Why does arc length formula require dx/dt > 0?
5 replies · 2K views · last reply
songoku
Please see below
none
This is not homework
Textbook page on arc length: the formula L = integral from a to b of sqrt(1 + (dy/dx)^2) dx, then the parametric form L = integral from alpha to beta of sqrt((dx/dt)^2 + (dy/dt)^2) dt, with the statement that dx/dt > 0 is assumed.
That passage is from James Stewart (Multivariable Calculus). I want to ask about the condition dx/dt > 0. If dx / dt < 0, the formula can't be used?
Thanks
Why not ? Can you find a counter-example ?
In my opinion, it can because from the derivation I don't see the need for dx/dt to be positive.
I just don't understand why dx / dt > 0 is written there in the text.
Thanks
If dx/dt > 0 then then x is increasing. Conversely, if dx/dt < 0 then x is decreasing.
Consider the parametric curve ##x = \sin(t), y = 1## for ##t \in [0, \pi]##. Graph this simple "curve" and determine its arc length from your graph. What does the integral formula for arc length of this curve produce?
The length of a curve should be the same, whether you start measuring it from the left end ([itex]dx/dt > 0[/itex]) or the right end ([itex]dx/dt < 0[/itex]). Some details of the derivation will change if [itex]dx/dt < 0[/itex]; in particular the assumption that [itex]f(\alpha) = a < b = f(\beta)[/itex] must be replaced by [itex]f(\alpha) = b > a = f(\beta)[/itex].
The graph is horizontal line y = 1 and 0 ≤ x ≤ 1.
I think the arc length should be 2 because the curve is traversed twice, once from left to right for 0 ≤ t ≤ π/2 and then from right to left for π/2 ≤ t ≤ π.
From integration, I get zero
I think I understand more clearly now from your post and Mark's example. The condition dx / dt > 0 is to ensure the curve is traversed once, only from left to right. If I want to use integration to find the arc length, I need to divide it into two cases, for 0 ≤ t ≤ π/2 and π/2 ≤ t ≤ π then subtract.
Thank you very much for the help and explanation BvU, Mark44, pasmith
