Why Do Physicists Write Integrals as ##\int dx f(x)##?
  • Level: Undergrad
  • Thread starter Thread starter martinbn
    Dx Integrals
83 replies · 13K views · last reply
Why do physicists like to write ##\int dx f(x)## instead of ##\int f(x) dx##? And also when did that start?
I have never seen that before.
Found a quick answer (with another linked question and answer):
https://math.stackexchange.com/ques...in-usage-for-dx-before-or-after-the-integrand
Although it doesn't say when it started.
It's a matter of taste. E.g. if we have especially long integrands with multiple variables and constants, it can be very helpful to denote the integration variable first. My guess is, that some physicists started with it for exactly this reason: write down the "unnecessary" first and concentrate on the essential part.
In QM Dirac notation, it is a more natural extension of the representation of vector/state for a countable basis, ##|n \rangle##:
$$|\alpha \rangle = \sum_n |n \rangle \langle n | \alpha \rangle $$
For a continuous basis, ##|x \rangle##, this becomes:
$$|\alpha \rangle = \int dx |x \rangle \langle x| \alpha \rangle $$
Where we have the identity:
$$\sum_n |n \rangle \langle n | = I$$
and
$$\int dx |x \rangle \langle x| = I $$
Says who? I'm a physicist, and I don't write it like that most of the time. I've seen mathematicians wrote dx first many times.
And why does this even merit a question? Isn't this no different than asking why someone prefers the color yellow instead of blue?
Zz.
Yes, this is the same. Mathematicians wouldn't put basis vectors first and the numbers second. It would be ##\sum a_i\vec{e}_i##, not ##\sum\vec{e}_i a_i##.
Ok, I thought it was obvious that I meant some physicists not all. But you are right I was sloppy.
Well, at some point someone must have started doing it. I might be wrong but I think the other notation have been around for a while before some, not all, started using the differential first notation. So there must have been a reason.
Also I have never seen seen it in introductory calculus/analysis textbooks. My guess is that physicists are exposed to it later on. It is puzzling to me that it is used.
Again, why is this "puzzling"? Unless you think that these things do not commute, does it matter that I write the product of A and B as BA instead of AB?
It is also a matter of typesetting style. Maybe some publishers or journals have a standard where the integration variables are written first. This is often useful if the integrand itself is a long, complicated function.
Once again, isn't this a matter of personal preference? Should I need to conform to liking the same color as you do?
Zz.
Yes, exactly, and the Dirac notation doesn't quite work the mathematician's way round! It's the same with the inner product being linear in the second argument, rather than the first.
Yes, and it is convenient that way. For the integral it is not, at least not any more. Are you saying that it is because of Dirac's notations? If you've been writing your integrals one way for a while there has to be a good reason to change later on, no?
All I know is that I started doing the integrals the other way round when I was learning QM Dirac notation. I've no idea whether Dirac started it. That's the only time I do it that way. Any other time I put the ##dx## at the end.
It's the same with vectors, it's only in QM that I write things back to front.
I have given it a little more thought. Here is a speculation. For some people, at least for me, the notation ##\int \dots dx## serves as parentheses to enclose the expression to be integrated, so it is natural to put it that way. Also if one does more abstract integration, or integration on groups it would seem awkward otherwise. Of course just ##\int\dots## would be fine. For other people it may be more important, at least in some cases, or more natural to think of the integral as an operator. It takes a function and it produces something else, a number, a function so on. Then it is more natural to write it as an operator ##\int dx\dots## acting on functions.
Zz.
Of course it "merits" a question. It elicited several sensible answers.
Demystifier said:
By analogy with ##\sum_n f_n## I would propose to use a third notation
$$\int_x f(x)$$
Makes sense, and before there will be complaints about the location for the boundaries:
$$\int_{x \in (a,\infty]} f(x)$$
To make the analogy with sums complete, how about
$$\int_{x =a}^{b} f(x) \;\;?$$
If you have a double integral, then the notation
$$\int_{a}^{b}\int_{c}^{d}f(x,y)dxdy$$
is ambiguous, because it is not clear whether ##x\in[a,b]## or ##x\in[c,d]##. With notation
$$\int_{a}^{b}dx\int_{c}^{d}dy \,f(x,y)$$
there is no risk for such a confusion.
I guess, because I like to write the sums as well as sum over instead of from to. :wink:
And if the integration order is arbitrary, we can even write
\int_{x_1}^{x_2}\, \int_{y_1}^{y_2} \, \int_{z_1}^{z_2} \,f(x,y,z) = \iiint_\stackrel{\stackrel{x \in [x_1,x_2]}{y \in [y_1,y_2]}}{\stackrel{z \in [z_1,z_2]}{}}\,f(x,y,z) = \int_{(x,y,z)\in [x_1,x_2]\times [y_1,y_2] \times [z_1,z_2]}\,f(x,y,z)
in which case the term volume gets a complete new feeling!
$$\int_x f(x)$$
Let me also note that Schiff in his quantum mechanics textbook uses the same notation
$${\large\sf S}_k f_k$$
for both sums and integrals.
Isn't that a proof that physicist's notation is better? :wink:
There are two major disadvantages with your proposal:
  • You cannot take away a loved infinitesimal from physicists.
  • Half of them would immediately lose the ability to perform a correct substitution.
:biggrin:
The greatest notation master among physicists is DeWitt, who writes e.g.
$$\int d^4x \sum_{\mu=0}^3 j_{\mu}(x)A^{\mu}(x)$$
simply as
$$j_kA^k$$
I would propose that all physicists should learn non-standard analysis, just for the sake of replying to pretentious mathematicians who mock physicists for using infinitesimals. :-p
Physicists don't do any substitutions anyway. They solve integrals either by looking into a comprehensive math handbook such as Bronstein et al (especially if they are old enough), or put it into Mathematica. :wink:
Well, I have rarely seen multiple integrals in physics written with the ##d^nx## (or whatever variable) written at the far end, it is always written right next to the integral symbol. Therefore it is logical to use the same notation when there is a single integration, no?
Oh, the question was about integrals in general, not just single integrals.
$$\int_x f(x)$$
The usual mathematical notation is ##\int_Sf## or ##\int_Sfd\mu## if you want to emphasize the measure.
The first notation is not ambiguous unless the text is very poorly written. It is used in many math books and i have never seen anyone, including tones of american undergrad students, be confused by it. Of course the way you've written it ##x\in[c,d]##. The integral sign ##\int## and the differential ##dx## are just like parentheses.The second notation looks very strange to me because surely ##\int_a^bdx=b-a##.
