Why Does 2 Seem to Equal 3 in This Mathematical Scenario?
  • Context: Undergrad
  • Thread starter Thread starter PrincePhoenix
7 replies · 2K views
PrincePhoenix
Why is 2 = 3 over here?
Suppose 2=3
Then subtract 5/2 from both sides.
2 - 5/2 = 3 - 5/2
4-5/2 = 6-5/2
-1/2 = 1/2
Take square root
(-1/2)2 = (1/2)2
1/4 = 1/4
What's wrong? why is it proved that 2 = 3?
Mathematics news on Phys.org
You didn't prove anything. Note that when you square both sides you effectively multiply the sides by different numbers.
Maybe it is because I am not fully awake yet, but I do not follow your arithmetic.
2 - 5/4 = 3/4 not -1/2
3 - 5/4 = 7/4 not 1/2
So you mean that taking square was wrong? I thought I did everything on both sides of the equation. I mean which step is incorrect?
I corrected the mistake. Check again.
When you square an equation, you run the risk of creating extraneous roots. For example, [itex]-2^2 = 2^2 = 4[/itex] but this does not prove that [itex]-2 = 2[/itex]. Also, another mistake you made is assuming what you're trying to prove. To have a correct proof you would need to begin with the equaltiy [itex]1/4 = 1/4[/itex] and proceed to show that [itex]2 = 3[/itex] (which you can't do).
Edit: Just so it's clear, the biggest fallacy in your "proof" was the assumption that [itex]2 = 3[/itex]. You can't assume what you're trying to prove.
To absolutely clear, here's why you can't assume what you're proving . . .
Let [itex]a,b \in \mathbb{R}[/itex] and suppose that [itex]a = b[/itex]. Then clearly we have that [itex]0*a = 0*b = 0[/itex]. Hence, if [itex]a[/itex] and [itex]b[/itex] are any two real numbers, then they are equal to each other (using your same logic). A correct proof would need to start at the equality [itex]0 = 0[/itex] and work from there (which is impossible).
Thanks for the answers. I didn't want to PROVE anything here. This was just shown to me by a friend and I just wanted to know what was wrong.
