Which system of units is coherent for mechanics?
The discussion centers on the coherence of various systems of units in mechanics, specifically FPS (Foot-Pound-Second), CGS (Centimeter-Gram-Second), SI (International System of Units), and MKS (Meter-Kilogram-Second). It is established that all these systems can be considered coherent as they adhere to Maxwell's coherence concept, which states that a coherent system has only one base unit from which all derived quantities are formed. The conversation highlights the importance of consistent unit usage across different industries to avoid errors, such as the Mars Climate Orbiter failure in 1999 due to unit miscommunication.
  • Understanding of coherent systems of units in physics
  • Familiarity with Maxwell's coherence concept
  • Knowledge of the differences between FPS, CGS, SI, and MKS systems
  • Basic principles of dimensional analysis in mechanics
  • Research the implications of unit conversion errors in engineering projects
  • Study the application of Maxwell's coherence concept in various scientific fields
  • Explore the historical context of unit systems, focusing on the Mars Climate Orbiter incident
  • Learn about dimensional analysis techniques for ensuring unit consistency in calculations
Students, engineers, and scientists involved in mechanics, particularly those working with different unit systems and ensuring accuracy in calculations across various industries.
core1985
FPS, CGS, SI, MKS, All of these
As coherent system of units has only 1 as base unit and all derived quantities are formed also are coherent
So, should i write All of these as accodring to wiki pedia maxwell applied coherence concept to FPS, CGS, and SI is already coherent so answer will be All of these ?? Am i right or MKS because question is restricted to mechanics only ?
core1985 said:
Homework Statement:: FPS, CGS, SI, MKS, All of these
Relevant Equations:: As coherent system of units has only 1 as base unit and all derived quantities are formed also are coherent
Units serve a purpose. Their use is usually determined by the environment they are used in. If you live in Europe, then SI units are the normal. Except you work in the airline business, where feet and miles and pounds are used. If you live in the US, then things become a bit complicated, as it depends on the industry. The famous Mars lander fail 1999 was due to the fact that Lockheed and NASA used different systems and didn't communicate it.
This is another reason units should always by dragged through the entire calculation. Then it doesn't matter which ones are used, because they are part of the figures.
  • · Replies 22 ·
  • · Replies 25 ·
