Why do contact points between gears have equal speeds?
Pipsqueakalchemist
I have the problem below
V_b = V_a + (w)X(R_ab)
So I’m confused about a few things in the solution. Why is it that speed of the V_h appears on both gear a and b? Is it because both gears are both in contact so they have equal speeds just in opposite direction. Same confusion for V_e being on the top of gear b. So Just because gear e doesn’t move and the top of gear b is in contact with it, that means the point of contact has the same speed? Also How can I use the V_h = V_e + (w)X(R_h/e) if they are separate gears and not one rigid body.
Hi,
Yes, there is a no slip condition. In this case the velocity ## v_H ## is in the same direction at the point of contact, but the angular velocities ##\omega ## will be in the opposite direction. Note, depending on how the gears mesh, the angular velocities may also be in the same direction (e.g. the way gear B meshes with E), but the velocity ## v ## will always be in the same direction
[EDIT]: Also note that the angular velocities are not necessarily equal, that depends on the radii & number of the gears in mesh
It is because they are in contact that they have the same speed at that point. Gear B is is instantaneously stationary about its point of contact (i.e. the velocity at the point of contact is 0, but it can be thought of as rotating around that point).
See above, ## V_e ## also refers to the speed of gear B at the point of contact, so I believe this equation is only referring to one equation. This equation can be used as we are using the stationary point of contact as the reference.
I hope that made some sense. If not, let me know.
Homework Statement:: I have the problem below
Relevant Equations:: V_b = V_a + (w)X(R_ab)
In order to better understand these relationships among meshing gears, you could visualize them as instantaneous levers, as shown in attached diagram.
Please, see:
https://www.tec-science.com/mechani...ary-gear/willis-equation-for-planetary-gears/
Yeah thanks guys, that helps and makes sense to me
