Why Does Changing Integration Limits Affect Arc Length Calculation?
10 replies · 7K views
johndoe
Find the length pf the curve over the given interval.
[tex]r=1+\sin\theta[/tex]
[tex]0\preceq\theta\preceq\2\pi[/tex]
Ok I set it up as:
[tex]2\pi[/tex]
[tex]\int\sqrt((1+\sin\theta)^2+cos^2\theta)[/tex]
and by simplifying and integrating, I get
[tex]2\pi[/tex]
[tex]-2\sqrt2[\sqrt(1-\sin\theta)][/tex]
[tex]-2\sqrt2[(1-0)-(1-0)] =0[/tex]
and obviously it is wrong,
I check the solution it has the same everything but the range ,
it obviously broke down the whole length into 2 times 1 piece from [tex]\pi/2 to 3\pi/2[/tex] and the answer is 8
My question is why I get zero within my range, and why broke it down into the range above?
You might wish to elaborate about how you got that integral. It's not what I get. You want to do the integral using a double angle formula to write the integrand as a perfect square. It also may help to shift the limits of integration by using sin(x+pi/2)=cos(x). You should also remember that sqrt(x^2)=abs(x) for any expression x. So to integrate something like that you'll need to break into regions where 'x' is positive.
There is some mistake on my first post but anyway I integrate it like this: (ignore the limits for the moment)
= [tex]\sqrt2 \int\sqrt((1+\sin\theta)[/tex]
= [tex]\sqrt2 \int \frac{\cos\theta}{\sqrt(1-\sin\theta)}[/tex]
(multiply up and down by [tex]\sqrt(1-\sin\theta)[/tex]
= [tex]2\sqrt2 [ \sqrt((1-\sin\theta)][/tex] (by substitution)
which if I use the limit [tex]\pi/2[/tex] to [tex]3\pi/2[/tex] and times 2
I get the answer, by I still don't understand what decision it based on setting the limits:rolleyes:,
I also tried from 0 to pi and times 2 and it came out to be zero , also when I trace on the calculator ( [tex]\pi/2[/tex] to [tex]3\pi/2[/tex])the x's are all -ve :rolleyes: clue?
So yes why the selected limits :confused: Also it will be great if you can demonstrate me a different way of integrating it and what do you mean by to shift the limits of integration by using sin(x+pi/2)=cos(x) :smile:
Thanks a million~
Ok wait I am up to something, it is because of the behaviour of the sin curve ?
for not getting zero I have to use that certain limit? :smile:
http://hk.geocities.com/ymtsang2606/sin.jpg
= [tex]2\sqrt2 \int \sqrt((1-\sin\theta)[/tex] (by substitution)
Thanks a million~
That's a clever trick. But it's hiding something from you. sqrt(cos(theta)^2)=abs(cos(theta)). As theta goes from 0 to pi, cos changes sign. Integrate from 0 to pi/2, then from pi/2 to pi and add the absolute values.
How do u get to sqrt(cos(theta)^2)?
sqrt(1-sin(theta))*sqrt(1+sin(theta))=sqrt((1-sin(theta))*(1+sin(theta))=
sqrt(1-sin(theta)^2)=sqrt(cos(theta)^2). Isn't that what you did?
= [tex]\sqrt2 \int\sqrt((1+\sin\theta)[/tex] (then I multiply up and down by [tex]\sqrt(1-\sin\theta)[/tex] ) <-- do u mean the sqrt cos^2theta on the top after multiplying?
= [tex]2\sqrt2[\sqrt((1-\sin\theta)][/tex]
Yes, I mean the cos(theta)^2 on the top under the square root.
Ok I get it now, so when you integrate you must make sure that the signs of the function would not change through out the limit range , cause otherwise they will offset each other, and given this case :[tex]\sqrt2 \int \frac{\cos\theta}{\sqrt(1-\sin\theta)}[/tex]
the sqrtcos^2theta on the numerator change signs with the range 0 to pi so you have to break it down into two parts and integrate, while sin doen't change signs in the denominator within 0 to pi so it doen't matter.
Thanks a million~
There's a superfluous integral sign in that post (the last line, where you've already performed the integration)... sorry to nitpick, but it might be confusing for those who are first signing on.
