Why Am I Getting Errors in My C++ Binary Tree Implementation?
3 replies · 10K views · last reply
Trista
I'm trying to write an address book that is based on a binary tree. I'm devloping in Visual C++ (I blew up my Ubuntu with the new dist), starting with the basics:
Code:
#ifndef binarySearchTree_h
#define binarySearchTree_h
#include <string>
#include <iostream>
using namespace std;
//Define the node
struct treeNode
//An object of type TreeNode
	string data;
	struct node* left;
	struct node* right;
treeNode(string str)
//constructor: Make a node containing str.
	data = str;
	left = NULL;
	right = NULL;
//define the class
class binarySearchTree
public:
	binarySearchTree();
		//constructor
	bool isEmpty() const;
	bool treeContains(treeNode *root, string data);
		//return true if item is one of the items in the
		//binary sort tree to which root points. Return
		//false if not
protected:
	treeNode *root;
#endif
my problem is in the implementation file in the treecontains() function:
Code:
#include "binarySearchTree.h"
#include <string>
#include <iostream>
binarySearchTree::binarySearchTree() :root(NULL)
bool binarySearchTree::isEmpty() const
		//return true if tree is empty
	return (root == NULL);
bool binarySearchTree::treeContains(treeNode *root, string data)
		//false if not
		if(root==NULL)
			//tree is empty
				return false;
		if(data==root->data)
			//item has been found
			return true;
		if(data < root->data)
			//item is in left subtree
			return treeContains(root->left, data);  //error
		else
			//item is in right subtree
			return treeContains(root->right, data); //error
	} //end treeContains()
I get an error that says:
Compiling...
test.cpp
binarySearchTree.cpp
c:\program files\microsoft visual studio\myprojects\binaryaddressbook\binarysearchtree.cpp(41) : error C2664: 'treeContains' : cannot convert parameter 1 from 'struct node *' to 'struct treeNode *'
Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
c:\program files\microsoft visual studio\myprojects\binaryaddressbook\binarysearchtree.cpp(46) : error C2664: 'treeContains' : cannot convert parameter 1 from 'struct node *' to 'struct treeNode *'
Error executing cl.exe.
binaryAddressBook.exe - 2 error(s), 0 warning(s)
Here is my test file:
Code:
#include <iostream>
int main()
	treeNode *root;  //pointer to the root noode in the tree
	root = NULL;  //start with an empty tree
	return 0;
as you can see it doesn't do anything, but get the constructors working.
please help so I can get this thing going?
thank you
Code:
#include <string>
#include <iostream>
//Define the node
struct treeNode
	string data;
	struct node* left;
	struct node* right;
	data = str;
	left = NULL;
	right = NULL;
It's been years since I've used C++ but I think you should have struct treeNode* left; and struct treeNode* right;.
Yep: TreeNode needs pointers to TreeNode, not pointers to struct node.
Cheers,
Tim
