Why does a sliding book stop rotating and translating at the same time?
117 replies · 22K views · last reply
There appears running torque for the rotation.Fulcrum and force are two essential ingredients for running torque. That is to say, ununiform configuration of force is responsible to the rotation.In addition, rotation disappears if surface is ideally flat.
Could someone tell me (I may have missed this in the past 90 posts; if so, I apologise) why the 'rotational' motion of a point is being considered? Does that have any meaning? At anyone instant, all points can be considered to have a linear velocity. What is the 'frictional torque' on a point?
The energy loss at any point is just proportional to its speed, as I have pointed out before. The faster moving points will be dissipating the book's KE faster than the slower moving points (it will be zero for the one point that happens to be stationary). If just one point is moving then all the others but the pivot point, must be moving too (rigid book).
Also, the relative distribution of speeds over the surface will be the same for the same ratio of rotation /translation speeds (everything scales). The rate of energy loss over the surface will be proportional to the absolute speed of , the CM and ratios of velocities will also be the same during every rev of the book.
Full marks to people for trying a simulation but the initial equations for a simulation must be justified before the results actually prove anything.
uumlau said:
A clarification of my initial points:
  • for the frictional force to STOP rotation without also stopping translation, it must be 100% symmetrical around the center of mass
  • for the frictional force to STOP translation without also stopping rotation, it must be 100% against the direction of motion of the center of mass (the net force of friction must "point at" the center of mass)
Although it is true that rotation stop at the same time, I think the only thing you have demonstrate is that rotation can only stop when translation is slowed, and vice versa.
uumlau said:
I'm beginning to suspect that the center of rotation doesn't move unless the frictional force from the surface is uneven (due to normal irregularities in the surface). I'd have to sit down and do the math to figure out if it does, but I'm refraining from doing so because I prefer to hone the qualitative explanation, for now. (And because I'm lazy. :-p)
Based on the program I wrote, that pivot point always moves towards the edges of the book. If the book is circular, it will approach the a point on the circumference.
uumlau said:
If the book is both rotating and translating, there is no way for it to stop just one or the other without some kind of discontinuity in the motion, as indicated by the location of the center of rotation.
If we slowed it down by some other method (not friction), we could stop one without the other and there would be no discontinuity of motion.
The KE at any point will be proportional to the square of the speed, so reducing the KE in proportion to the speed will not keep everything proportional. It will disproportionately affect the speed of the slower moving points.
... I'm still considering one of your other points ...
But the rate of loss of energy is proportional to speed (friction force times speed is dissipated power); that's my point about "everything" being proportional. Perhaps the word "everything" was a bit unspecific.
What I am getting at is that the same exponential energy dissipation (not KE) decay factor applies to every point at every time; whatever its instantaneous speed, its loss of power is proportional to that speed. This, in my reasoning, means that no energy can be lost from anywhere 'first'. This all hangs upon the idea that the 'rotational' forces and energy do not have to be relevant - even if the way they have been used by some contributors is actually valid - I have my doubts about that.
I thought that this idea could be applied even better if you bear in mind that the instantaneous stationary point (reference the table) will follow a path over the bottom surface which will repeat itself once per cycle of rotation*. So you could break one cycle into a loop of N delta steps and apply my exponential idea to every point sampled at a given angle of rotation. Sm(tn) would represent the speed Sm of point m at time tn, where n goes from 1 to N every rotation. The speed samples Sm(tn) would all follow a path of energy loss against speed Sm(tn). No individual point could attain zero speed (unless there was no initial translation speed); at times when its speed is low, the energy loss is low and when its speed is high the energy loss would be high - but the rest of the book is coupled to it so you could say it is sharing the total KE of the other points and, between them, all points are dissipating the KE at different rates and at different times.
*Hmm - that may be a circular argument but, even without it, my reasoning seems coherent - to me.
This is basically the same code as before but with better annotation.
I also eliminated an unnecessary variable and renamed two other variables.
Let me know if you want more detail or explanation.
Code:
  //  This code computes the frictional forces acting on a spinning and
  // translating disk at one moment in time.  The ratio of the speeds of
  // rotation and translation are varied over a wide range.
  int     nX, nY, nDiv, nYRange;
  __int64 nYRange2, nDiv2, nArea;
  double  fR, fX, fY, fX2, fPivot, fPR;
  double  fForceX, fForceY, fSpeed, fRDiv;
  double  fForceXSum, fForceYSum, fTurnForce, fTurnForceSum;
  double  fSpinFrictionMax, fArea;
  //  I am presuming a circular book.  "fR" is the radius of that book and I
  // am setting it to 1.  This doesn't really matter because everything will
  // scale to the radius anyway.
  fR    = 1.0;   // Radius
  //  The ratio of the rotational speed and the translational speed can be
  // described by specifying the "pivot" as a ratio of the radius, which I
  // calling "pPivot".  When pPivot is zero, there is only spin motion.
  //  The pivot point is the location where there is no relative motion
  // between the book and the surface.  It will always be along a line
  // that crosses through the center of the book and is perpendicular to
  // the translational motion of the book.
  //  When pPivot is 1, the pivot point will be at the circumference of
  // the book.  When pPivot is zero, the pivot point is at the center of
  // the book.
  //  I am varying the pPivot from 0 (book center) to 2.5 (well outside
  // the book so there is much more translation that rotation.
  for(fPivot=0; fPivot<=2.5; fPivot+=0.05) {
    //  Multiplying "fPivot" by the radius gives us the actual distance
    // between the pivot point and the center of the book.
    fPR   = fPivot*fR;
    //  I will be performing discrete integrations across the surface of
    // the book.  "nDiv" is the number of discrete interval I will be
    // using along the radius.  Computation time will be proportional to
    // nDiv*nDiv but precision improves as nDiv is increased.
    nDiv  = 100;
    //  Two values that will be needed in the inside loops (below) are
    // precomputed here.  They are the actual distance of one interval
    // (fRDiv) and the square of nDiv (nDiv2).
    fRDiv = fR/nDiv;
    nDiv2 = (__int64)nDiv*nDiv;
    //  We will be integrating five value:
    //   nArea:    The area of the circular book surface.
    //   fSpinFrictionMax:  The force that would have been applied
    //           against friction if there was no translational force.
    //   fForceXSum:  The translational force along the direction of
    //           travel.
    //   fForceYSum:  The translational force perpendicular to the
    //           direction of travel.  This should be zero and is used
    //           as a check.
    //   fTurnForceSum:  The force applied against the book's spin.
    nArea = 0;
    fSpinFrictionMax = 0.0;
    fForceXSum  = 0.0;
    fForceYSum  = 0.0;
    fTurnForceSum = 0.0;
    //  Discrete integral along the direction of motion from the
    // trailing edge to the leading edge.
    for(nX=-nDiv;nX<=nDiv;nX++) {
      //  The book is circular and we only want to integrate across
      // points that are on the books surface.  So we compute the
      // range of Y value that will keep us on the book (nYRange).
      //  We are using __int64 foor the intermediate results.  This
      // will allow us to use values of nDiv above 45000 - not that
      // we would want to run the program that long.
      nYRange2 = nDiv2-((__int64)nX*nX);
      nYRange = (int)sqrt((long double)nYRange2);
      //  Compute the X coordinate and its square.
      fX  = nX*fRDiv;
      fX2 = fX*fX;
      //  Discrete integral across the direction of motion from the
      // left edge to the right edge.
      for(nY=-nYRange;nY<=nYRange;nY++) {
        // The Y coordinate.
        fY = nY*fRDiv;
        //  These next two integrals (nArea and fSpinFrictionMax)
        // are not dependent on fPivot.  So if I wanted to optimize
        // for speed, I could create separate (nX, nY) loops for
        // them so that they are only computed once.
        //  Integrate the book's area by integration so that it will
        // match the other integrals.
        nArea++;
        //  Integrate the spin friction assuming no translation.
        fSpinFrictionMax += sqrt(fX2+fY*fY);
        //  Compute the direction of the frictional force.  It will be
        // against the direction of motion and can be computed
        // from the relative position of this point to the pivot point.
        fForceX = -fY-fPR;
        fForceY = fX;
        //  Compute the speed.
        fSpeed = sqrt(fForceX*fForceX+fForceY*fForceY);
        //  Check for the zero-friction point.  This is important to
        // avoid zero/zero division.
        if(fSpeed<0.001) continue;
        //  I'm using a coeeficient of friction of "1", so the absolute
        // value of (fForceX,fForceY) must be 1.
        fForceX /= fSpeed;
        fForceY /= fSpeed;
        //  The turn force is the cross product of the force and the
        // arm to the center of gravity (fX,fY).
        fTurnForce = fY*fForceX-fX*fForceY;
        // Accumulate frictional forces.
        fForceXSum += fForceX;
        fForceYSum += fForceY;
        fTurnForceSum += fTurnForce;
    // Compute all the proportional forces.
    fArea    = (double)nArea;
    fForceX  = fForceXSum/fArea;
    fForceY  = fForceYSum/fArea;
    fTurnForce = fTurnForceSum/fSpinFrictionMax;
    // Output fQ, fForceX, and fTurnForce here ...
Code:
OK, so that works out the forces. Then will you calculate the effects of those forces on the book as a whole? It could help perhaps is you were to describe the process analytically, rather than in code. Code is easily digestible by a compiler but a series comment lines tends get a bit disjointed for the human reader.
I guess your approach so far is fine. What does the next step involve and what does it show?
I'm not sure where you're getting this.
If you take the maximum frictional forces for translation and rotation as occurring when there is, respectively only translation or only rotation, then the table shows what percentage of that maximum force you have when the pivot point it not at those extremes. Although, I am wondering if I should have computed energy loss instead of force. What is critical is that in either case (force or energy) the spin and translation curves will be monotonic. So they will cross at a particular point and the book will tend towards the spin/translation ratio corresponding to that point. The only time there will be a regular oscillation of this ratio is when the book is not circular and it is already at the ideal spin/translation ratio.
There will be only one point at any time that is not moving wrt the table. For a disc the points will lie on a circle where tangential velocity equals minus translation velocity of centre. For a general shape the locus may not be a circle (?) this point is losing no energy from the book.
I tend to think in a mixture of graphics and computation - and sometime the graphics don't translate fluently to equations.
The basic question can be restated as:
Given any particular initial spin/translate ratio, will that ratio tend towards the extremes (no spin or no translate)?
Or, restated again:
Given any particular spin/translate ratio, in what direction will the spin/ratio change?
If the answer to that last question is either "the ratio stays constant" or "is tends to some middle point", then we know that the spin and translation end at the same time.
A book that is only translating has speed-squared (Ts=speed; Ts2/2) energy and is loosing energy at rate proportional to speed (Ts). So it will stop in a period proportional to speed (Ts/2).
A book that is only spinning has speed-squared (Ss=speed at edge; Ss2/4) energy and is loosing energy at a rate proportional to average speed (2Ss/3). So it will stop in a period proportional to speed (3Ss/8) - but 25% quicker than with the corresponding translational speed.
(So when I went to the 2:1 ratio in the table, I was probably wrong. But anyway...)
If we had two books, one spinning (Ss) and one translating (Ts) and we wanted them to stop moving at the same time, then Ts/2 must equal 3Ss/8, so Ss/Ts must equal 4/3.
When there is a combination of spin and rotation, I will not get my maximum energy loss from either. So the situation will be:
Translational Speed: Ts
Translational Energy: Te=Ts2/2
Maximum relative rate of translational energy loss: Tfmax = Ts
Effectiveness of translational energy loss: Tfe(Ts/Ss)
Actual relative rate of translational energy loss: Tf = Tfmax*Tfe(Ts/Ss) = Ts*Tfe(Ts/Ss)
Spin Speed: Ss
Spin Energy: Se=Ss2/4
Maximum relative rate of spin energy loss: Sfmax = 3Ss/8
Effectiveness of spin energy loss: Sfe(Ts/Ss)
Actual relative rate of spin energy loss: Sf = Sfmax*Sfe(Ts/Ss) = 3Ss*Sfe(Ts/Ss)/8
The Tfe and Sfe functions were the ones I was trying to compute with my program - and show in the table.
We can further describe the situation in terms of how fast we are approaching a stationary book at the given moment. Of course, since the spin/translate ratio is changing, this rate will change. But at any given moment:
Extended time to no translation: Tet = Te/Tf = (Ts2/2)/(Ts*Tfe(Ts/Ss)) = Ts/(2Tfe(Ts/Ss)).
Extended time to no spin: Set = Se/Sf = (Ss2/4)/(3Ss*Sfe(Ts/Ss)/8) = 2Ss/(3Sfe(Ts/Ss)).
Ratio of extended times to no translation and no spin: Ret = Tet/Set = (Ts/(2Tfe(Ts/Ss)))/(2Ss/(3Sfe(Ts/Ss))) = (3/4) (Ts/Ss) (Sfe(Ts/Ss)/Tfe(Ts/Ss)).
If Ret equals 1, then we are bleeding energy in the same proportion form both spin and translation. Since our Ts/Ss ratio is not changing, Ret will remain 1 until both stop.
If Ret is greater than 1, spin is slowing faster than translation and our Ts/Ss ratio is increasing.
If Ret is less than 1, translation is slowing faster than spin and out Ts/Ss ratio is decreasing.
When Ret is not 1, we need to look at whether it will be heading towards 1 or away from 1.
If it is moving towards 1, one motion will end before the other. If it is moving towards 1, they are syncing up.
Ret is useful because we know the target is 1. But we can do the same sort of thing with the Ts/Ss ratio:
Letting the ratio be: Rs = (Ts/Ss)
Ret = (3/4) (Ts/Ss) (Sfe(Ts/Ss)/Tfe(Ts/Ss)) = (3/4) (Rs) (Sfe(Rs)/Tfe(Rs))
We are aiming for Ret equaling 1, so let
Target ratio: Rst such that (3/4) (Rst) (Sfe(Rst)/Tfe(Rst)) = 1
Rst = (4/3) Tfe(Rst) / 3Sfe(Rst)
At this value, the ratio will not change.
Now consider what happens when we are not exactly at Rst, say we are at Ratio=Rst+δ
d( (4/3) Tfe(Ratio) / Sfe(Ratio) ) / d(Ratio)
= (4/3) Sfe(Ratio)Tfe'(Ratio)) - Tfe(Ratio)Sfe'(Ratio) / Sfe(Ratio)²
We only need to know the sign of this value so...
Is Sfe(Rst)Tfe'(Rst)) - Tfe(Rst)Sfe'(Rst) < 0?
Sfe(Rst) is never negative (range is 0 to 1)
Tfe(Rst) is also never negative (range is 0 to 1)
Sfe'(Rst) is negative because the effectiveness of the spin energy loss always decreases with increasing spin.
Tfe'(Rst) is positive because the effectiveness of the translational energy loss always increases with increasing spin.
So both terms will be zero or negative. And they both can't be zero.
So the area around Rst has a negative slope. So if we have start with Rst+δ we will tend to move opposite from the change (δ), back towards Rst.
OK. I misunderstood what you were saying.
Actually, for a disc the point will lie on a spiral that will asymptotically spiral in towards or out towards a circle.
Can you be sure of that? Remember, the point is where the tangential equals the translational velocity - whatever the actual value (which will, of course, reduce with time). If the two motions decay together then the locus will be at the same distance from the centre. It would be only if what we are trying to prove were false that the locus curve would spiral inwards / outwards.
@.scott
I'm afraid that I trip out with such long and involved posts. I like to read some Maths, which condenses a model into a recognisable form. Maths was actually invented because it is impossible to hold so many lines of description in your head - if you are not the one who wrote it. Some of the most sophisticated Physics can be boiled down into a very few lines and this problem doesn't approach the complexity of EM theory - which is covered by just four equations.
If your graphics does not 'translate' to equations then it may be that there is something wrong somewhere.
The magic spin to move ratio is about 0.865 - I'm guessing it's really 5/6.
Here's the table. I've set it to show the ratio=0.86 with better resolution. The key is when the "4Sfe/3Tfe" column goes to 1. If you start it at that ratio, it will stay there. Otherwise it will move towards it.
Am I sure? I would say moderately. The only way to be sure about models like this is to run known cases against them. I've done a little of that - but not enough to be more than moderately confident.
Code:
| Pivot Pt.| Energy Loss % of Best |           |  d Energy / d Ratio   |
|  (Ts/Ss) | Translate |   Rotate  | 4Sfe/3Tfe | Translate |   Rotate  |
    0.000,     -0.000,    100.000
    0.100,      9.989,     99.495,     13.281,      0.999,     -0.051
    0.200,     19.902,     97.935,      6.561,      0.991,     -0.156
    0.300,     29.663,     95.235,      4.281,      0.976,     -0.270
    0.400,     39.189,     91.309,      3.107,      0.953,     -0.393
    0.500,     48.391,     86.101,      2.372,      0.920,     -0.521
    0.600,     57.170,     79.612,      1.857,      0.878,     -0.649
    0.700,     65.407,     71.933,      1.466,      0.824,     -0.768
    0.800,     72.952,     63.304,      1.157,      0.754,     -0.863
    0.850,     76.401,     58.769,      1.026,      0.690,     -0.907
    0.851,     76.468,     58.677,      1.023,      0.669,     -0.920
    0.852,     76.534,     58.586,      1.021,      0.660,     -0.909
    0.853,     76.600,     58.496,      1.018,      0.659,     -0.909
    0.854,     76.666,     58.405,      1.016,      0.658,     -0.909
    0.855,     76.732,     58.313,      1.013,      0.665,     -0.921
    0.856,     76.799,     58.220,      1.011,      0.664,     -0.921
    0.857,     76.864,     58.130,      1.008,      0.655,     -0.909
    0.858,     76.930,     58.039,      1.006,      0.654,     -0.909
    0.859,     76.995,     57.948,      1.003,      0.653,     -0.909
    0.860,     77.061,     57.856,      1.001,      0.660,     -0.921
    0.861,     77.127,     57.764,      0.999,      0.659,     -0.921
    0.862,     77.192,     57.673,      0.996,      0.650,     -0.909
    0.863,     77.257,     57.582,      0.994,      0.648,     -0.909
    0.864,     77.321,     57.491,      0.991,      0.647,     -0.909
    0.865,     77.387,     57.399,      0.989,      0.654,     -0.921
    0.866,     77.452,     57.307,      0.987,      0.653,     -0.921
    0.867,     77.516,     57.216,      0.984,      0.644,     -0.909
    0.868,     77.581,     57.125,      0.982,      0.643,     -0.909
    0.869,     77.645,     57.034,      0.979,      0.642,     -0.909
    0.870,     77.710,     56.942,      0.977,      0.649,     -0.921
    0.900,     79.588,     54.210,      0.908,      0.626,     -0.910
    1.000,     84.889,     45.766,      0.719,      0.530,     -0.844
    1.100,     88.136,     40.128,      0.607,      0.325,     -0.564
    1.200,     90.322,     36.021,      0.532,      0.219,     -0.411
    1.300,     91.917,     32.780,      0.475,      0.160,     -0.324
    1.400,     93.132,     30.124,      0.431,      0.121,     -0.266
    1.500,     94.083,     27.895,      0.395,      0.095,     -0.223
    1.600,     94.844,     25.991,      0.365,      0.076,     -0.190
    1.700,     95.465,     24.342,      0.340,      0.062,     -0.165
    1.800,     95.977,     22.897,      0.318,      0.051,     -0.144
    1.900,     96.406,     21.620,      0.299,      0.043,     -0.128
    2.000,     96.769,     20.481,      0.282,      0.036,     -0.114
    2.100,     97.079,     19.460,      0.267,      0.031,     -0.102
    2.200,     97.346,     18.538,      0.254,      0.027,     -0.092
    2.300,     97.578,     17.701,      0.242,      0.023,     -0.084
    2.400,     97.781,     16.938,      0.231,      0.020,     -0.076
    2.500,     97.958,     16.238,      0.221,      0.018,     -0.070
    2.600,     98.115,     15.596,      0.212,      0.016,     -0.064
    2.700,     98.255,     15.002,      0.204,      0.014,     -0.059
    2.800,     98.380,     14.453,      0.196,      0.012,     -0.055
    2.900,     98.491,     13.943,      0.189,      0.011,     -0.051
Here's the code that generated that table:
Code:
// SpinEnegryModel()
//  This routine computes the frictional forces acting on a spinning
// and translating disc at one moment in time.  The ratio of the speeds
// of rotation and translation are varied over a wide range.
//  It returns a multiline text report output in the form of a CString.
CString SpinEnergyModel()
  struct ReportEntry {
    double fRatio;
    double fELossX;
    double fSpinELoss;
  CString s, sRpt;
  ReportEntry reLast, reNew;
  int     nX, nY, nDiv, nYRange, bFirst;
  double  fR, fX, fY, fX2, fPivot, fPR, fRDiv;
  double  fForceX, fForceY;
  double  fSpeedX, fSpeedY, fSpeed;
  double  fForceXSum, fForceYSum;
  double  fSpinArm, fSpinForce, fSpinELoss;
  double  fSpinELossSum;
  double  fSpinELossMax, fArea;
  // and I am setting it to 1.  This doesn't really matter because
  // everything will scale to the radius anyway.
  fR = 1.0;
  nDiv  = 200;
  fRDiv = fR/nDiv;
  //  Integrate two initial values, these are not dependent on the
  // spin/translate ratio, so they are computed here, outside the pivot
  // point loop.
  //   fSpinELossMax:  The force that would have been applied against
  //                friction if there was no translational force.
  nArea = 0;
  fSpinELossMax = 0.0;
    // points that are on the books surface.  So we compute the range
    // of Y value that will keep us on the book (nYRange).
    //  We are using __int64 foor the intermediate results.  This will
    // allow us to use values of nDiv above 45000 - not that we would
    // want to run the program that long.
    fX  = nX*fRDiv;
    fX2 = fX*fX;
    //  Compute the book's area by integration so that it will match
    // the other integrals.
    nArea += 1+2*nYRange;
      fY = nY*fRDiv;
      // Integrate the maximum spin energy loss (with no translation).
      // Note:
      //   Both the force and the speed are proportional to the radius,
      //  so the total energy loss will be proportional to the square
      //  the radius.
      fSpinELossMax += fX2+fY*fY;
  // We skip some steps the first time through the loop.
  bFirst = true;
  // Apply the heading to our report.
  sRpt =
    L"| Pivot Pt.| Energy Loss % of Best |           |  d Energy / d Ratio   |\n"
    L"|  (Ts/Ss) | Translate |   Rotate  | 4Sfe/3Tfe | Translate |   Rotate  |\n"
    L"|----------|-----------|-----------|-----------|-----------|-----------|\n";
  // the book.
  for(fPivot=0.00; fPivot<=3.00; fPivot+=0.10) {
    //  Look carefully around 0.86.
    if((fPivot>0.81)&&(fPivot<0.995)) {
      fPivot -= 0.099;
      if(fPivot < 0.85) fPivot = 0.85;
      if(fPivot > 0.87) fPivot = 0.90;
    fPR   = fPivot*fR;
    //  We will be integrating three values:
    //           travel.
    //           as a check.
    //   fSpinELossSum:  The energy loss against the book's spin.
    fForceXSum  = 0.0;
    fForceYSum  = 0.0;
    fSpinELossSum = 0.0;
    // trailing edge to the leading edge.  These nX/nY loops step
    // through the same values as the nX/nY loops above.
      fX  = nX*fRDiv;
      fX2 = fX*fX;
        fY = nY*fRDiv;
        fSpeedX = -fY-fPR;
        fSpeedY = fX;
        //  Compute the speed of point (fX,fY) against the surface.
        fSpeed  = sqrt(fSpeedX*fSpeedX+fSpeedY*fSpeedY);
        //  I'm using a coefficient of friction of "1", so the absolute
        fForceX = fSpeedX / fSpeed;
        fForceY = fSpeedY / fSpeed;
        fSpinArm = sqrt(fX2+fY*fY);
        fSpinForce = fY*fForceX-fX*fForceY;
        fSpinELoss = - fSpinArm * fSpinForce;
        //  If the speed is less than fR-fPR, we can discard the
        // translation force because it will all cancel out within
        // that circle.
        //  This code was only used for test purposes.  It is now
        // commented out.
        // if(fSpeed<(fR-fPR)) fForceX = 0.0;
        // Accumulate frictional effects.
        fSpinELossSum += fSpinELoss;
    reNew.fSpinELoss = fSpinELossSum/fSpinELossMax;
    //  Except for sign, the translational energy loss (fELossX) is
    // proportional to the force.  This is because it is proportional
    // to the overall translational speed (fPR).  So we would
    // multiply by -speed (for energy loss) and then divide by speed
    // (for proportional energy loss).
    reNew.fRatio  = fPivot;
    reNew.fELossX = -fForceX;
    // Output fPivot, fELossX, and fSpinELoss here ...
    s.Format(
      L"%9.3f,%11.3f,%11.3f",
      reNew.fRatio, 100*reNew.fELossX, 100*reNew.fSpinELoss
    sRpt += s;
    if(bFirst) {
      bFirst = false;
      s = L"\n";
    } else {
      double fDeltaR, fDeltaMove, fDeltaSpin, d43RatioSsTs;
      fDeltaR      = reNew.fRatio     - reLast.fRatio;
      fDeltaMove   = reNew.fELossX    - reLast.fELossX;
      fDeltaSpin   = reNew.fSpinELoss - reLast.fSpinELoss;
      s.Format(
        L",%11.3f,%11.3f,%11.3f\n",
        (4.0/3.0) * reNew.fSpinELoss / reNew.fELossX,
        fDeltaMove/fDeltaR, fDeltaSpin/fDeltaR
    sRpt += s;
    reLast = reNew;
  return sRpt;
I think I translated it successfully. It's just not the most fluent thing I do. Some of those ratios (for example 4/3) are based on simple integrations of circle area - once for spin, once for translation.
As you can see in the previous post, I have also redone the program to report energy loss instead of force. This hasn't affected the "translate" (or "travel") column because there's a straight speed factor and the energy loss is scaled to speed anyway. But it made a difference with the spin column.
The assumption still seems to be that translational and rotational motion stop at the same time. Where is the evidence to back up this assumption? I suggest that respondents here try out a few preliminary tests for themselves. There are many variables to consider but in the first instance all that is needed is a flat surface and objects that can slide and rotate over it.
I have tried it out with different things and I am not at all convinced that both types of motion stop simultaneously. Try an object or book with a smooth surface and put a lot of spin on it.
There is quite some literature on the subject. This has even been the subject of at least one doctoral dissertation. The short answer is yes, friction couples rotation and translation and they both stop together. The final ratio between the linear and angular speed depends on the shape and mass distribution in the object in question. Some references:
A. Yu. Ishlinskii, B. N. Sokolov, and F. L. Chernousko, Motion of plane bodies with dry friction, Izv. Akad. Nauk SSSR, Mekh. Tver. Tela, 16 (4) (1981) 17-28
K. Voyenli and E. Eriksen, On the motion of an ice hockey puck, American Journal of Physics 53, 1149 (1985).
S. Goyal, A. Ruina and J. Papadopoulos, Planar sliding with dry friction. Part 1. Limit surface and moment function, Wear 143, 307–330 (1991).
S. Goyal, A. Ruina and J. Papadopoulos, Planar sliding with dry friction. Part 2. Dynamics of motion, Wear 143, 331–352 (1991).
Z. Farkas, G. Bartels, T. Unger and D. E. Wolf, Frictional Coupling between Sliding and Spinning Motion, Phys. Rev. Lett. 90, 248302 (2003). [http://arxiv.org/pdf/physics/0210024.pdf]
Guido Bartels, Mesoscopic Aspects of Solid Friction, PhD thesis, 2006 [http://duepublico.uni-duisburg-essen.de/servlets/DocumentServlet?name=duett-01272006-083621/]
Mark Denny, Comment on “On the motion of an ice hockey puck” by K. Voyenli and E. Eriksen, Am. J. Phys. 74, 554 (2006)
I would recommend reading at least the paper by Farkas et al.
Farkas found the asymptotic ratio to be 0.653, a lot less than my 0.865. I believe him.
The key thing is that we both agree that there is a value will always be approached as the disc slows. That, om general, the pivot point draws out a spiral, not a circle, onto the disc.
I can't take the work of Farkas et al and others seriously yet because because their findings do not conform to simple observations I have made. Where is the experimental evidence that both types of motion stop simultaneously?
I have done simple tests on my desk top and in many cases with different objects the motions do seem to stop at the same time. But not in all cases. I am able to put a lot of spin on a light weight, smooth covered book at the edge of my desk whilst sliding it towards the middle of my desk. Each time it seems to stop sliding long before it stops spinning. try it for youself.
The Farkas paper deals with a uniform disk specifically. Bartel's thesis is more generic, and he shows that for some mass distributions the terminal motion may be pure rotation. See Fig. 3.10.
Just tried it several times with a disc shaped lid from a storage jar and in each case both motions did seem to stop at the same time. Will try different variations later.
That's because your desk surface and/or the book (or disk) is not perfectly flat.
It just takes a very slight imbalance in the smoothness of the contact surface to throw the whole experiment off. Unless you can verify the smoothness of both the book and desk with high precision, the heavier book experiments are more valid because they are not quite as sensitive to small imperfections in smoothness.
This "catching" effect is even more pronounced if you are using a lid or any kind of ring shape instead of book or flat disk shape. Friction pressure gets localized instead of being spread out over the entire object.
The Farkas paper does include experiments. They used CD discs, data side down.
Yes I know. I scanned the paper. The initial observations I referred to were made were made with a book whose surface was smooth enough for me to set it spinning fairly fast whilst getting it moving with translational motion. I have since tried other things, including CD discs, but was unable to get these spinning as fast as I was able to get the book spinning.
Quite often the spinning /moving discs seemed to stop and then move momentarily in a different direction. There were also times when air pressure seemed to affect and slow down the movement. I assume this was due to the smoothness and close contact of the surfaces
There are so many variables to consider and pressure now seems to be another one.
The high spin situation is especially sensitive to anything that varies from the ideal. For translational motion, you're creating a near frictionless surface, so any local valleys in the surface will affect a slow moving object. Any dust or smudge on the table or the disc could cause a snag. The spin will cause more heat along the edge of the disc than in the middle - giving the disc a slight saddle shape. Also, if the spin is not strictly horizontal, there may be a bit of precession.
A.T. said:
Friction on Ice is quite complex, and cannot be modeled with a constant coefficient.
Here is more on the physics of curling:
https://www.youtube.com/watch?v=7CUojMQgDpM
hehe, I skipped pages 3-7 of this thread. :-p But didn't jbriggs444 nail it? :/ His/Her explanation seemed pretty convincing(to me atleast)
