Which vector undergoes parallel transport in a Foucault pendulum?
6 replies · 4K views · last reply
Joker93
Hello!
I try to think about the Foucault pendulum with the concept of parallel transport(if we think of Earth as being a perfect sphere) but I can't quite figure out what the vector that gets parallel transported represents(for example, is it the normal to the plane of oscillation vector?).
In particular, I can't exaplain the following animation https://en.wikipedia.org/wiki/File:Foucault_pendulum_plane_of_swing_semi3D.gif
which is found in this wikipedia article
https://en.wikipedia.org/wiki/Foucault_pendulum
using the concept of parallel transport.
Thanks in advance.
An object in free-fall would be a geodesic, which is related to parallel transport because a geodesic is just a curve that parallel transports it's own tangent vector.
You might look at https://arxiv.org/pdf/0805.1136.pdf. I havaen't really read it yet. My intuition is that we need Fermi-Walker trasnport, and not parallel transport, but I'm not sure if that's what the reference is saying.
In the animation its obviously not the normal to the plane of oscillation, but a vector parallel to the oscillation plane and surface. But it doesn't really matter which vector you show, as they have a fixed 90° offset.
That's what I thought at first but why does it get parallel transported in this way? At some points that vector is tangent to its trajectory, so wouldn't its parallel transport look something like the attached image?(from Do Carmo)
  • Diagram of a vector transported around a sphere along a closed curve; the vector is drawn at several points on the curve, labeled alpha, alpha double prime and alpha prime, with the vector at each point tilted relative to the previous one.
But is does not follow a geodesic since a geodesic on a sphere is a great circle.
Also, I do not know about Fermi-Walker transport. I will check out the pdf file though. Thanks!
