Which has a greater Gravitational Energy?
The discussion revolves around comparing the gravitational energy and impact velocities of two objects, A and B, with different masses and heights. The objects are specified as A=500g at 2m and B=1.0kg at 1m, prompting questions about gravitational energy, impact velocity, energy storage in a spring, and spring compression.
  • Participants explore the calculations of gravitational energy using the formula Eg = mgh and discuss the implications of equal gravitational energy on impact velocity. Questions arise regarding the relationship between gravitational potential energy and kinetic energy, particularly how they relate to the masses and heights of the objects.
Some participants have provided calculations and expressed uncertainty about their correctness, particularly regarding the impact velocities. Others have suggested examining the conservation of energy principle and the independence of velocity from mass. The discussion is ongoing, with multiple interpretations being explored.
Participants are navigating through the implications of gravitational potential energy and kinetic energy, questioning assumptions about mass and height in relation to velocity. There is a noted lack of consensus on the interpretations of the energy equations and their applications to the problem at hand.
Hockey101
1. Imagine two objects, A and B, answer the questions that follow based on the conditions given.
A= 500g, at 2m, B=1.0kg, at 1m
a. Which has a greater Gravitational Energy? Why
b. If they are both dropped, which would have a greater velocity impact? Why?
c. If both are dropped onto a spring, which will store the greater energy?
d. Which will cause the spring to compress more?
2. Eg = mgh
3. a. A=(.5kg)(9.8 N/kg)(2m) = 9.8 J
B=(1kg)(9.8 N/kg)(1m) = 9.8 J
b. They would both have the same velocity because they both have the same amount of gravitational energy.
c. They will both store the same amount of energy.
d. Both springs would compress the same.
Hello everyone, I believe I did my calculations correct for part a, but I'm not positive about my answers on parts b, c, and d. Can someone tell me if I did this incorrectly? Thanks!
2. Eg = mgh
Your answer to a., I assume, is that they both have the same gravitational energy. You should state that. c. and d. are correct.
Your answer to b. is not correct. They both have the same kinetic energy just before impact. What is the expression for KE? (hint: it is in terms of mass and velocity). Work out your answer for v from that.
AM
So what you're saying is to use Ek=1/2mV^2? I do not understand how I am supposed to solve for EK (Kinetic Energy). If I want to find Ek, then I am missing the velocity component in order to figure out Ek. If I'm solving for velocity, then I'm missing the Ek piece. So I do not understand.And how do you know that they have the same kinetic energy?
Energy is conserved. There are only two forms of energy here: gravitational potential energy and kinetic energy. What a body loses in gravitational potential energy it gains in kinetic energy. You can also think of gravity as doing work on the body so the work done (Force x distance = (mg) x h) must equal the change in kinetic energy. So if it starts with 0 velocity (0 KE), you can determine its kinetic energy by: -ΔPE = -mgΔh = ΔKE = .5mv2 - 0. You can work out the speed, v, from that.
AM
I still do not understand...If PE (Gravitational Energy) and KE are equal to each other, then that means KE will equal 9.8J. Considering that both objects have 9.8J as their gravitational energy, then if I plug 9.8 J into KE, both objects come out to be 4.4 m/s. What am I missing?
Well, if you look at the equations a little more closely, you'll notice something peculiar.
Say you are given two different masses at two different heights like you are in this situation. Without using any numbers, you can see why these two things will not be going the same speed.
So, the maximum kinetic energy for both of these objects at different heights is basically when the height is zero, because all of your energy will then be coming from the kinetic energy alone.
Setting up your equations for two different objects of two different masses, you'll get:
$$m_{1}gh_{1} = 1/2m_{1}v^2$$
$$m_{2}gh_{2} = 1/2m_{2}v^2$$
Without plugging in any numbers, you might notice that your masses in both cases just end up cancelling out. So, what does this tell you? It tells you that ending the velocity after falling a certain distance is completely independent of the mass of the object, and has EVERYTHING to do with the specific height.
So, in your case,
$$v_{1} = \sqrt{2gh_{1}}$$ and
$$v_{2} = \sqrt{2gh_{2}}$$
This makes sense from a real world standpoint. If you were to drop two balls from the same height, but they both had drastically different masses, they would hit the ground at the same time if air resistance is not taken into account. In your result, it would make no sense
So if I plug numbers into those equations, Object A would be 6.26 m/s and Object B would be 4.43 m/s...making Object A with the higher velocity?
Yes.
  • · Replies 46 ·
  • · Replies 33 ·
