Why are implications used instead of equivalent expressions in a direct proof?
  • Context: Undergrad
  • Thread starter Thread starter njama
    Direct proof Proof
The discussion revolves around the use of implications versus equivalences in direct proofs within propositional calculus. Participants explore the validity of certain proof steps and the nature of logical implications in relation to premises and conclusions.
  • One participant questions why implications are used instead of equivalent expressions in a direct proof, presenting a specific example with premises and a conclusion.
  • Another participant asks for clarification on the proof system being used, emphasizing that implications do not always behave like equivalences.
  • Concerns are raised about the validity of substituting expressions in proofs, particularly regarding disjunctive simplification and its implications.
  • Some participants discuss the axiom of disjunction introduction, suggesting it may be relevant to the proof steps being taken.
  • A participant expresses confusion about the use of premises multiple times within a proof and whether the truth values of variables can change throughout the process.
  • There is a discussion about the assumptions made in direct proofs, specifically that premises are considered true during the derivation of conclusions.
  • One participant proposes a method of validating the proof through truth values, questioning its correctness.
Participants do not reach a consensus on the use of implications versus equivalences in direct proofs. There are multiple competing views regarding the validity of certain proof steps and the nature of logical reasoning involved.
Participants highlight the importance of understanding the distinction between implications and equivalences, as well as the rules governing the use of premises in proofs. The discussion reflects varying interpretations of logical principles and proof strategies.
This discussion may be of interest to students and practitioners of logic, mathematics, and formal proof systems, particularly those exploring the nuances of direct proofs in propositional calculus.
njama
"A direct proof is a proof in which the truth of the premises of a theorem are shown to directly imply the truth of the theorem's conclusion."
Here are the premises:
(P -> R) ^ (Q -> S) ^ (~P) ^ (P v Q)
and the conclusion:
(S v R) ^ (~P)
Now what I do not understand why we are using expressions that are implications are not equivalency?
Let me start the prrof.
(1) ~P premise
(2) P v Q premise
(3) From discjunctive simplification we got:
(P v Q) ^ (~P) -> Q
(4) (Q->S) premise
(5) From detachment i.e (Q->S) ^ Q -> S
(6) P -> R premise
(7) from (6) ~P v R
And I didn't come up with the conclusion? What is the problem with this direct proof?
Shouldn't I use equivalent expressions and not implications?
:confused:
Please help
Which proof system are you using?
Its called direct proof in propositional calculus.
But the real problem is not every time implication works as same as equivalency.
For ex.
The first proof.
(P -> R) ^ (Q -> S) ^ (~P) ^ (P v Q) -> (S v R) ^ (~P) (tautology)
When substituting (P v Q) ^ (~P) -> Q
like
(P -> R) ^ (Q -> S) ^ Q-> (S v R) ^ (~P) is not tautology
Practically the direct proof is substituting implication in the expression, which I believe is not valid.
But from S, you should be able to prove S v X for any proposition X.
I do not understand. Please explain how.
I don't know how in your particular system, but there's often an axiom of disjunction introduction, similar to the conjunction elimination you've been doing so far:
(conj. elim.) (A ^ B) => A
(disj. intro.) A => (A v B)
Ok, my question is:
Would be correct to substitute
(~P) ^ (P v Q ) -> Q as it is equivalent expression to Q as follows (because of disjunctive simplification):
(P -> R) ^ (Q -> S) ^ Q -> (S v R) ^ (~P)
?? Is this valid?It is not. So why the proof says:
(1) A proof must end in a finite number of steps.
(2) Each step must be either a premise or a proposition that is implied from previous steps using any valid equivalence or implication.
(3) For a direct proof, the last step must be the conclusion of the theorem.
The (2) says that.
Any help, please? Could somebody possibly explain my why the direct proof is valid?
Thank you.
(~P) ^ (P v Q) implies Q, but it is not equivalent to Q (since Q says nothing about whether or not P holds). Thus, you cannot simply substitute it for (~P) ^ (P v Q) in an expression.
The steps don't need to involve substituting the things into the original formula, but just noting what other statements follow from the premises.
Yes, the steps does not involve substituting, but it is same like substituting things.
I didn't manage to prove the expression above, because it is something wrong with this direct proof. Just look at my first post and see where I am stuck.
You were fine up to and including step 5.
(1) ~P premise
(2) P v Q premise
(3) From disjunctive simplification we got:
(P v Q) ^ (~P) -> Q
(4) (Q->S) premise
Then here your next steps should be something like
(6) S -> (S v R) by disjunction introduction
(7) (S v R) ^ (~P) from (6) and (1)
And (7) is what you wanted to prove.
Thanks.
But you used premise ~P already in step (3).
Is it valid to use it again?
Of course. You can use a premise as often as you want. It remains true throughout the entire proof.
And does p,q,s have any truth value, for example. true or false through the process?
Do we suppose from the start that the premises are true?
Yes, in a direct proof one assumes the premises are true, and derives statements from that.
Thank you.
And can we prove it like this:
t(P->R) = T
t(Q->S)=T
t(~P)=T
t(P v Q)=T
Since the premises are true.
t(P)=F
From t(F v Q) =T, t(Q)=T
From t(T->S)=T, t(S)=T
From t(F->R) = T t(R)=T or t(R)=F
Substituting in the conclusion:
(T v R) ^ (T) <=> T ^ T <=> T
Is this valid?
  • · Replies 22 ·
  • · Replies 24 ·
