Which Direction Do You See the Dancer Spin?
  • Thread starter Thread starter PlasmaSphere
    Brain Test Visual
40 replies · 26K views
PlasmaSphere
this is supposed to be visual test on if you are mainly left brained or right brained, it a woman spinning around a point, and if you see it spinning clockwise, you are right brain, if you see it anticlockwise, you are left brained.
It nearly always goes right for me. I'm not sure how accurate is is, i just want to see if people are divided evenly, or if most people see it going clockwise aswell.
check it out; http://info.break.com/static/live/v1/pages/brain/brain.html
what are you, left or right?
I see her spinning counter-clockwise. I am unable to see her spinning any other direction. Can you manage to see her spinning in either direction?
This experiment says I'm left-brained. That's a shocker to me.
According to the result I'm anencephalic.
Sorry. I skewed up the test. Or however you spell it.
Hmm, when I look at her in my peripheral vision she begins to spin clockwise. As soon as I focus on her she spins counter-clockwise. Interesting.
Ok, I can already make her spin either direction at will. That didn't take long.
I wonder if she is single.
it's funny they used a nude 'attractive' woman for the test
I can see it either way
She spun clockwise first, and then started doing it the other way.
I just saw this two days ago.
And it seriously freaked me out.
Because it's both. I'm guessing conflicting signals are both being sent in my brain at the same time.
Also, sometimes it seems like she's oscillating in a way like a vibration.
I also immediately got the idea to try control her spinning, and had some success.
IT would be even more unusual if they used a generically unattractive figure. At least I find this one pleasing to focus on.
Perhaps that explains so many right brain tendencies. The subject matter might offset the results.
If I stare consistently at the image it is difficult for me to change her direction. If I close my eyes for about 2 or 3 seconds and think about an object spinning clockwise, then open my eyes, she is almost always spinning that direction, and vice versa.
I believe the idea was to make her similar to a ballerina. i.e. skintight, spinning
She shifts from clockwise to counterclockwise and back every 15 seconds or so. I consider myself to be equal parts left and right brained. My wife brained me left and right too when she caught me staring at the nude woman.
I hope at least you invited her to take a peek also. Tell her it will turn into David HAsselhof or something.
I just wonder how much of interpreting 'which way' she spins has to do with it be an attractive nude (esp. in men looking)--for the left or right brain.---like Huckleberry states.
--ballerina in skin tight tights?---yeah--sure!
Your left brain is your analytical, logical, rational brain. It is also the one that controls the right hand. Most people are left-brained.
You right brain is the fluffy one.
That's not the figure of any ballerina I've seen.
It started couter-clockwise for me, so I'm apparenly left brained, but I figured out how to make it switch directions on will.
The picture just changes direction every so often, its random. I was staring at it for 5min, then it changed, so I opened two different browsers that generated the pictures at different speeds and looked at both at the same time, one would spin one way, the other, the other way, and moved the browsers to opposite sides as well.
Nevermind, everytime I look down and up again, it changes, so weird. Its like changing with my eyes, like I am using my mind to change the direction.
Really? I just change the direction by realizing that every path is actually the other direction in a different stage of the rotation.
Yeah I saw her spinning right at first, then made her spin left...what does that mean??
I presume that means that your brain is about equal on each side, so one side is not dominant over the other, so it will switch depending on which side of the brain you are engaging when looking at it. There probably a technical term for it, i just don't know it.
Here's another funny aspect---when I watch her (not it) outside foot, she appears to spin counter-clock----------when I look at the area around the hips up to around the chest, she goes clockwise--------then when I look at the head area, she's back to spin counter-clock wise. I guess that sort of follows for me the different 'functions' on the left side of the page.
I spent so much time trying to figure out how it worked, that I can't remember which way I initially saw it spinning. I find its easiest to get it to switch direction if you pause it, and decide which way you want to see it. There is also a white line when her leg spins to the right, that, undoubtedly, when you pause it, he body is turning toward the left, (anticlockwise). Perhaps that's why it means attention to detail? The shadow also affects which direction it seems to turn, and makes it easier to watch it just bounce back and forth.
Anyway, I think its odd that you can see her nips... looks like a boob job.
Whoo, that's good to know...I thought I was half woman there for a minute! :smile:
I know. I have a great appreciation for my fluffy side, though I would use other adjectives for it. :smile: I was disappointed when I was, at first, unable to see her spin clockwise.
I see spinning both directions, but then I see the image stop and reverse in a oscillating peroidic semi-circular motion. Interesting.
I think the technical term you're searching for is "bullsh*t." :wink:
How about this one:
http://www.healthyeyes.org.uk/uploads/pics/necker_cube.gif
If you see the yellow side facing outward, you're left-brained. If it's inward, you're right-brained. If it switches, you have a brain tumor.
right. Which is false. I find it impossible to see her spin the other way no matter how long I look.
Counter-clockwise.
I can see her spin clockwise if I try, but she still drops back into a counter-clockwise rotation after a few seconds.
When I was a kid, I used to love those signs that would rotate 180 degrees and then reverse direction (it was hard to rotate something in the same direction forever because of cable wrap). You'd try to figure out which way the sign was rotating, but eventually realize it was just going back and forth.
How about this one:
I must have a tumor.
