Cookiey
- Messages
- 14
- Reaction score
- 0
Two point charges a and b whose magnitudes are same positioned at a certain distance along the positive x-axis from each other. a is at the origin. The graph is drawn between electrical field strength and distance x from a. E is taken positive if it is along the line joining from a to b.
From the graph it can be decided that
1) a is +ve b is -ve
2) a and b are both +ve
3) a and b are both -ve
4) a is -ve and b is +ve
The attempt at a solution
As the electric field is defined with respect to a positive unit charge, a should be positive. This is because the field strength near a is tending to positive infinity, and according to the question, this is from a to b. So, this can be interpreted as repulsion.
As we move towards the middle of the graph, the strength decreases, almost to zero, so the field from point charge b must be cancelling it out. So b is also positive.
But why does the graph go towards positive infinity again? Because if b is also positive, won't it push our test positive unit charge away? This direction would be from b to a, right? Shouldn't the graph go to negative in that case?
The answer is given as a and b both being positive.
Thanks for helping!
Thanks for helping!
