Which of the following are in R(T)?
  • Thread starter Thread starter ayh123
The discussion centers on the linear transformation T: R4 → R3 defined by T(x1, x2, x3, x4) = (4x1 + x2 - 2x3 - 3x4, 2x1 + x2 + x3 - 4x4, 6x1 - 9x3 + 9x4). The user attempts to determine which vectors are in the range R(T) and concludes that all provided vectors (0,0,6), (1,3,0), and (2,4,1) are indeed in R(T). The discussion clarifies that the range of T is R3, not the set of all real numbers, and emphasizes the relationship between the rank and nullity of the transformation.
  • Understanding of linear transformations and their properties
  • Familiarity with concepts of basis and dimension in vector spaces
  • Knowledge of row reduction techniques for matrices
  • Comprehension of the rank-nullity theorem
  • Study the rank-nullity theorem in detail to understand the relationship between rank and nullity
  • Learn about basis vectors and how to find them for different vector spaces
  • Explore row reduction techniques for solving systems of linear equations
  • Investigate the implications of linear transformations between different dimensional spaces
Students and educators in linear algebra, mathematicians working with vector spaces, and anyone involved in understanding linear transformations and their applications.
ayh123
Let T: R^4 ---> R^3 be the linear transformation given by the formula:
T(x1, x2, x3, x4) = (4x1+x2-2x3-3x4, 2x1+x2+x3-4x4, 6x1-9x3+9x4)
(a) (0,0,6)
(b) (1,3,0)
(c) (2,4,1)
Not sure what this means.. please skip to attempt at a solution
I have tried so many different ways, and it seems to me that all of these vectors are in R(T).
I tried finding the basis of R(T) by putting the coefficients into matrix (A), and row-reducing A to row echelon form, then noting the columns with the leading 1's in them, and matching them with the original A. So then I thought, all vectors in R(T) must be a linear combination of these 3 basis vectors and will satisfy r (4, 2, 6) + s (1, 1, 0) + t (-3, -4, 9) = (b1, b2, b3).
But all of them satisfy these conditions!
I also tried using the elementary vectors, or basis vectors for R^4.
I found the transformation images for:
T(1,0,0,0) = (4, 2, 6)
T(0,1,0,0) = (1, 1, 0)
T(0,0,1,0) = (-2, 1, -9)
T(0,0,0,1) = (-3, -4, 9)
Then I used the proposition that if the vectors span R^4, and it is a linear transformation, then T(vectors) span R(T).
I put the T(vectors) into a matrix and row-reduced. This gave me the 3 linearly independent vectors that are the basis of R(T) (or so I thought).
So then, all vectors in R(T) must be a linear combination of these vectors:
r (1, 1/2, 3/2) + s (0, 1, -3) + t (0, 0, 1) = (b1, b2, b3).
But all of those fit this formula!
A related question in the book actually does ask for the basis of the range, and since it is an odd-numbered problem, in the back, it gives this answer for a basis:
{(1, 0, 0), (0, 1, 0), (3/2, -4, 1)}
which is not what I got in either tries.
I bet you're shaking your head at how wrongly I did this problem. Please help clarify... thanks in advance.
Essentially you are asked to determine if a set of equations has a solution.
For example, (0, 0, 6) is in R(T) if and only if there exist (x_1, x_2, x_3, x_4) such that T(x_1, x_2, x_3, x_4)= (4x_1+x_2-2x_3-3x_4, 2x_1+x_2+x_3-4x_4, 6x_1-9x_3+9x_4)= (0, 0, 6). In other words, if and only if the equations
4x_1+ x_2- 2x_3- 3x_4= 0
2x_1+ x_2+ x_3- 4x_4= 0
6x_1- 9x_3+ 9x_4= 6
have at least one solution
Your method, however, of finding a basis for the range space is perfectly good- and faster. I see that you got three vectors for the basis. That means they span all of R3 and so, not just these but any set of three numbers, (a, b, c), is in that range.
Of course, a single vector space has many different bases. The fact that you happen to get a different one from what the book gives is not a problem.
Thanks for the clarification. Is this a common range for T - the set of all real numbers? Is there any way to gauge if that is the case without row reducing a matrix?
The range of T, here, is NOT "the set of all real numbers". It is all of R3. T here is from R4 to R3.
In general, R(T), where T is from an n dimensional space to an m dimensional space is a subspace of dimension at most n. It is also true that dimension of R(T) plus the dimension of the kernel of T (the "rank" and "nullity" of T, respectively) must be equal to n. Here, T is from a 4 dimensional space to a 3 dimensional space so the rank is at most 3 and nullity at least 1. But it is possible for the rank to be smaller than that.
Thanks. I knew real numbers wasn't right.. but couldn't think of a way to describe R^3.. set of real vectors in three dimensions? But I think the correct way to describe it is the set of all ordered triples of real numbers.
Wanted to clarify one more thing. You said, "In general, R(T), where T is from an n dimensional space to an m dimensional space is a subspace of dimension at most n." Do you mean "at most m"?
Thank you very much for your help!
  • · Replies 24 ·
