Which surfaces get positively charge by grabbing (static electricity)
The discussion centers on the principles of static electricity and the triboelectric effect, particularly regarding how different materials interact when charged. It highlights that certain materials, like balloons and hair, exhibit strong electron affinity, leading to static charge transfer. The conversation also clarifies that batteries, due to their low voltage potential, do not exhibit the same electrostatic attraction as charged objects like balloons. Additionally, it notes that the plastic casing of batteries acts as an insulator, preventing significant charge accumulation.
  • Understanding of static electricity principles
  • Familiarity with the triboelectric series
  • Basic knowledge of battery voltage and electrical potential
  • Concept of electrical polarization
  • Research the triboelectric series and its implications in material science
  • Explore the principles of electrical polarization in different materials
  • Study the effects of voltage potential in electrostatic applications
  • Investigate the role of insulators in electrical charge accumulation
Students of physics, educators explaining static electricity, and anyone interested in the practical applications of electrostatics in everyday materials.
danielhaish
So is it becouse the material or becouse the fact that the balloon is the object that moves and the hair is static. and does every two objects that been grabed together will nacessrly continues each other.
and also why does the minos of a bttary doesn't stick to the flower
you know why does the negative side of the battery doesn't create Electrical Polarization and stick to the
ceiling like a balloon?
The voltage difference necessary to get something to stick to the ceiling is typically in the thousands of volts. Luckily for us, the discharge current and amount of time is minimal. Batteries just don't have high enough voltage potential.
Ok cool
danielhaish said:
Ok cool
Have you ever seen someone stick a magnet to a AA battery? My first guess would be that he used some magnets.
Take a look at this
The battery video is a Trick so the Physics of the situation that you 'see' is not right. As @scottdave suggests, there's probably a magnet stuck to the back of the fabric, somewhere.
It is possible that the plastic case of the batteries is a good enough insulator to allow it to be charged up electrically but they are too heavy for Electrostatic attraction to be enough. Magnets do the job much better.
I think i found my answer i made an experience I connect a motor to Minos of one battery and to the positive side of another battery and nothing happened until I connect the battery s together so the electrons in the battery moving only if you
Connect it to it possitive side
  • Sad
So I assume that only small part of the elctrons move to the positive side an then the battery didn't recycled the the potential
  • Sad
  • · Replies 20 ·
  • · Replies 58 ·
  • · Replies 20 ·
  • · Replies 36 ·
