Why are quantum fields operators after second quantization?
  • Context: Undergrad
  • Thread starter Thread starter joneall
    Second quantization
124 replies · 14K views
vanhees71 said:
The position is the position of the detector.
The detector is a screen and has many positions, one of them responds to the photon. The two coordinates of the responding position define the transverse position of the photon measured.
vanhees71 said:
There's no position operator for the photon.
For the photon, in the observer frame, there is no 3-component position operator with commuting components transforming properly under rotations.
But there are commuting operators for the two components of position transversal to the beam direction. Thus transverse position can be measured with in principle arbitrary accuracy.
vanhees71 said:
A photodetector registers a single photon at a given space-time point (within a finite resolution). That's a measurement par excellance as it is defined in standard QT.
But it is a measurement of a particle, not of a field. If it would measure a field, as you claim the energy intensity, which value do we get for the incident field at the impact point? and which values at non-impact points? (Not seeing a response is also a measurement of photon presence, but not a field measurement.)
vanhees71 said:
This can of course only be achieved by measuring an ensemble (or rather a "statistical sample") of equally prepared systems.
I don't see, where we differ in this respect: the expecation value of a local observable like the electromagnetic field ##(\vec{E}(x),\vec{B}(x)## can of course again only be measured on an ensemble not a single system, and the expectation value as only one of the moments of the corresponding probability distribution only describes a small aspect of the state.
An engineer measures a local observable like the electromagnetic field ##(\vec{E}(x),\vec{B}(x)## with a single measurement at x, not by statistical means. This works well, although only a single electromagnetic field is prepared, not an ensemble of fields.
Statistics is needed only for extremely weak fields, such as that defined by a single photon state, and only to acumulate responses, not to average field values.
Reply
Fra said:
If I understand Neumaier, he thinks the "statistical sample" approximates not some fictional ensemble but the value of an actual "real" field (that is defined by accounting for ALL the actual varialbes the in universe, even those the local observer isn't informed about).
An engineer records no statistical sample but only one value at any point where a measurement is made.
For very low intensity fields, the interpretation of the statistical sample is as usual - it approximates the fictional ensemble and produces in a large number of detector responses the q-expectation = 1-point function of the intensity field at the positions of the screen.
But a single detector response has no quantitative information about the intensity (except that it is positive at the response position). Thus it cannot be called a field mesurement.
vanhees71 said:
it's a problem of all kinds of measurement also within classical physics. You can always only prepare a finite number of systems and measure them.
In classical physics we prepare one electromagnetic field and can measure it anywhere with a single measurement, provided the intensity of the field is large enough. The smaller the intensity the large the exposure time needed for an accurate measurement.
The same holds verbatim in quantum field theory: We prepare one electromagnetic field and can measure it anywhere with a single measurement, provided the intensity of the field is large enough. The smaller the intensity the large the exposure time needed for an accurate measurement.
Independently from the measured system, be it describable with good accuracy within classical physics or be it only describable within QT, you always have to repeat an experiment on a "sample of equally prepared systems" very often to be able to evaluate the statistical and systematical errors.
In the discussion about the measurement of the electromagnetic field and it's possible approximation with classical electrodynamics it's clear that a classical electromagnetic field like a field from a Laser pointer is described by a coherent state of QT. The intensity (i.e., the em. field energy density) is a measure of the field strength. If the coherent state is of high intensity the photon number (i.e., the total energy devided by ##\hbar \omega##, where ##\omega## is the frequency of the excited laser mode) is Poisson distributed. Particularly thus ##\Delta N=\sqrt{\langle N \rangle}##. This means that ##\Delta N/\langle N \rangle=1/\sqrt{\langle N \rangle}## is small for ##N \gg 1##, i.e., for high-intensity coherent states. Then you'll find that the repeated measurement is indeed only weakly scattering around the average value, and thus in such a case the description as a classical em. field is a good approximation. For very "dim laser light", where in the extreme you can have ##\langle N \rangle <1## this is no longer the case, and the quantum description is needed. In this case the coherent state is mostly "vacuum" and it's very unlikely to even measure one photon in a given time. That's why in this case you'll see the "quantum noise" and the discreteness of the registration processes of single photons.
For a macroscopic measurement (when an engineer measures a field, in particular, for most classical measurements) one rarely takes a sample, one just measures a single time. One needs it only in those case where the measurement results are so noisy that one needs to average a large number of measurement results.
No, only a longer exposure is needed before a measurement of the field results.
The reaon is that for a coherent state input, the quantum description gives identical results for the final intensity as the classical description.
But when only one photon arrived, neither the classical nor the quantum descrition allows you to obtain a value for the intensity from the recorded dot. Thus you don't have an intensity measurement, only a photon detection.
Yes, and that's why you dont have an intensity measurement.
This is a solution only if stationarity assumptions holds, right? Isn't the stationarity assumption a kind of "repeated preparation" in disguise?
/Fredrik
vanhees71 said:
There is no problem or if there is a problem it's a problem of all kinds of measurement also within classical physics.
Yes, I think is in principle a problem in classical physics too, but since classical physics is non-contextual, in practice, it stays beeing a practical problem of the physicist ignorance...
vanhees71 said:
You can always only prepare a finite number of systems and measure them. In general also both the preparation and the measurement are only approximate etc.
...because the right value of which we have approximations is independent of the measureement. Its just ignorance.
Neumaier has some idea that the similar argument can be applied to QM in his interpretation. But this does not work in the ensemble inteepretation as you can repeat all experiments, for example cosmology (But I dont find that a satisfactory solution as I take the measurement and observer perspective as central)
/Fredrik
Reply
It must be nearly stationary during the time of observation. For less stationary sources with a known evolution law one gets a 1-point function heavily smeared in time.
If you think only statistically then you need to use this disguise. But If you think in terms of 1-point functions stationarity is not needed and one just has different smearing functions.
In your interpretation, is this evolution law merely "in principle" knowable by some "omnipresent superobserver" but still assumed objectively determined?
How do you put that in terms of process tomography? Do you treat an actual finite observers processing of statistical samples just an "approximation" of something "real".
Or how is an observer independet definition of law (hamiltonian?) defined for say arbitrary observers in non-inertial frames? (Conceptually that is! as we know there is no full quantum gravity theory yet)
/Fredrik
The evolution law of the universe is known only to God. But it is assumed to exist and to be deterministic and observer independent. In this sense it is objective. Observer form their own approximate models of this evolution law.
Yes. Any collection of observations informs the observer about properties of the universe near its spacetime position. From this information observers construct, based on statistics and subjective plausbility (= prejudice) , their models for prediction.
For the universe, it is given by a classical action for fields defined on spacetime, to be interpreted somehow as a quantum dynamical law.
Fra said:
/Fredrik
Reply
Im in no position to answer what a quantum field is, but questions such as this one might often lead astray to rather philosophical inquiries. If thats not what is asked for, more concrete questions might help the understand the concept. Such as:
1. How does it transform under coordinate change?
2. If it can be considered as a mapping, beween which spaces does it map?
3. What physical information can be calculated from a quantum field?
Well, then you don't like this year's physics Nobel prize?
Wow, those assumptions fly in the face of almost every known quantum phenomena, whether quantum fields or particles or systems. I guess I'm surprised to hear this coming from you. Maybe I haven't read enough of your posts in this thread to understand your context, and if so, my apologies.
a) There is no currently known cause of apparently indeterministic outcomes of quantum measurements, so why would anyone assume there is such a cause?
b) Every prediction made on entangled systems (such as Bell or GHZ) is strictly observer dependent; and in fact the only relevant components of that prediction lie in a future measurement context freely* chosen by... observers. How does that point to objectivity? The field - whatever you may think it is - is not a factor in that calculation at all. (Obviously, any contribution it makes must cancel out, and can effectively be ignored completely.)
c) I won't even mention the usage of the word "evolution" in regards to quantum (as opposed to classical) systems or fields - other than to ask: How the passage of time (whether a nanosecond or a millennium) change anything? Time doesn't seem to a factor (in general, obviously there are exceptions where time is an explicit dependency).*Apparently.
Reply
He should have been invited to the Solvay Conference!
The context is my thermal interpretation of quantum physics.
This is a deterministic theory in which the traditional stochastic observables of quantum mechanics are denied to be observables. Instead the N-point functions of quantum field theories, which have a deterministic evolution law, are identified as the beables of quantum field theory in the sense of Bell.
Because one can hold the philosophical view that there is no effect without a cause. Then having found no cause only means one has not understood enough.
1000 years ago all what we now call science was unknown, and no causes were known for what we now understand as being caused. Why should it today be different compared to 1000 years in the future?
In a deterministic universe, free choices are only apparent. Indeed, all our free choices are actually determined by our motivations, experiences, goals, feelings, fits of the moment, etc.!
The field carries whatever causes the detection events. Without fields no transmission of information.
Time is a parameter in the evolution of a quantum state, hence the state changes with time (unless the state is stationary).
He is outside the universe, but determined the Solvay Conference to happen in the form it actually happened....
Reply
I mean, in the work leadking to this year's physics Nobel prize, one indeed observes the time evolution of electrons in atoms/molecules on the atto-second resolution level.
vanhees71 said:
I mean, in the work leading to this year's physics Nobel prize, one indeed observes the time evolution of electrons in atoms/molecules on the atto-second resolution level.
This does not contradict my claims in this thread. For clarity I provided again the context for these claims, namely measuring the intensity of a field.
The observation of the short time dynamics of single electrons is quite different - it is a stochastic process where observation is very noisy. But the extracted information is again based on a statistical evaluation of the correlation function and its interpretation through the short time Fourier transform of a 2-point function. The latter is the true observable carrying the information of interest; the stochastic trajectory is just a means for arriving at this information.
Even holding such a philosophical view (which admittedly is shared by many), you must admit the reasoning is essentially circular. No evidence is still no evidence, regardless of hope for the future.
I would agree it is reasonable (and in some ways useful) assumption. But it is the requirement that the causes precede the effect that gives me pause. I realize that requirement will be part and parcel of any interpretation with "thermal" in the name. But some degree of time symmetry in physics seems a relevant consideration too. Nonlocal contextuality has been demonstrated in so many recent experiments, and that seems to fly in the face of traditional concepts of causality. Ordering just doesn't matter, and in a deterministic universe, you'd think it would.
If you changed your "1000 years" to "100 years", your analogy might appear quite different (which is probably why you chose 1000 and not 100). By 1935, it was argued that QM was complete and there were no underlying "causes" to be found. 88 years later, it is even more evident - and certainly not less - that there is no meaningful root cause of quantum indeterminacy*. *The Bohmians got the jump on everyone by saying it is everywhere and now (but manifestly nonlocal), but is unknowable even in principle. Somehow their "unknowable in principle" seems to be a good bet no matter what interpretation we end up with. :smile:
The thermal interpretation is positive evidence for the possibility of interpreting QFT deterministically and causally.
There is no evidence at all that Nature is time symmetric, but overwhelming evidence for the opposite. Time symmetry is simply a theoretical assumption made, supplemented by heuristics for nevertheless having a causal arrow.
Since the thermal interpretation is nonlocal contextual, there is no conflict here.
I found meaningful causes in the chaoticity of the hierarchical dynamics of the N-point functions of QFT.
This is just as meaningful as the causes for randomness in classical mechanics.
I wouldn't say it's an assumption--it's a property of what have turned out to be our best current theories, that their equations are time symmetric. Since, as you say, we observe that Nature itself is not time symmetric, we then have to figure out how time symmetric equations can produce outcomes that aren't time symmetric, which then leads to the heuristics you mention.
Even time-symmetric equations do not imply that Nature is time-symmetric and only our perception of it is asymmetric.
To get sensible physics one has to assume causal asymmetry in addition to the time-symmetric equations! Causality is at the very root of theoretical physics!
Both in classical and quantum field theory, time symmetry is explicitly broken by choosing the retarded solutions as the ones that have physical reality, and ignoring the advanced solutions. This is done on the basis of the law of causality, that nonlocal causes never conspire to have exclusively local effects.
If the equations are just approximations, yes, that's true; the more fundamental equations they are approximations of could be time asymmetric.
More precisely, if one grants that the equations are time-symmetric, one has to make use of the fact that time-symmetric equations can still have time-asymmetric solutions--as long as the solutions occur in pairs, each the time reverse of the other. And then one has to explain why we live in one solution of such a pair instead of the other. I don't know if this is what you mean by "assume causal asymmetry"; your next paragraph suggests that it might be.
Independent of whether the equations are just approximations, the solutions of linear hyperbolic differential equations (such as the wave equation) form a vector space that is the direct sum of a space of retarded solutions and a space of advanced solutions. Causality is indispensible to explain why only the retarded solutions and neither purely advanced nor mixed solutions occur in Nature.
This cannot be explained by the common argument that we simply experience the direction in which entropy increases.
This would still allow superpositions of retarded and advanced solutions as long as the retarded one dominates.
But we have to explain why these unphysical superpositions never occur! I don't know of any other explanation than to assume causality.
Hm, I see; if you have linear equations the solution set is not limited to the "pure" ones, so to speak.
My personal "solution" would be that the ultimate fundamental equations are not linear. But I don't know if that option is being investigated.
In general, the linear equations define the 1-particle spaces upon which the quantum field theories are erected. The equations are necessarily linear, otherwise one has no superposition principle. But the latter is essential for the particle interpretation in scattering processes.
For Fermions one gets a Dirac equation. But only positive energy solutions are permitted for the superpositions. Positive energy is a causality constraint.
https://arxiv.org/abs/2312.01992
In this work, we review and extend a version of the old attempt made by Louis de broglie for interpreting quantum mechanics in realistic terms, namely the double solution. In this theory quantum particles are localized waves, i.e, solitons, that are solutions of relativistic nonlinear field equations. The theory that we present here is the natural extension of this old work and relies on a strong time-symmetry requiring the presence of advanced and retarded waves converging on particles.
If one looks from the observer side (which you don't in the same way).
How fit would a physical agent/observer be in order to maintain and encode picture that contains what most of us think of "unphysical things"?
Whould such an observer be stable? It would likely take an incredibly complex amount of processing to make up for the "poor ansatz". So selection pressure is to adjust the ansatz and gain stability.
So the alternative to a "constraint" is to consider the probability for agent survival if some have strange ways to encode the same data, that may be "logically possibly" but at face with a more natural or more economical interpretation of the data. In this view one would presume that among the crazy options, the distribution would be sharpply peaked around the "physically reasonable", not because the other ones are not possible, but because they are inefficient for nature.
This is how I interpret the KG to Dirac transition as well. Lets suppose, that an observer acually DID observer something going backwards in time? (whatever it means). the question is still, would the agent likely INFER that it was something going backwards in time, or would the discovery of a new particle simply by more natural? The latter is how I see it. Why and in what sense it is more "natural", is something to be clarified and makde more precise of course. But fitness is an possible intuitive angle.
(this would then indirectly relate back to the dynamics of hte "background spacetime", as the background spacetime on which QM is formed, might be emergent in a similar way)
/Fredrik
Of course. If you measure the intensity of the em. field prepared in single- or few-photon Fock states, it's also a very noisy observation.
