Why Are Different Distances Used in Fluid Dynamics Calculations?
7 replies · 2K views
goldfish9776
in the second picturre, why the zs1 and zs2 is calculated by using 2m and 0.6m respectively ? it should be 0.8m , am i right ? what's the purpose of the author to use 2m and 0.6m ?
0.8m is the height of the tank. The author is comparing two orientations of the tank. In one orientation the front-to-back distance is 2m, in the other it is 0.6m. The zs values are the corresponding extra heights of the water, so one calculation uses 2m, while the other uses 0.6m.
why not we use 0.8m instead of 2m and 0.6m to get zs? the zs is in the same direction as 0.8m , right ?
can you please sketch out the 3d diagram , so that i can understand better
Yes, but that is only relevant to the question whether or not the water pours out of the tank: whether zs< 0.8 or zs> 0.8.
To calculate the actual increase in the height of the water on the back wall you need to use the distance from front wall to back wall. And that depends upon the orientation of the tank.
i think i get the idea already . why the distance is distance between the front and back wall ? Isn't the dstance= distance between the right and left wall as shown in the figure 3-52 ?
In which direction is this box moving? How do you distinguish between "front and back" and "side to side"?
I was using front-to-back in reference to the direction of movement. In one scenario, front-to-back is 2m (and the 0.6m doesn't matter); in the other it's the other way around.
