- 7,619
Here is a more precise way to explain the difference between determinism and superdeterminism. Let ##x_1(t),...,x_N(t)## be the complete set of phase-space variables in a closed system.A. Neumaier said:Then please point out where the error is. If one assumes that the universe (including all detectors and experimentors) is described by classical physics, the initial conditions determine everything including the choices of the experimentors, and there is no freedom. This is orthodox thinking since Laplace.
Determinism is simply the property that ##x_1(t),...,x_N(t)## are functions of ##x_1(0),...,x_N(0)##.
What does it mean in practice? It means that if you know ##x_1(0),...,x_N(0)##, then, in principle, you can calculate ##x_1(t),...,x_N(t)## for each ##t##. But if you don't know all ##x_1(0),...,x_N(0)##, then you cannot calculate ##x_1(t),...,x_N(t)##, despite the fact that the system is deterministic. If you don't know ##x_1(0),...,x_N(0)##, then determinism is not useful. Of course, Nature always knows ##x_1(0),...,x_N(0)##, but it is of no use for you if you don't know them.
Now superdeterminism. It is determinism plus one additional property. Unlike determinism, superdeterminism can be useful even if you don't know all ##x_1(0),...,x_N(0)##. For instance, it may be the case that Nature was so generous that it has chosen ##x_1(0),...,x_N(0)## in a very special way, such that
##x_2(t)## can be expressed as a function of ##x_1(t)##
In practice, it means that if you know ##x_1(t)## (e.g. by measuring it) then you can also calculate ##x_2(t)##. And to do the calculation, you don't need to know anything about ##x_1(0),...,x_N(0)##. Of course, Nature knows all ##x_1(0),...,x_N(0)##, but the point is that you don't know ##x_1(0),...,x_N(0)##, and yet you still can calculate ##x_2(t)## just from ##x_1(t)##. That's superdeterminism.
From this, one can see that superdeterminism is not always problematic. For instance, Nature might have chosen initial conditions such that the distance between Earth and Moon is a constant. This is an example of a non-problematic superdeterminism. A problematic example of superdeterminism would be a pseudo-random number generator at my laptop that always gives the same numbers as the ones drawn at the lottery. Why is the latter example problematic and the former is not? Because the latter example looks like a conspiracy. What is the definition of conspiracy? Unfortunately, there is no precise definition. Yet, it looks intuitively quite clear that the latter is a conspiracy and the former is not.
