Why does a pilot on a spiral trajectory feel zero g forces?
  • Context: High School
  • Thread starter Thread starter farolero
    Doubt Forces Normal
157 replies · 14K views
farolero
so a pilot is spining in a circle at a constant speed, the g forces he will feel will be the same than normal acceleration dependent on wr
but now you put him inside a tube where he can move along varying the radius of the circle
now the normal acceleration will be zero because he is in the equivalent of centrifugal gravity free fall
but he will feel as g forces the tangential acceleration as tangential velocity is function of wr and r is increasing as the pilot moves along the tube
but now you propel the spining tube in such a way than as the pilot doubles radius the w velocity of the tube halves, on this way the tangential velocity is constant and hence tangential acceleration is zero
but how can the pilot be in this last case in zero tangential acceleration and zero normal acceleration which implies he endures zero g forces if he is making a spiral trajectory?
Define "tangential" and "normal" precisely.
i thought they were universal terms:
normal or tangential to the pilot trajectory
Exactly how would you do that? What motion of the tube would make this happen?
well you put a precise gps on the pilot and connect the data with the engine of the tube
alternatively you could calculate an spiral tube in such a way that the spiral of the tube made the w half as the radius doubles with the right shape of the spiral tube
And what function would you program into the GPS? What motion of the tube could you program which would result in the desired motion of the pilot?
What shape spiral is the right shape?
well i would take as the center of reference the center of spin of the tube and from this reference the pilot will make a perfect spiral for which i don't know the formula of position but i guess someone does
now the normal acceleration will be zero ...
Only initially. It doesn't stay zero if angular velocity of the tube is constant.
If you spin the tube such that it exerts no force on the pilot, then he moves on a straight line.
The requirement that you proposed in your original post is for the motion of the tube that would produce the specified motion of the pilot. I don't think that the motion you proposed is even possible, and it seems that you are simply assuming that it is possible without any knowledge of the details.
If you assume that something impossible is possible then clearly you will wind up with contradictions.
i think i figure it out with your help guys, thanks
the pilot makes a spiral trajectory and this is the key
but the center of curvature in a given instant is not the center of the spiral but its somewhere offset from the center
so you just have to calculate this center and obtain the normal aceleration with this new instant temporal center that will be the g forces the pilot will experiment as he makes an spiral trajectory
(1) Draw us a picture .
(2) Aircraft and pilot g forces have been well studied over many years . Have you done a search for any existing information about your problem ?
g forces a pilot feels for what i know go in function of At and An
as a curiosity on free fall on vacuum you feel zero g
edit:
where i wrote At i meant An
farolero said:
... but now you propel the spining tube in such a way than as the pilot doubles radius the w velocity of the tube halves, on this way the tangential velocity is constant and hence tangential acceleration is zero
Your analysis is incorrect. Increasing the tube speed proportional to radius is NOT the condition that keeps the tube from touching him.
Start with the idea that with no acceleration he must move in a straight line. For there to be no acceleration the tube must be positioned around him at all times but not touch him
One might question how it came about that the pilot started moving in a straight line in the first place, but I didn't make up the problem. You did.
So if the pilot moves parallel to a radial, the initial tube velocity is 0 and dividing by the pilots radial position still gives 0. The tube does not move.
Now say the pilot moves at a constant velocity v starting at t0 on a tangent at radius r0. The pilots position at time t is angle = atan(v t / r0) and radius = sqrt((v t)^2 + r0 ^2)
For small angles atan(v t / r0) ~= v t /r0 and the angular speed increases linearly with time, but not linearly with the pilots radius. In fact at small times the sqrt approximates to r0 + (v t)^2 / (2 r0). For the tube not to touch him and keep the acceleration at zero the tube moves proportional to the square root of the radial position. This is because in addition to the radius becoming larger the fraction of the velocity which is tangential becomes less and less. This is where your logic failed. Any other motion of the tube, say angular velocity proportional to radius as you propose WILL accelerate the pilot.
well obviously as soon as the wall of the tube pushes the pilot he will feel g forces and if he goes in a staright line the tube is not spining which is a condition
what i initially failed to see is that the center of the trajectory at a given instant is not the center of the spiral but the center of curvature of that portion of the spiral where the pilot is at the given instant
if instead you wrongly take the center of curvature in the center of the spiral that's when the contradiction appears
i still have some trouble with this case problem:
imagine the case there are two counterrotating tubes in space:
the tubes are massless and frictionless, i can make this assumption for being them counterrotaing they still can apply a torque
there are two astronauts in the center of each tube and exactly at the same moment they start a centrifugal gravity free fall
we measure their trajectory exactly in the moment both astronauts intersect
the trajectories will be V which added will be a I aiming up
if initially the astronauts vectors in an isolated system was zero, how can it the isolated system go to a vector I aiming up without counterpart since the tubes are massless and hence can not have a vector
i hope you don't mind me asking questions of things i don't see and setting my self physics problems in order to solve them for entertainment
If they were massless they would have an infinite acceleration from any unbalanced force, so you already found the flaw in your assumptions.
i think what would be going on is that actually none of the astronauts would be moving forward or backwards just lateraly, it would be the massles platform which would be rocking back and fordward :)
now a last case that will help me understand vectors and their arms:
now there's a single masless frictionless tube in space and two astronauts that jump to free fall artificial centrifugal gravity in opposite sense
initially there's a vector aiming upwards from the surface of the paper where the drawing is
how did it mathematically go to those two opposite vectors and the growing arm?
well then make the tube have the same mass than the both astronauts and be 10 m long, then the torque will be provided by the tubes inertia to keep spinning
consider than the tube with the astronauts inside its spinning at w=10
the initial separation between the astronauts cog would be 10 cm
You really need to describe your scenarios more carefully. In this case, is the tube initially rotating?
Assuming so then the angular momentum of the tube + astronaut system is L. This can be written as ##L= I\omega##, which is constant. As the astronauts go down the tube ##I## increases and therefore ##\omega## decreases.
i see thanks yes the tube is spinning together with the astronauts at w=10
if theyre initially in the center of the spinning tube separated by 10 cm could anybody help me calculate the speed they will have at 1 m centrifugal artificial gravity free fall?
im not very sure how should i solve it
Forget solving it for now. Do you know how to set up the problem? What equations would you use?
I am not sure what you have learned so far. Have you studied Newton's laws, free body diagrams, rotational motion, Lagrangian mechanics, ...?
well it would be easier for me to solve it accounting for a massless tube
i think the main equations i should use are conservation of momentum equations, the angular momentum must remain constant since its an isolated system
would you please allow me to solve it accounting for a very insignificant low weight tube?
Ok, so first step is to specify the problem completely.
Describe the geometry and the masses involved. How much mass are the astronauts, are they considered point masses, if not then what shape, the mass of the tube, any friction or other forces, any external forces, etc.
Next, describe the initial conditions and any events that set up the problem. Like initial rotation, astronauts letting go of each other, etc.
well first correct me if I am wrong please:
you were right a massless tube wouldn't result in an spiral motion but both astronauts going in an straight line
but if i take a very low neglectable mass tube they will go in a very open spiral, if increase the mass of the tube the spiral motion of the astronauts will be less open
the initial conditions are this:
there's a spining tube in space with two astronauts inside both separated by 0.1 m who are holding each other and suddenly let go on artificial gravity free fall(the astronauts for simplification are considered point masses and for simplifictaion reason friction along the tube is minimum and its neglected)
the spinning tube with the astronauts its rotating at w=10
the mass of each astronaut is 1kg
the mass of the tube can be consider and I am no very sure of this as 2 kg or neglectable
the tube is one meter long
what speed will have the astronauts when leaving the tube?
if there's any teacher here they could put this problem to their students to see who can face unseen problems and whose just been memorizing standard cases
edit:
i realize now it would be wrong to neglect the tube mass so please if you can take it as two kg it would help me a lot
OK, so you have a scenario in mind. The next thing to do is to start selecting the laws that you want to use.
At your level, the standard laws to use are Newton's laws. Those laws apply whenever there are forces acting and you can neglect relativity (which is fine here). So you can use Newton's laws by calculating the forces acting onnthe tube and on each astronaut.
However, it is usually easier to apply conservation laws. So think about your system. Which conservation laws apply and why do they apply.
well in this case above all i would check conservation of momentum so the mvr of the astronauts remain constant
they would apply for being practically an isolated system
Ok, so conservation of angular momentum. That is a good start.
Are there any other conservation laws that would apply?
yeah of course conservation of energy
so let's see the astronauts go initially at 1 m/s(0.1*10)(wr) so their kinetic energy is 0.5*2*1=1
the momentum is initially 2*0.1*1(mvr)=0.2
but i don't remember how to fit the tube in the equation, i don't remember very well the rotational equations
i know rotational momentum is w/r and rotational energy is 0.5*w*I2 but what's the moment of inertia of a tube?
