Who else but pf could help me w/this prob.
  • Context: Undergrad
  • Thread starter Thread starter karen03grae
The discussion revolves around a calculus problem involving the optimization of the dimensions of a rectangular beam cut from a circular log. Participants explore the relationship between the beam's strength, defined as proportional to the product of its width squared and length, and the constraints imposed by the circular cross-section.
  • Homework-related
  • One participant describes the problem and expresses uncertainty about how to proceed with the optimization.
  • Another participant clarifies that the problem involves finding the dimensions of a rectangle inscribed in a circle, suggesting the development of a formula for the rectangle's dimensions.
  • A participant mentions the use of the Pythagorean theorem to relate the rectangle's dimensions to the circle's diameter.
  • One participant calculates specific dimensions for width and length but questions the correctness of their method, indicating they may have deviated from standard calculus techniques.
  • Another participant suggests a different approach for substituting relationships between width and length directly into the strength equation.
  • A later reply challenges the correctness of a previous answer and suggests an alternative method involving differentiation to find critical values.
  • One participant expresses that the problem seems complex for a Calculus I level, hinting at potential confusion due to the mathematical notation used.
Participants express differing views on the correctness of the methods used to solve the problem, with some suggesting alternative approaches and others questioning the validity of specific calculations. No consensus on the optimal solution or method has been reached.
Some participants note the potential complexity of the problem and the challenges posed by the mathematical relationships involved, indicating that assumptions about the relationships between the dimensions may not be fully resolved.
karen03grae
So a friend of a friend calls me with this Cal. I. prob. I try to figure it out and get stuck. I have already told her that I don't know how to solve it. Now I am reallllyy curious on how to solve it. Here it goes:
You have a rectangular beam. Its cross-section has dimensions "l" and "w". The strength of the beam is directly proportional to w^2*l. Now if the beam is cut from a circular log with diameter of 3ft, what are the dimensions of the beam that will make it the strongest?
So I said s(w,l)= k*w^2*l where "s" is the strength. The width must be a little less than 3ft...but here I am just guessing. I know that l*w is proportional to pi*r^2, but I don't know where to go from there. help
That question was confunsingly worded, but I think it means the rectangular section you can cut our from the circle.
Hence, develop a formula for the dimensions of a circumscribed rectangle, then derive it.
Yes! I can't relate the rectangle to the inscribed circle. How would one do that?
Draw a picture. If a rectangle is inscribed in a circle, then its diagonal is a diameter of the circle. Now use the Pythagorean theorem.
Let R be the radius of the circle. If an inscribed rectangle has length and width, l and w, then [itex]l^2+ w^2= (2R)^2[/itex].
I got w = 6/sqrt(5) and l= 3/sqrt(5). I said [tex]s(l,w) = w^2*l[/tex]. Where "s" was the strength. I took the partial derivative with respect to both "l" and "w". The partial w.r.t. "l" was [tex]w^2[/tex]. And the partial with respect to "w" was 2*l*w. I set both of these equal to zero. I did this to maximize the function. I don't think I was supposed to solve it this way because it is a problem from Cal. I. Anyway, I now have 2*l=w. I solved for "l" by the relationship that HallsofIvy told me to use. So [tex]l=sqrt(9-w^2)[/tex] gets substituted into l= w/2 and that's how I got w= 6/sqrt(5). It sounds reasonable, but I would like to know if I did it correctly.
You could've used the fact that w^2 = (9-l^2)
and just subed that directly into the equation.
No, your answer is wrong :-) Follow double Mikes suggestion. There is no need for implcit differentiation
Never did figure out this one.
You are given that the strength is s= kw l2 and you know that
w2+ l2= 4R2 so l2= 4R2- w2 and s= 4kR2w- kw3.
Differentiating with respect to w, s'= 4kR2- 3kw2= 0 at a critical value. That is, w2= (4/3)R2 so that [tex]w= \sqrt{\frac{4}{3}}R[/tex] and then l2= 4R2- (4/3)R2= (8/3)R2 and [tex]l= 2\sqrt{\frac{2}{3}}R[/tex].
l, you might notice, is not "w/2", it's w= l/2.
Thats a tough problem for calc 1. Perhaps latex is just making it look really complicated.
Thanx. Can rest easier now.
