Why do we care about trig identities?
17 replies · 7K views
musicgold
Homework Statement: This is not a homework question.
I am trying to understand why we spend so much time studying trig identities.
Homework Equations: As far as I understand, the two basic trig functions (sin and cos ) show the relationship between the sides of a right angle triangle in a unit circle. We care about them because we can apply this knowledge in many engineering and physics situations.
What I don't get is why we care so much about identities like
Why should I spend time learning and remembering something like ## cos u . sin v = \frac {1}{ 2} [sin(u + v) − sin(u − v)] ##
Here is how I tried to understand ## (sin u + cos v )^2 = sin^2 u +cos^2 v + 2 sin u . cos v ## . All I see is sinusoidal functions with different periods and some of them are always positive.
How do I use this knowledge?
Mathematics news on Phys.org
Good answer here: https://math.la.asu.edu/~surgent/mat271/mintrig.pdf
Short answer is to learn some of the identities well, not all. The above is a guideline.
Secant and cosecant might be a bit unusual or even be called redundant as they are just reciprocals of sine and cosine, but especially the identity ##\sin^2 u+ \cos^2 u =1## is very important. It is the equation of a circle, and as such present in many applications: change between Cartesian and polar coordinates, integration methods, physics in general. Especially in integration calculus we often switch between trig functions and polynomials, depending on which it is easier to find an antiderivative for.
But also in mechanics, there are angles all around and want to be calculated from lengths. Think of the formula for pulling a cart: work = force times distance times cosine between them.
Then you have other formulas like ##a \cdot b=|a||b|sin \theta ## which gives rise to orthogonality, geometry, so this is a very narrow view of what matters.
I always felt we learn these identities like we learn our addition and multiplication tables so we don't dwell on rederiving them over and over again as we solve more complex problems.
You will find the many math prodigies have these and many more facts at their fingertips allowing them to peel away the layers of a complex problem and get to the heart of it quickly and efficiently with minimal reduction mistakes.
I am reminded of the story told here recently of trying to get a math paper published that 1+1=2 by subbing in various math identities trig or otherwise to create a complex enough and interesting enough expression that looks devilishly hard to prove but in the end when the identities are stripped away by the reader, they realize its simply 1+1=2.
jedishrfu said:
I always felt learn these identities like we learn our addition and multiplication tables so we don't dwell on rederiving them over and over again as we solve more complex problems.
I get what you are saying. My problem is when you understand something it is easier to memorize it. How do you make sense of the product of two ratios:
I would just look that up. The only four I know for sure without looking them up are:
##\sin^2 x + \cos^2 x = 1## (*Note)
##\sec^2 x = 1 + \tan^2 x##
##\cos^2 x - \sin^2 x = \cos (2x)##
##2\sin x \cos x = \sin(2x)##
Everything else I would look up.
(*Note) This and the formula for quadratic roots are probably the two most useful things to remember. I use them every day!
If I may, ( ignore otherwise), how do you use these every day? Do you teach? You seem advanced in your knowledge so I can't think of how you would use them daily.
I just study Physics for my own interest.
Just today I was looking at QM Spin and if you take an electron z-up spin state and measure its spin about at axis at an angle ##\theta## to the z-axis, then the probabilities of getting spin up and down measurements are ##\cos^2(\theta/2)## and ##\sin^2(\theta/2)## respectively. The trig identity is important as that ensures that these two probabilities (which are the only options) sum to ##1##.
Moreover, the spin state has a phase factor of ##exp(\frac{i\phi}{2})##, which is a complex number of modulus ##1##. If we expand the complex exponential as:
##exp(\frac{i\phi}{2}) = \cos(\frac{\phi}{2}) + i \sin (\frac{\phi}{2})##
Then, again, it is the same trig identity that ensures this has indeed a modulus of ##1##.
##\cos^2 + \sin^2 = 1## is truly ubiquitous.
Thanks. Now I/we have a good answer for the repeated question : "Why should I learn trig , I will never use it again?":).
For that identity, I'd think of the algebra - how the symbols are going to combine after you apply the addition formulas for ##\sin{(u+v)}## and ##\sin{(u-v)}##. It's a mistake to attempt to visualize all mathematical facts as facts about pictures and graphs. Strings of symbols form patterns and change into other patterns.
Are you in a class where you are expected to memorize a long list of trigonometric identities? If so, I think you will have to memorize some of them by rote. I recall seeing a message on the internet that claimed using ##e^{i\theta} = \cos{\theta} + i \sin{\theta}## can be used to derive most trig identities, but I've never looked into that.
If you are worried about remembering every trig identity that you encounter as preparation for future courses - only a few of them are used frequently and obscure identities are things people expect to look up.
If you are worried about remembering lots of trig identities as preparation for entering math solving contests, I don't know anything about that.
Like Jedi suggested here, automating/memorizing a few formulas will help free your mind to do more advanced work. I assume you do not review every aspect of your life daily before studying or going to work; you automate and build on it. I am not discouraging you to find a way of understanding the formulas but until you do, you may just bite the bullet, repeat them for the exam. Notice, e.g, actors who remember their lines. Yes, in an ideal world schooling would be different but at this point it is not. Edit: Maybe playing around with them will help you memorize them.
I use them frequently in my work in, e.g., antenna coordinate transformations and signal processing. Example: I recently analyzed the large-signal behavior of an electro-optic modulator. When overdriven, and using complex (I&Q) signals, one gets sums and products of sines, cosines and Bessel functions. I tend to remember the most common trig relations, but look up relations involving derivatives and inverse trig functions.
Some would say the fact that ##e^x e^{-x} = 1## is what ensures the trig identity!
$$e^{i(u+v)} + e^{i(u-v)} = e^{iu}e^{iv} - e^{iu}e^{-iv} = e^{iu}(e^{iv} + e^{-iv}) = (\cos u + i\sin u)(\cos v + i\sin v + cos (-v) +i \sin(-v)) = (\cos u + i\sin u)(2\cos v) = 2 \cos u \cos v + 2i \sin u \cos v $$
And
$$e^{i(u+v)} + e^{i(u-v)} = \cos(u+v) +i \sin(u+v) + \cos(u-v) + i\sin(u-v)$$
Comparing real and imaginary parts yields:
$$\cos(u+v) + cos(u-v) = 2\cos u \cos v; \ \ \sin(u+v) + sin(u-v) = 2 \sin u \cos v$$
Euler's formula is great for rederiving these identities. However, the more difficult approach is to use the a diagram of two right triangles with an appropriate layout as shown in the video below:
We had to learn this proof because we didn't learn of Euler's formula until we covered complex number algebra.
Euler's formula approach is so much cooler and one has to wonder how Euler came upon it.
Sine and Cosine are the "basic" wave functions and it becomes apparent that in physics (from classical to quantum physics and from non relativistic to relativistic) and engineering, waves play an important role, so just try to learn about sine and cosine as much as you can!
I think that trig and calculus are the two most important math sectors that i have learned. Trig for its many practical applications and calculus because it helped open my mind to an entirely different way of thinking.
These identities help you find values when you are given certain parameters but need others. They are just different "Angles" of going at a problem.
The complex trig functions are often very important for higher level math derivations. Some integration techniques for example are simplified by using these identities, and are key to major mathematical formulas being found.
http://www.mathcentre.ac.uk/resources/uploaded/mc-ty-intusingtrig-2009-1.pdf
Also of thought is that these functions (maybe useless to most of us) are useful for people that perform these higher level calculations. Much like remembering that 5+5 is 10. I didn't count that i just remembered it and so it saved me time.
