Why Do Physicists Write Integrals as ##\int dx f(x)##?
  • Level: Undergrad
  • Thread starter martinbn
    Dx Integrals
83 replies · 13K views · last reply
stevendaryl said:
A Lebesgue integral can be converted into a Riemann type integral by switching the integration variable.
You have (for simplicity, assume it's nonnegative) a function f(x)f(x)f(x). You define a new function f∗(t)=μ({x|f(x)>t})f∗(t)=μ({x|f(x)>t})f^*(t) = \mu(\{ x | f(x) > t \}) (μ(A)μ(A)\mu(A) means the Lebesgue measure of set AAA). Then the lebesgue integral of fff is the Riemann integral of ∫∞0f∗(t)dt∫0∞f∗(t)dt\int_0^\infty f^*(t) dt. I guess the reason it's better defined is that f∗(t)f∗(t)f^*(t) will often be better-behaved than fff.
Which doesn't say anything about the notation ##\int fdx##.
martinbn said:
You don't need to write ##df## it is enough to write ##f##, and ##x(f)## is not just the set of all those values, you need the measure, so it is better to write ##\mu## or ##\mu(x)## so you integral becomes ##\int f\mu##, which of course is standard.
But you challenged me to write it somehow in terms of infinitesimals, didn't you?
Yes, but in a way that can be interpreted as ##dxf(x)##. That was the whole point, right?
Demystifier said:
Well, physicists don't often use Lebesgue integrals in practical computations
What do they use in their favorite Hilbert space ##L_2(M)## if not Lebesgue?
Demystifier said:
Speaking of physicists's way of doing Lebesque integrals, how about the following heuristics?
$${\rm Riemann}=\int dx\, f \cong \int dx \int df \cong \int df \int dx \cong \int df\, x ={\rm Lebesque} $$
I would be cautious here. Lebesgue ##\neq## Riemann. The above "equation" brings in automatically the physicists' chronic disregard of mathematical subtleties right from the start, rather than its usual occurrence later on.
Btw., does anybody know why the Riemann integral isn't called Aristoteles integral?
Demystifier said:
Well, #59 comes pretty close, doesn't it? :wink:
Well, it says Riemann = Lebesgue.
Why would it be called that?
That's why I used ##\cong## instead of ##=##.
Here ##\cong## means something like "almost equal but not quite", or "equal in most cases of practical interest".
What did you mean by ##\cong##?
But if you are going to use ##\int df=f## and ##\int dx = x## in that line, then you may as well say that ##\int fdx=\int dxf=xf=fx## with the appropriate ##\cong##'s.
fresh_42 said:
Wasn't he the first who came up with this idea?
Aristoteles! Do you mean Archimedes?
Not if you are a physicist with an intuitive feeling for limitations of any heuristic rules. :biggrin:
But it does seem to write the Lebesgue integral in terms of infinitesimals.
But those infinitesimals are for another function. The point was to be able to make sense,at least intuitively, of ##\int dxf(x)## as an infinite sum of infinitesimals.
Would it be correct to say that both Riemann and Lebesque integrals are just special cases of computing the area
$$\int\int dxdy$$
of a region on a 2-dimensional plane?
And what do you mean by area? The Lebesgue measure of the set? The integral you wrote down? What exactly is that integral?
Let ##f## be a function from reals to reals (for simplicity, let it be nonnegative). Let ##S(A,B)## be the set of points ##(x,y)## such that ##A \leq x \leq B## and ##0 \leq y \leq f(x)##. Then if the area of set ##S(A,B)## is defined, it will be equal to ##\int_A^B f(x) dx##. Right? By "area" I mean a measure on ##R^2## such that every set of the form ##\{ (x,y) | x_0 \leq x \leq x_1 \wedge y_0 \leq y \leq y_1\}## has measure ##|(x_1 - x_0) \cdot (y_1 - y_0)|##
May be, it depends on the unstated assumptions. Say you take area to mean the Lebesgue measure in the plane. It satisfies your requirement for area. Take a function ##f(x)## so that ##S(A,B)## is Lebesgue measurable and ##f(x)## is not Riemann integrable. Then if the integral you wrote is the Riemann integral, then the area is not it, the integral doesn't exists. I assume that is not what you mean, but you didn't say anything about the relationship between the measure in the plane and the integral on the line in you statement. But let's say that it is all fine. Then what? Where are you going with this?
I was just trying to answer the question "What do you mean by area"?
##\int dx f(x) = (x+C)f(x) ##
:DD
$$\int\int dxdy$$
I'm having difficulty in understanding how either of them would be special cases of finding an 'area'. An application of either theory would be finding the area/volume/measure of an ##n##-dimensional, pre-determined to be measurable, set.
The expression ##\int\int dx\,dy ## is just some function ##f:\mathbb R ^2\to\mathbb R## (hopefully).
