Why Do Different Methods Yield Different Accelerations in This Friction Problem?
x86
F=ma
Ff = N u
Pretty much, I did the same thing in the solution.
For box A:
N = mg
Ffs = mg*uk = 9.81*20*.4=78.48N
I note that Ffs > 60 N, so the boxes will move with the same acceleration
Now there are two ways I can approach this problem, each gives me a different answer??
1) Take two boxes as the same system, then Fx = 70*a = 60 ==> a = 0.857 m/s^2
2) Look at the FBD of box 2, note that Fx = 50*a = 60 ==> a = 1.2 m/s^2
However, both of these answers are different than the solution.
Where did I mess up (and why do 1 &2 give different solutions?)
Solution messed up the math, although equation is correct. . When you look at the lower Block , you did not properly address the force acting on the lower block. It isn't 60. Draw an FBD.
Check for errata. Looks like they did 60 = 70a --> a = 70/60, which is wrong.
Isn't this the FBD? Ffs on the top block is -60N, and since its an action-reaction pair it should be +60N on the 50kg blockEDIT: Actually, now that I think about it, the friction on the bottom/top block should be different, because its making the top block accelerate.
So the I have more equations to solve:
20a = -Ff + 60
50a = Ff
20a = -50a + 60
70a = 60
a = 60/70
Thank you everyone for your help
