Why does cos(22.5°) not equal 2/√5?
  • Context: High School
  • Thread starter Thread starter bonodut
    Trigonometry
The discussion revolves around the misunderstanding of trigonometric relationships, specifically why cos(22.5°) does not equal 2/√5. Participants explore the geometry of right triangles and the relationship between angles and slopes.
  • One participant expresses confusion about the cosine of 22.5° and derives a triangle with sides 1, 2, and √5, concluding that cos(22.5°) should equal 2/√5.
  • Another participant challenges this assumption, stating that a triangle with those dimensions does not correspond to an angle of 22.5°.
  • A later reply acknowledges the mistake in equating angle with slope and recognizes the need for a clearer understanding of trigonometric relationships.
  • One participant provides a formula relating slope to trigonometric functions, suggesting that the angle derived from the triangle is approximately 26.5°, not 22.5°.
  • Another participant suggests using an online triangle calculator to verify the angle measurements based on the triangle's sides.
Participants do not reach a consensus on the initial reasoning regarding the triangle dimensions and their corresponding angles. There is acknowledgment of misunderstandings, but no definitive resolution is presented.
Participants express uncertainty about the relationship between angles and triangle dimensions, and there are unresolved aspects regarding the correct application of trigonometric principles.
Individuals interested in trigonometry, geometry, and those seeking clarification on the relationships between angles and triangle properties may find this discussion beneficial.
bonodut
I've never really learned any trigonometry and I'm wondering if someone could tell me where I'm going wrong here.
My reasoning is this:
The hypotenuse of a 1,1,√2 right triangle is at a 45° angle to its base.
Halving that angle should require that the base leg be doubled if the height leg is kept at 1, giving the new triangle lengths of 1,2,√5
The cosine is adjacent/hypotenuse which would be 2/√5, yet calculators give a different answer. Why is this?
Mathematics news on Phys.org
Your mistake is in thinking that a 1, 2, sqrt(5) triangle has one angle 22.5 degrees.
So this assumption isn't correct?
Edit: I see now that it's not but I don't understand why... Seems like it should be
2nd edit: my problem was that I was equating angle with slope. I like math... Too bad I'm so bad at it! :/
The relation between angle and slope is
$$\mathrm{slope}=\dfrac{\mathrm{rise}}{\mathrm{run}}=\dfrac{\Delta y}{\Delta x}=\dfrac{\sin(\theta)}{\cos(\theta)}=\tan(\theta)$$
Draw a right angle triangle using protractor,scale,pen or pencil which I just did.By drawing the dimensions of right angle triangle of sides 1,2,## \sqrt 5 ## you will see that the angle made by hypotenuse and base is approximately 26.5° not your 22.5°.So, cos 26.5°= 2/##\sqrt 5## So the calculators were right and you may have made a minute mistake.
  • · Replies 17 ·
11K
  • · Replies 33 ·
