has twice as much mass as car 2 (TLC). Equal and constant forces are applied to each car and they accelerate across equal distance to the cliff. WE ignore the effects of friction. When they reach the far end of the lot, the force is suddenly removed, whereupon they sail through the air and crash to the ground below. Which car has the greater momentum at the cliff's edge?
Impulse= force x time
Momentum= mass x velocity
Since velocity is a factor of momentum, I would need to figure out the acceleration? However, I don't see that there is enough information to do that. My guess is that since car 1 has twice the mass, but the same force and time, it has more momentum. Car 2, has 1/2 the mass of car one, but the same force and time, so less momentum? This looks right. Anyone know for sure??
You are correct that the change in momentum equals the force multiplied by the time the force is applied. So, to which car is the force applied for a longer time? That is, which car takes longer to cover the same distance?
That will answer your question. On the other hand, unlike what you wrote, mass certainly does enter the definition of momentum: p=mv.
The same force is applied to both cars for the same amount of time. With that being said, since I don't know the velocity, do I assume that since car 1 has twice the mass, it therefore has twice the momentum??
I guess, I'm not sure how to find the velocity without the information necessary; direction and speed. help please. I know this is probably easy but it is overwhelming to me!
No, the force is not applied for the same time, but over the same distance.
The final velocities of the two cars will not be the same...
Maybe I'm starting to understand, since car 1 has twice the mass therefore, twice the inertia. It has the equal and constant force applied for a longer time period because it is slower to accelerate than car 2, with 1/2 the mass? Therefore, car 2, with half the mass, would have a greater velocity. So, even though the force applied is equal and constant, it is only until the cars reach the end of the cliff? Which will be faster for car 2.
That's right! So, car 2 experiences the same force for a shorter time. Hence...
So, car 2 has less momentum and car 1 has more momentum!
Alrighty!
Thank you for your help! I REALLY appreciate it. I am envious of your understanding of this foreign language.
It took many years :-)
  • · Replies 17 ·
