Why do emergency detectors use high pitched sounds?
  • Thread starter Thread starter newjerseyrunner
20 replies · 3K views · last reply
newjerseyrunner
I know that as humans age their abilities to hear high pitched deteriorates, even if the rest of their hearing doesn’t. So why do emergency things like CO detectors use such a high pitched sound? I got to my in laws and their detector needed new batteries. Neither are hard of hearing but neither had any idea their detector was going off. Made me wonder if they’d even be able to hear it if it went off for real?
noises
Biology news on Phys.org
phinds said:
carry farther than lower frequencies?
Do they? Google "elephant communication."
Yeah, I googled around a bit. Turns out I apparently had it backwards.
Shrill is maybe 1 or 2 kHz? That's well within the peak of human hearing.
Smoke detectors aren't that high of a frequency. I believe they commonly use a frequency around 3 kHz.
phinds said:
That's very low on in the range of human hearing:
You're misreading something. 1.76 kHz is two A's above middle C.
I'm just saying ... the human range of hearing goes up to 20KHz, so a couple of KHz is low on that scale. Maybe everything over a couple of KHz sounds high pitched but is still audible.
In terms of octaves, the human range is 11 octaves with 2 kHz falling in the 7th octave.
Also, the (normal) human ear is most sensitive to the 2-5 kHz range, so it would make sense to place an alert tone in this range.
Interesting question, which makes me think of many alarms clocks which also have (relatively) high pitched sounds. I wonder if it is beacuse it sounds more intense/is more annoying, so the listener is more inclined to take action or even wake up?
EDIT:
Sounds like a good reason.
LOL, nope, nope, nope.:smile:
There is a practical reason for this, but it has little to do directly with the best range for human hearing...
Small, inexpensive piezo-based sound makers for low-cost consumer electronics happen to have that frequency range. You are not going to spend several dollars for a speaker-based sound maker in a product design, when you can use a simple sub-dollar piezo beeper instead... :smile:
Ah, here's the thing you are missing. Hearing is logarithmic. Each octave is a factor of two in frequency.
I suspect the reason the devices are inexpensive is because they are mass produced in the range that is best for human hearing.
Simple and solid state construction probably helps as well.
Vanadium 50 said:
I suspect the reason the devices are inexpensive is because they are massed produced in the range that is best for human hearing.
Just a commercial goodness coinkidink. :smile:
In theory, because it is out of the range of the most commonly used frequencies. Usually apart from some bird songs there are not many sources for that range.
In reality, it is what @berkeman wrote under that spoiler button...
Lower frequency alarms need bigger speakers to achieve same volume.
if i remember right the resonant frequency of the human ear canal is around 3khz, so I am guessing that has something to do with it as well..
i know when mastering a music track, its common to dip down the volume in that range.
Well, since birds already got mentioned - http://users.aber.ac.uk/rmm/urbansong.htm
