Why does ε + 2ε² + 3ε³ + ... equal ε/(1-ε)²?
  • Level: Graduate
  • Thread starter jbowers9
3 replies · 4K views · last reply
jbowers9
What they said:
f(ε) = Σ e-nε/kT n = 0 to ∞
Write the following series in terms of f’(ε):
g(ε) = Σ n ε e-nε/kT n = 0 to ∞
Then use the geometric series results to show that g can be written in the form:
ε + 2 ε2 + 3 ε3 + … = ε/(1- ε)2
What I did:
Let x = e-nε/kT
1/(1- x) = 1 + x + x2 + ...
1/(1- x)2 = 1 + 2x + 3x2 + 4x3 + ...
x/(1- x)2 = x + 2x2 + 3x3 + 4x4 +...
which leads me to:
g(ε) = ε e-nε/kT / (1 - e-nε/kT)2 n = 0 to ∞
How do they get, ε + 2 ε2 + 3 ε3 + … = ε/(1- ε)2
and what does it mean?
I'm not sure I understand your notation, please use proper parantheses.
Do you mean:
[tex]f(\epsilon) = \sum_{n=0}^{\infty} e^{-\frac{n \epsilon}{kT}[/tex]
OR
[tex]f(\epsilon) = \sum_{n=0}^{\infty} \frac{e^{-n \epsilon}}{kT}[/tex]
And what is your question?
Is it why does this hold:
[tex]\epsilon + 2 \epsilon^{2} + 3 \epsilon^{3} = \frac{\epsilon}{\left(1 - \epsilon \right)^2}[/tex]
If so, that's just taking derivative of both sides. If you need more clarification, let me know
Do you mean:
OR
The sum is the first one. The factor kT pegs this as a statistical mechanices problem.
Basically, to the OP, what the problem amounts to is that you have an infinite sum,
[tex]\sum_{n=0}^{\infty}\exp\left[-\frac{n\varepsilon}{k_BT}\right][/tex]
which is really just a geometric series: if you let [itex]x = \exp<br /> \left[-\frac{\varepsilon}{k_BT}\right][/itex], you get
[tex]\sum_{n=0}^{\infty} x^n = \frac{1}{1-x}[/tex]
(since the exponential is always less than one). Hence, if you take a derivative with respect to [itex]\beta = 1/(k_BT)[/itex] you get
[tex]\sum_{n=0}^{\infty} n \varepsilon e^{-n \varepsilon \beta} = -\frac{\varepsilon e^{-\varepsilon \beta}}{(1-e^{-\varepsilon \beta})^2}[/tex]
which allows you to easily find the average energy of the system.
Or, even simpler, leaving it as x and differentiating with respect to that,
[tex]\sum_{n=0}^{\infty} nx^{n-1} = \frac{1}{(1-x)^2}[/tex]
so just multiply by [itex]\varepsilon e^{-\varepsilon \beta}[/itex] to get
[tex]\sum_{n=0}^{\infty} n \varepsilon x^n = \frac{\varepsilon x}{(1-x)^2}[/tex]
I understand how to proceed to get the expression
but epsilon is a constant, hυ, not e-nε/kT. Do they mean that ε = f(ε) = e-nε/kT? That makes sense then.
