No, BS is saying that TRAVERSING a vector OF INTEGERS (in order to find the insertion point) is often faster than traversing a linked list, and that this efficiency dominates the theoretically less efficient process of insertion, where FOR INTEGERS the inefficiency is mitigated by cache hits.
In the real world we are hardly ever dealing with lists of integers, and we often have much larger data structures, or entities that cannot be serialized to a fixed-length record at all. The post you linked considers this, showing that for the combined search and insert operation in the context tested, a vector was about twice as fast for 100,000 8-byte records, but for 100,000 128-byte records it was about 50% slower and for 100,000 4K records the vector was more than 20x slower than the list. Where the records are non-trivial data types (so they cannot simply be serialized into a fixed-length array element), again the vector is 20x slower for 100,000 records (the 'random_insert - 16 bytes' chart immediately before the 'Random Remove' section).
So rather than "On most machines, O(n) insertion into a vector is often faster than O(1) insertion into a linked list, due to the cache and pipeline" I think we can say that "On a machine with a cache that is larger than the dataset in question, the combined process of insertion of a record preceded by searching for an insertion point can be significantly faster for a vector than for a list, however for large datasets or where moving data is a non-trivial operation then the vector performance can be many times worse than a list."
