Why do all objects fall with the same acceleration regardless of mass?
Objects fall with the same acceleration in a vacuum due to the equivalence of inertial mass and gravitational mass, as described by Newton's laws of motion and gravitation. The force of gravity acting on an object, represented by F_g = G M m_g/r^2, is balanced by the object's inertial mass, leading to the conclusion that acceleration (a) is independent of mass. This principle was illustrated by Galileo, who demonstrated that combining a heavy and a light object results in a paradox if one assumes that different masses fall at different rates. In a vacuum, where air resistance is absent, all objects experience the same gravitational acceleration regardless of their mass. This fundamental concept underlies our understanding of gravity and motion in physics.
themadquark
I am well aware that objects of varying masses, shapes, and surface areas will fall at different speeds and accelerations in an environment with a gas in the way such as air due to air resistance. Why is it though, that gravity causes all objects to fall with the same acceleration in a vacuum? Objects that fall further and have more energy and less time to decelerate have much more impact force, so why is it that this happens?
This happens due to the equivalence of inertial mass and gravitational mass. For inertial mass we have ##\Sigma F = m_i a##. For gravitational mass we have ##F_g=G M m_g/r^2##. If the object is in free fall then ##\Sigma F = F_g## so we have ##m_i a = G M m_g/r^2##. Then, because inertial mass and gravitational mass are the same we can set ##m=m_i = m_g## and get ##a = G M/r^2##, which is independent of ##m##.
This is an FAQ over in the General Physics section: https://www.physicsforums.com/showthread.php?t=511172
Please start by reading this FAQ entry:
Zz.
Newton's Laws of motion & gravitation give F = ma =GMm/r^2 where r is distance from center of Earth (roughly constant for dropping light & heavy objects). The mass m of the object cancels out, so its acceleration doesn't depend on its mass. Assume that air resistance isn't a factor.
Galileo showed a non-mathematical proof: Aristotle says that heavy objects fall faster than light objects. So what if we tie together a heavy object with a light object. By Aristotle's reasoning, the light object would then slow down the heavy object and at the same time, the heavy object would speed up the light object. The composite light-heavy mass would fall somewhere between the speed of the two alone, say an average. But the mass of this composite is greater than the mass of either part of the composite, so it should fall faster than either the light or heavy object. Thus, we have a problem in which we have proved that the composite both falls slower than one of its components and also falls faster than either component.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
