Why colonize Mars and not the Moon?
  • Thread starter Thread starter lifeonmercury
    Mars Moon
817 replies · 93K views
mheslep said:
Water is only trace in that cold atmosphere, and that only near the poles. Maybe mine the soils for ice and/or recycle for human needs.
Mining requires a lot of additional equipment. Additional equipment needs to be designed and built or imported, and needs additional maintenance. Mining can't be done just in any location - you need to actually have the desired material at the mining location (as opposed to air which is everywhere).
Instead of messing with all that, if you already have air processing plant which produces some H2O anyway, it may make sense to use _it_ to get H2O.
Mars colony is likely to have closed-loop life support systems (developed from space station technology) and need not that much water to top up losses.
Astronomy news on Phys.org
stefan r said:
Why not colonize both the Moon and Mars?
Sure, I agree.
The discussion exists because the $$$ available for space programs is limited. Thus, the question is more like "which colony - Moon or Mars - should be prioritized?"
mheslep said:
Im not a chemist either, but a change in pressure doesn't not necessarily effect Haber;
I thought that Haber was all about the appropriate working pressures. Perhaps we'd only be talking about a few more Watts of compressor on low pressure atmospheric N on `Mars. Probably not the biggest problem up there.
The Haber process needs the right pressure range, but once you have purified the inputs (probably via distillation), you are decoupled from the atmospheric pressure anyway.
I think they will hauling/piping water from the polar caps. At least until Ceres gets their elevator and mass driver built.
For colony #1 they are likely to drop the lander directly on the water deposit. http://www.space.com/31143-manned-mars-landing-sites-workshop.html
They will need to top up water much more than they will need nitrogen or argon. Data from viking mission has nitrogen 2.7% and water at 0.03%. Distillation would give you a cheap run separating CO2 from the Ar/N2. The water would be bound up in the dry ice at a little over 315 ppm. I suspect using a molecular sieve would be easier than distilling. Gypsum might be much more available than molecular sieves.
Maybe bulldoze the gypsum into a large solar bake oven or use nuclear waste heat oven. After extracting the water spread the gypsum out and let it pick up trace water for a few years. Maybe pile it on the habitats for extra radiation shielding. Helps if any water leaked reacts on location. then throw it back in the heat oven.
They found vast amounts of water ice at intermediate latitudes on Mars, just a few meters below the ground. A small digging or drilling tool can deliver as much as water as necessary. Digging gives water, the atmosphere provides CO2 and a bit of nitrogen. Water and CO2 are needed both for the station and to produce rocket fuel (and potentially as emergency energy storage), while nitrogen is only needed to cover losses in the station ecosystem.
OK That's a reasonable reply, thanks. Nitrogen will just be a bit more expensive - fair enough as everything else would be the same. There is always the possibility that mineral Nitrate deposits exist, from a time when there was more of an atmosphere.
[Edit: it looks like they would have to be of biological origin so that's a non starter . . . . . unless. . . .]
CO/O2 is a good fuel/oxidizer pair too, and this pair can be made from only CO2.
Nitrogen also is needed for plastics.
CO/O2 would give a bad Isp. Wikipedia mentions 250 s without reference, that is at the level of bad solid rocket fuels. The Raptor engine using methane and oxygen has 380 s.
With 380 s, you can go from the Martian surface to Earth with a single stage easily (mass ratio ~5-6).
With 250 s, you probably want a second stage (mass ratio ~12-14). What do you do with the first stage then? And how do you get the now much larger and more complex rocket to Mars?
With 380 s, you can go from the Martian surface to Earth with a single stage easily.
Fuel is useful not only for rockets. It might be the way how to store PV-generated energy for night consumption. Also, vehicles.
You don't have to go from Mars surface to Earth using a single rocket. A developed colony can have dedicated LVs for ferrying cargo and people to low Mars orbit. Earthbound passengers then change the ship. CO/O2 is adequate for LMO launch vehicle.
Here is a thread about CO/O2 fuel in NS forum - https://forum.nasaspaceflight.com/index.php?topic=21544.0
A few snippets:
Here's a few technical reports:
Experimental evaluation of the ignition process of carbon monoxide and oxygen in a rocket engine
http://hdl.handle.net/2060/19960045922
Carbon monoxide and oxygen combustion experiments: A demonstration of Mars in situ propellants
http://hdl.handle.net/2060/19910014990
(This one says that 260-280s is a realistic Isp for a pressure-fed engine, while 290-300s is realistic for a pump-fed engine.)
Use the right tool for the right job. The low Isp of the CO/O2 propellant combo is actually optimal from an energy standpoint (presuming you get really good mass fraction), which is relevant if you have to produce all that propellant from local power sources.
Colony #1 uses the same rocket. Earth to LEO with methane is much harder than Mars to MEO using CO. That would not work with H2/O2 engines.
ISP measurements vary depending on liquid vs gas going into the engine and the atmospheric pressure outside of the rocket nozzle. Wikipedia lists ISP 369 and ISP 309 for methane on the same chart.
You can do a single stage to orbit CO/O2 rocket on Mars ISP 250 is enough. But you can make engines that burn both methane and CO. So launch with CO to haul CH4 and Oxygen to the orbiting station and return using CH4. You can switch tanks fuel tanks mid flight while using one LOx tank and one rocket. Would not be 2 stages but similar effect. Elon Musk said something about using natural gas instead of pure methane to further cut costs for launch from earth. That opens up options for CO mixed into CH4 and/or mixtures with C2H4 and C2H2.
Let's calculate. For fuel that combust to CO2 and H2O, the reaction releases as much energy as we put in. Then, neglecting efficiency issues, the energy we need scales with ##(\mathrm{mass factor} - 1) I_{sp}^2## where ##\mathrm{mass factor} = \exp(\Delta v / (g\cdot I_{sp}))##. For every ##\Delta v##, this leads to a curve with a minimum at ##g I_{sp} = 0.628 \Delta v##.
For Mars orbit, 3.5 km/s, the most energy-efficient Isp is 225 s. If you get fuel from Earth in Mars orbit, then a low energy density can be an advantage. For return to Earth, 6 km/s, the most energy-efficient Isp is 385 s, and CO/O2 is significantly worse due to the staging issue.
This is neglecting gravity losses, which favor higher Isp. It is also neglecting that a lower Isp will need a larger rocket, again favoring higher Isp. CO has a higher density than methane, but we need more of it compared to methane, the effective density is similar. CO has a lower boiling point, making cooling more difficult.
Why would a developed colony want to rely on fuel sent from Earth? Or do you suggest electric propulsion or something similar to leave Mars orbit? Or multiple fuel launches as pseudo-second stage? All that increases the complexity. With methalox you can launch from Earth, land on Mars, refuel, and fly back in the next launch window.. You don't need a rocket infrastructure on Mars.
Yes, but you have to get to LEO, and Earth to LEO with CO is not going to happen. With methalox you can use the same engines to get to Mars and to get back.
Different temperature range, completely different fuel mixture ratios, different temperatures... I don't think that would lead to a good performance. Mixtures might work, but I don't see why CO should be in the mixture.
mfb said:
The risk is tiny for everyone involved apart from the few astronauts that would go to Mars. Space missions are not just the astronauts.
Sure. ? And the topic is moot if the astronauts are removed from the mission. Unmanned missions continue as before, for a $billion per go, with no concern about flight time, radiation, return, and relatively little concern about failure.
mfb said:
...Yes, but you have to get to LEO, and Earth to LEO with CO is not going to happen. With methalox you can use the same engines to get to Mars and to get back.
CO should be in the mixture because it is excessively abundant. Splitting CO2 to make O2 creates CO. Using the CO means no added infrastructure.
It is certainly not going to be ideal performance. The question is how much performance is lost. The oxy-fuel mix is easy to adjust. The valves to control flow are already in the engine. I have never built a turbo-pump. If I was buying a pump for a lab I would likely use the same model on CO or CH4.
I would worry about the engine getting hot enough to crack the CO. Would be easy to test for that.
For 1 liter of oxygen, you need 3.1 liters of CO, or 0.8 liters of methane. That is a factor 4 difference. An engine that can burn both needs horribly oversized fuel pumps and probably two separate injection systems. Not to mention the problem how to design the tank. Do you want to keep it 3/4 empty in methane operation? Or keep the oxygen tank 3/4 empty in CO operation?
The optimal chamber pressure and the optimal expansion ratio will be different for the two fuels, again you misdesign your engine for at least one of them. A thermal system good for CO is overdesigned for methane. You would need a gigantic benefit to outweigh all these disadvantages.
I'm sure it is possible to design a methalox engine to accept 1% CO or vice versa. But where is the point? You just add complexity for no reason.
H20 is only trace in the air, except for small periods near the poles.
Right, whatever Haber requires, additional power can make the conditions Earth like.
mheslep said:
Right, what ever Haber requires, additional power can make the conditions Earth like.
In principle yes, but where is additional energy to come from?
With useable technology at present the only feasible option is to set up several fission power plants on Mars.
These will have to be shipped, installed, and maintained from Earth.
That seems unlikely at best.
With useable technology at present the cheapest option is several fission plants set up on Mars.
Any power source on Mars must be shipped from Earth, of course. Small nuclear power plants have been proposed for missions, both by in the Mars Direct proposal in NASA's "90 Days Study". Either radioisotope (already used multiple times in space missions) or fission are considered.
Immediately after landing, the propellant factory/ERV would deploy a robot “utility truck” rover carrying a 4.5-metric-ton SP-100 nuclear reactor. The rover, which would burn methane fuel and oxygen oxidizer, would carry the reactor a few hundred meters away and place it into a natural crater or one blasted “with the aid of a few sticks of dynamite.” The crater wall and rim would prevent the reactor from irradiating the landing area. Thermal radiators would deploy from the SP-100, then the rover would run a cable from the reactor back to the propellant factory/ERV.
The SP-100 would supply 100 kilowatts of electricity to compressors in the ERV. These would draw in martian air, which is mostly carbon dioxide. The carbon dioxide would be reacted in the presence of a catalyst with 5.8 metric tons of liquid hydrogen brought from Earth, yielding 37.7 metric tons of methane and water...
I believe the deployment of the reactor to make fuel in Mars Direct occurs before arrival of the manned mission, i.e. is all robotic.
Solar panels are considered as well. They have a nice power to mass ratio and space is not an issue.
Yes, apparently 1.7 tons of solar panels http://www.uapress.arizona.edu/onlinebks/ResourcesNearEarthSpace/resources30.pdf to accomplish the same fuel production mission as the four ton nuclear reactor in Mars Direct.
Same source has an array 1850 m^2, less than on the ISS. Space craft arrays don't need much structural support, but one on Mars would need some. Assuming, 2 cm thick strings of cells, that's 37 m^3 of solar panels. Its not clear to me how that volume competes with the reactor on Mars transit.
I would have thought solar panels would be an ideal solution. Totally flexible modular design where a single problem with nuclear generation would mean no electricity supply. And we wouldn't want to mess up the Martial environment die to a crash or other unforeseen accident.
The issue of batteries for night time is not there if the panels are for fuel production. They deffo get my vote.
On Earth, CO2 is only 0.04% in the air. Look at any tree. Its carbon came _entirely_ from that CO2.
Was that 1% energy efficient conversion?
The leaf does gas separation by conversion from CO2 to carbonic acid, H2CO3. Martians can use minerals that react with water. However, if there is already a 2 story sand dune of hydrated mineral nearby then it is easier to use a bulldozer instead stressing the distillation plant.
We're discussing a very involved industrial process here, for which the small details affect the choice of the optimum system. It's hardly worth discussing the beauty contest without much more information about the real situation and the actual costs involved.
Everything has to be redundant. No one would rely on a single nuclear reactor - you would send at least two or three, where the failure of one or even two is not mission-critical. Same for the electronics for solar panels.
Batteries are useful if no nuclear reactor is present - you need electricity at night, and burning fuel for that has a bad efficiency.
I get all that; redundancy goes without saying, along with loads of reconfigurability. A solar farm would be producing much more fuel than would need to be stored in the basic overnight batteries. The best economy is to run with minimal dark time requirements and a big proportion of the solar output would go towards rocket fuel and daytime manufacturing activity. Vast thermal storage systems would be the way to provide heating. Life would revolve around such regimes - which is why I have always said that life on Mars would be no picnic ( same as in the Antarctic stations but much worse - no penguins to provide light relief. I would foresee the need for a lot of Psychoanalyists up there.
I know. However, the need of plant life for water and CO2 is considerably different. A mature tree might uptake .1 or .2 kg of CO2 per day in its growing season, but use almost half a ton of daily water. I doubt collecting the scant water vapor in the Martian atmosphere is effective compared to mining the soil for ice.
One might well send a single reactor for the unmanned fuel production mission.
Supposedly the dust storms encountered by the rovers blocked up to 99% of sunlight during the storm, and the dust cover remaining afterwards significantly reduced power. I doubt solar (plus batteries) is suitable, either for a manned mission with 24 power needs or an earlier unmanned fuel production mission that might be permanently impaired.
https://en.m.wikipedia.org/wiki/Spirit_(rover)#Global_dust_storm_and_Home_Plate
There have been several unmanned Mars mission accidents strewn around the planet, such as the Mars Polar Lander impact. There will be more. Curiosity's sky crane retro rocket was by design destroyed on the surface after landing Curiosity.
https://marsmobile.jpl.nasa.gov/msl/mission/technology/insituexploration/edl/skycrane/
. . . .but none involving nuclear materials, which was what my post was referring to.
How are nuclear materials, even if some escaped from a tiny reactor, harmful to the Martian environment? Mars surface radiation is 30 uSv/ hr, 120 times that of Earth background levels.
