Why do the forces of nature act on each other?
  • Context: Graduate
  • Thread starter Thread starter skullcracker
    Act Forces Nature
The discussion centers around the existence of fundamental forces of nature, exploring questions about their purpose, the nature of interactions, and the underlying principles that govern these forces. Participants delve into philosophical inquiries, theoretical models, and the implications of emergent properties in physics.
  • Some participants question whether fundamental forces exist to attain a state of equilibrium, particularly in the context of attraction between positive and negative charges.
  • Others express skepticism about the ability to answer "why" these forces exist, suggesting that such questions may belong to the realm of philosophy.
  • A viewpoint is presented that while better models may exist, there will always be fundamental assumptions that cannot be further explained.
  • Some argue that deeper explanations for natural phenomena may always exist, while others challenge the notion that science will ultimately answer the "why" behind fundamental forces.
  • One participant proposes that force fields are emergent properties of simpler interactions, suggesting that forces can be viewed as the most likely outcomes of numerous possibilities.
  • Another perspective posits that entropic forces do not exist to increase stability or entropy but are emergent results of less constrained rules acting on large numbers of particles.
  • There is mention of the limitations of the standard model of particle physics in explaining the magnitudes and properties of forces, with an acknowledgment of ongoing unknowns in the field.
Participants express a range of views, with no consensus on the purpose of fundamental forces or the nature of their existence. The discussion remains unresolved, with competing interpretations and philosophical considerations present throughout.
Participants highlight the limitations of current theories, such as the standard model, in deriving fundamental properties from first principles. There are also references to the philosophical implications of asking "why" and the nature of emergent properties in physics.
skullcracker
why do fundamental forces of nature exist? Is it to attain a state of equilibrium? For e.g. is a positive charge is attracted to a negative charge to attain a state of equilibrium? Then why do forces like gravity, strong force, weak force exist?
I doubt if anyone can answer why. It is difficult enough to understand how.
Yes, 'why' belongs to philosophy.
a better model should be able to do that. Nature is not magic.
There will ALWAYS be a point where you can't just say a better model must exist. Even the most fundamental theory of the universe, whatever that will end up being, will have to have assumptions built in and properties that are true simply because they are true.
why not . This is how we made progress. Better assumptions lead to more usefull theories. Or at least more appealing ones.
Eventually science will answer the "why". But there's still some way to go.
When understanding is good enough, things are no longer "true simply because they are true". A deeper explanation always exists.
Can you logically show that deeper explanations can exist ad infinitum?
Think about a simple math proposition such as [itex]5*{{1}\over{5}}= 1[/itex]. Why is that true? There's a couple reasons: inverse, etc. However, at the end of the day, you can't go beyond "it is true because humans created the system such that it is true".
I usually hate these kinds of discussions because, in the end, everyone gets tied in knots and cries, "Uncle". Anyway, how would we know that we've uncovered the ultimate truth/theory of Nature? I don't think we can.
For the sake of argument, we don't even have to assume humans figure it out. It just has to exist. Then whatever it is, there's no reason to believe there would exist an explanation that you couldn't just say "why is this true?" to.
I have to say though, it's cool to imagine a situation like that... like something (almost) unimaginably special that only in retrospect could we say "wow, there is no 'why' to that..."
It's funny since I just read a transcript of a talk by Stephen Hawking where he talked about how he no longer thought a TOE was possible to uncover.
On the other hand, it's so sad when people stop asking "why?" so quickly. For example, I bet millions of students have been shown the model of the atom where... despite protons having the same charge, they all are shown bunched up in the center next to each other and none of them say "hey, wait a minute...".
"why do fundamental forces of nature exist?"
The force fields are emergent properties of simpler interactions between particles and photons (or bosons) acting over all possible paths and summed together.
For example, there are more ways that an electron and a positron can interact which end up with a closer position than which end up in a farther away position. The path integral gives an expected attraction.
So I think it is correct, if not fully descriptive, to say that all forces of nature are entropic. Gravity being less certain.
Its a bit like putting a red and a green gas together and saying that there is a 'mixing force' which causes them to mix together. It isn't really a force, just the most likely outcome from the huge number of possibilities (random movement of the molecules in this case).
but would it be wrong to assume that forces of nature exist to bring about a low energy state? (for e.g. strong force acts to bring about more stability).however more stability means less entropy.Moreover what is the reason for 4 different forces to exist , which ultimately leads to the same result i.e. stability ?
I don't think it is right to think of entropic forces as existing in order to increase entropy or increase stability. I would say that they exist because that is the emergent result of less constrained rules acting in large numbers.
By analogy I don't think that evolution exists in order to create fit individuals, they just happen to be the result of natural selection acting in large numbers.
But its getting into interpretations, maybe you interpret differently. Several different forces because there are several different simple interactions that happen on different particles in different ways. I don't think anyone knows exactly why there are the specific types that there are, other than the quite weak argument that humans wouldn't exist if they were different by as much as a percent or two.
nobody knows...yet.
The standard model of particle physics does our best job of explaining
three of the four forces(excluding gravity), and lots of the activities. But the magnitudes of the forces, the mass of the particles, the charge of particles, and so forth cannot yet be derived from first principles...they are observed quantities.
Qantum field theory within the standard model does a pretty good job explaining most of what we know...but there are still unknowns.
You could equally well ask: why does mass exist?? Why does our universe exist? Why do we?
for more check out:
http://en.wikipedia.org/wiki/Standard_Model
  • · Replies 28 ·
  • · Replies 29 ·
  • · Replies 16 ·
