iVenky
- 212
- 12
We have two tides because of the moon's attraction on the front and back side of the earth. I can understand the reason for the attraction of the moon on the front side which causes the water to move towards the moon but I can't understand the reason that the thing happens in the backside.
I can't understand this paragraph to be exact-
I couldn't understand those bold sentences.
Thanks a lot for your help
What do we mean by "balanced"? What balances? If the moon pulls the whole Earth toward it, why doesn't the Earth fall right "up" to the moon? Because the Earth does the same trick as the moon, it goes in a circle around a point which is inside the Earth but not at its center. The moon does not just go around the earth, the Earth and the moon both go around a central position, each falling toward this common position. This motion around the common center is what balances the fall of each. So the Earth is not going in a straight line either; it travels in a circle. The water on the far side is "unbalanced" because the moon's attraction there is weaker than it is at the center of the earth, where it just balances the "centrifugal force". The result of this imbalance is that the water rises up, away from the center of the earth. On the near side, the attraction from the moon is stronger, and the imbalance is in the opposite direction in space, but again away from the center of the earth. The net result is that we get two tidal bulges.
