Which way does the cylinder roll? Solution posted doesn't make sense.
  • Thread starter Thread starter ph7ryan
    Cylinder Roll
The discussion centers on the mechanics of a 30lb cylinder subjected to forces from a spring and a mass, questioning the direction of its movement upon release. The cylinder rolls to the right due to the spring force being greater than the tension force, despite initial confusion regarding slipping. Participants utilized the moment equation Mo=Io(alpha) and the parallel axis theorem Ip=Io+md^2 to analyze the system, leading to a consensus that the cylinder's movement is counterintuitive but mathematically sound.
  • Understanding of rotational dynamics and moment equations
  • Familiarity with the parallel axis theorem in physics
  • Knowledge of forces acting on rigid bodies
  • Basic principles of energy conservation in mechanical systems
  • Study the application of the parallel axis theorem in different mechanical systems
  • Explore the concept of rolling motion and friction in rigid bodies
  • Learn about energy conservation principles in mechanical systems
  • Investigate the implications of tension and spring forces in dynamic systems
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of rolling objects and the forces acting upon them.
ph7ryan
A cylinder weighing 30lbs is initially at rest on a horizontal surface. There is a spring attached directly below the center, 2ft away from the center point o, pulling to the right horizontally. There is a string attached to the center and to a mass (around a pulley, frictionless) that can free-fall upon release of the system, with tension to the left direction (horizontally). There is enough friction to oppose slipping in this case.
(I know it says no pictures, but its a little hard to visualize this.)
http://i688.photobucket.com/albums/vv242/ph7ryan/Miniquiz_2_zpsd47d7512.png
Weight of mass = 10lb
weight of cyl= 30lb
k=50ft/lb
delta_x=2ft (stretched)
r1(to spring from center)=2ft
r2(radius of cyl)=3ft
There was a lot to do on this problem but the question that I am confused with is it wants to know in what direction will this travel after release. Apparently it moves to the right, although I don't see how this is possible without slipping.
He gives a hint to use the moment equation, where Mo=Io(alpha). In the posted solution, he also uses the parallel axis theorem, Ip=Io+md^2.
I took the moments about point o. The spring force would have a moment of 25lbft ccw, the tension doesn't have a moment, and friction is unknown, but would have to be to the left in order to prevent slipping (causing a cw moment). The resulting direction would be that it would roll to the left.
He took a different approach.
He said, because we don't know friciton, but we can represent T=massofweight*accelofsystem and we know fs (spring force), we can take the moment about point P, the bottom most part of the cyl in contact with the ground with vp=0. Thus the moment of fs is cw, and the moment by T is ccw, but because the spring force is much greater than the tension force, the fs moment outweights the T moment, thus it rolls to the right (cw).
Everyone agrees with me that this doesn't make sense, but no one knows how to argue the case against it. Maybe we are all wrong, but no one has explained it in a way that would let us change our mind.
here is his math in case anyone is interested in how he did it.
http://i688.photobucket.com/albums/vv242/ph7ryan/miniquiz2soln_zpsa245c17e.png
If the cylinder rolls to the right, what direction does the cylinder end of the spring move, and what is the relationship between the distance the cyliner rolls versus the distance the cylinder end of the spring moves? Do the math for this and the answer should make sense.
it would move to the left... meaning it would stretch more, and the weight would move up. the energy would have to come from somewhere for this to not violate thermo law 1.
and I did the math for the ratio traveled, it comes out to like 2:3.
  • · Replies 59 ·
  • · Replies 36 ·
  • · Replies 97 ·
  • · Replies 37 ·
